Pioneer's NEW 7th Generation Plasmas for 2006-2007 - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 4252 Old 06-10-2006, 12:36 PM
cpcat's Avatar
Originally Posted by leisureg View Post
and that is my basic question. Will the 50" Pioneer Pro-FHD1 have a noticeably better picture on lets say CBS-HD broadcasts versus the 5070 watching CBS-HD at 9 feet? It is all confusing but the Pioneer Pro-FHD1 specs says it upconverts the signal. I was just wondering if this upconverting will be noticeable and worth the $4K difference in price
At 9 feet on a 50 inch screen, you'd qualify as being able to see the difference. For this much cash though, I'd see it first (preferrably even side by side with the 5070) before buying if I were you.
cpcat is offline
post #362 of 4252 Old 06-10-2006, 01:24 PM
apru's Avatar
Originally Posted by cpcat View Post
Not a dumb question at all. You'll get two answers though. One will say "1080p screen resolution is better regardless just because". The other is my answer in that it all depends on screen size/viewing distance. You won't see any differences based on the higher screen resolution alone (assuming all other factors equal) unless you sit close enough or the screen is large enough.
I'd think that all things being equal the 50"1080p panel would allow a smaller viewing distance (compared to a 50" 720p panel) since the picture elements are necessarily smaller, ie, finer. When I compare 42" v. 50" sets from the same manufacturer, for example, the 42" sets have a better picture from the same approx. 6' distance. Consequently the new Pio 50" 1080p should offer better images from a wider range of viewing areas than its 50" 720p sibling. Correct?
apru is offline
post #363 of 4252 Old 06-10-2006, 01:34 PM
cpcat's Avatar
Yes. Simply put, you need to sit close to take advantage of the added screen resolution of the FHD-1. This means 9 feet or closer and in fact you can sit as close as 6 feet and still easily be far enough away for the pixel structure to be invisible.
cpcat is offline
post #364 of 4252 Old 06-10-2006, 02:06 PM
leisureg's Avatar
But what about my question as it refers to broadcast HD broadcasts? Would there be a noticeable difference or would the 1080P Pio have the better pic than the 5070. I just am not sure of this upconverting feature
leisureg is offline
post #365 of 4252 Old 06-10-2006, 02:22 PM
cpcat's Avatar
Whether you benefit from 1080p screen resolution is independent of the input signal. It depends entirely on screen size/viewing distance considerations. Any theoretical advantage a 1080p screen has with a 1080i input signal will be captured by the screen size/viewing distance consideration anyway.
cpcat is offline
post #366 of 4252 Old 06-10-2006, 03:43 PM
Tonypaul's Avatar
I remember viewing the PRO-FHD1 at CES from 3.5 feet (BD source/"Chicken Little") with no visible pixel structure. However on my PRO-1130, the pixel structure becomes visible at 6"- 2" (If I look for it). At 4'- 6" the SDE is overwhelming.
This month's new word. The Dopeler Effect: The tendency of stupid ideas to seem smarter when they come at you rapidly .
Tonypaul is offline
post #367 of 4252 Old 06-10-2006, 04:32 PM
Elemental1's Avatar
That does not sound good...
My HT
In the words of English philosopher Edmund Burke, ÂAll that is necessary for the triumph of evil is that good men do nothing.Â
Elemental1 is offline
post #368 of 4252 Old 06-10-2006, 04:41 PM
Tonypaul's Avatar
Are you being facetious, who watches a 50" - 720p plasma from less than 5 feet ? I generally watch the 1130 from 7', and I consider the PQ stunning.
PS. Just for reference, my vision is 20/20.
Tonypaul is offline
post #369 of 4252 Old 06-10-2006, 04:57 PM
cpcat's Avatar
I can't see the pixel structure on my 50 inch 768p until about 5 feet either, I was just trying to give a very safe estimate with the 1080p for those eagle eyes out there.
Overall the watershed estimates I gave are probably overdone as well. In other words, they are biased towards getting a 1080p screen and many probably will still be fine with 768p at even closer distances/larger screen sizes.
Afterall, I wouldn't want to be party to slowing progress.
cpcat is offline
post #370 of 4252 Old 06-10-2006, 05:10 PM
Tonypaul's Avatar
cpcat, thanks for the feedback.
Tonypaul is offline
post #371 of 4252 Old 06-10-2006, 10:16 PM
Harden's Avatar
Is it true that the new Pioneers plasmas are NOT going to have the separate media box? Is this true for both the Elite and non-Elite series?
Harden is offline
post #372 of 4252 Old 06-11-2006, 03:26 AM
MisterVball's Avatar
That is correct, the media box has been eliminated.
MisterVball is offline
post #373 of 4252 Old 06-11-2006, 03:47 AM
westa6969's Avatar
Quoted: 398 Post(s)
Liked: 418
I see much discussion on 1080P and the real difference versus a 768 display and for those that think that a native 1080P display makes no difference I would issue a challenge to see it real life in a very simple smack in front of your face viewing experience with an SXRD 60" displaying from a Sony HD Box "Hawaii". My point is not to sell anyone on SXRD or any better than scenario but to point out just how much better 1080P or i can be on a native display, even the version that doesn't take 1080P.
Simply go to a Circuit City anywhere in the country where they have this setup and cpcat may have mentioned 5'? That's a joke - you can put your eyeballs up to the panel and not see pixels on that feed yet your cannot say that for any other panels in the store except perhaps the new 1080P Samsungs being fed likewise.
My Sharp is a native 1080 display that doesn't take the progressive but hell at 1:1 pixels I can get within less than a foot before seeing any pixeling and that is not being fed via a 1080P Box - and viewing CSI Miami I cannot see any from within inches.
My point is not a better than scenario or tech but that the fill factor on a large panel is just amazing on 1080P Native Displays and when you folks see it on the new Panasonic 65" and the Pio 60" you'll be blown away comparatively just as a 60" SXRD or a 70" Q006 blows away a 3LCD panel and most other technology, add to that the HP, JVC Pro 1080P, the Brillian and now plasma will join. The BONUS is getting a larger panel for HT immersion with kick ass clarity and details a step above.
For those naysayers on 1080P and it's difference I'll be back after Rich Harkness has done his review of both the Pio/Panasonic after he has jaw surgery when he reports the blow you away fill factor with next to no visible pixels (you can bet they'll have a Blu-Ray feeding it). Go see the SXRD or half a dozen other native displays being fed HD and there is a difference and my point is not to be argumentative but rather despite PDP owners not having 1080P previous the fill factor will make a big difference just as it does with LCD and RPTV and FP. Eventually they'll all migrate to 1080P and a price premium is always there for early adopters. Enjoy!
Samsung 75HU8550w/SEK-3500-UHDVideoPk, 65F8000, 60D8000, 40HU6350, Philips Folio Soundbar
XBoxOne/360, FPS's Borderlands 1/2, EDF 2017/2025, Halo's
westa6969 is offline
post #374 of 4252 Old 06-11-2006, 05:27 AM
VFR
VFR's Avatar
I had not seen this posted yet , I guess the 43" panel isnt dead yet.
http://www.pioneer.co.uk/uk/product_...onomy_id=62-63
VFR is offline
post #375 of 4252 Old 06-11-2006, 05:31 AM
Harden's Avatar
Why is Pioneer elimnating the media box? To me - someone is considering either the new Pioneers or the "old" Pioneers - the media box is very attractive due to not having to fish new wire for future peripherials.
Is it just a matter of cost? Do current Pioneer owners not like the media box?
If I'm looking for a non-Elite 50" plasma, then the 5060HD is my best bet, right?
Harden is offline
post #376 of 4252 Old 06-11-2006, 05:41 AM
cpcat's Avatar
No one said it doesn't make a difference. Whether you'll benefit from 1080p screen resolution is simply based on screen size/viewing distance. Many viewing situations will not allow a close enough viewing distance to justify the added cost. From the S&V article linked in your signature:
If your room layout restricts either your viewing distance or the screen size, you actually have more choices. Say you're limited to a seating distance of around 10 feet and a screen width of 50 inches. In this case buying a 1080i/p set won't get you better resolution than a 50-inch 720p set (the 10-foot/50-inch point lies above the 1080i/p trace). You might be able to save some money by choosing a 720p model. Then again, all screen sizes seem to be switching over to 1080i/p pixel counts, and eventually 720p sets may be hard to find.
That last sentence represents the "just because" argument.
That same article also recommends being at least 6 feet away from a 50 inch 1080p screen. I think you could probably be a little closer, but not within inches as you seem to be proposing.
cpcat is offline
post #377 of 4252 Old 06-11-2006, 07:02 AM
Elemental1's Avatar
No, I'm not. I guess that is why I took the 500u over the Elite 1130HD.
I had noticed this myself on the 1130HD and was surprised.
My HT
post #378 of 4252 Old 06-11-2006, 07:37 AM
alpina's Avatar
initially i was concerned about this also but no more
as a 5060 owner, i dont really see the big deal as you are already running a dvi and controller cable from media box to plasma.
if i upgrade to the 1080p model, i'll simply run 2hdmi cables (1 for the sake of it) which will take up less surface area than existing cables and control it all through a video switcher (ideal) or though existing avr.
im still hurting from the optional 10mt cable i had to buy to connect existing media box to plasma due to large distance apart - needed 5mts and std cable is 3mts
my biggest gripe with the new units is that they are thicker than the 5060. i would imagine that it's because it needs to house all the added circuitry (ie, built in media box) but disappointing nonetheless.
cheers,
julie
alpina is offline
post #379 of 4252 Old 06-11-2006, 08:15 AM
Elemental1's Avatar
Hopefully there won't be any new 'features' introduced like interference, heat...etc...etc from the new design.
My HT
post #380 of 4252 Old 06-11-2006, 09:51 AM
a_ok2me's Avatar
Quoted: 42 Post(s)
I originally liked the idea of a separate box too, but now I'm finding that I'm out of cabinet space for all my equipments. I either will have to place the media box + some other component vertically or place them outside the cabinet, next to the tv - very unattractive. I assume most people are in this, rather than the wall mount, situation. If you wall mount and can't hide your av components, you're better off having wires running up the display than having av component anywhere they fit.
a_ok2me is offline
post #381 of 4252 Old 06-11-2006, 12:13 PM
Tonypaul's Avatar
You do not mention the size. 50" or 42"?
Tonypaul is offline
post #382 of 4252 Old 06-11-2006, 12:57 PM
Elemental1's Avatar
50", what else?
My HT
post #383 of 4252 Old 06-11-2006, 02:02 PM
omegaGray's Avatar
Whoops--disregard, please
A.B.
omegaGray is offline
post #384 of 4252 Old 06-11-2006, 03:10 PM
cajieboy's Avatar
Quoted: 125 Post(s)
Liked: 69
Westa my man, you said it straight. This is exactly my view as well. 1080p has been in the works for a very long time, and when the mfg'ers finally were able to accomplish this feat I knew we were in for one heck of a ride on the PQ train. I've already got an HD-Lite TV, and for my next HT Upgrade I will not settle for anything less than a 1080p display w/can input AND output 1080p.
Concerning viewing distances...for those people that can't possibly move their sofa or chair a few feet forward, do you thing think you'll be watching your new display from the exact same spot and distance day in and day out for the entire life of the TV? What if you ever want to move it to the kitchen area or the bedroom, etc.? For myself, I want the very best PQ & resolution I can get regardless, but then that's JMHO.
cajieboy is offline
post #385 of 4252 Old 06-11-2006, 04:00 PM
cpcat's Avatar
In other words, "just because".
No problem, your money.
cpcat is offline
post #386 of 4252 Old 06-11-2006, 04:09 PM
billybob_jcv's Avatar
I'm waiting for 2160p - I heard you can mount a 65" to the front of your Barcalounger *without* a trace of SDE...
If you think this post was dumb, you really should read my blog=> http://bumpedhishead.blogspot.com/
billybob_jcv is offline
post #387 of 4252 Old 06-11-2006, 04:16 PM
cpcat's Avatar
cpcat is offline
post #388 of 4252 Old 06-11-2006, 06:34 PM
a_ok2me's Avatar
Quoted: 42 Post(s)
Also, I'm not sure if anyone covered this, but I just hooked up my PC to my 50" Elite and split-screened it (TV/PC). My PC is at 1024x768. PC screen looks good, but it's still a little distorted and you'll get some blurry rows of text. It would be really nice to have the additional resolution. I bet gamers would also appreciate 1080p.
OT: What I really love about the setup I have is that it cleared up all the clutter of a separate PC and TV. My PC is hidden in my cabinet along with my AV components.
a_ok2me is offline
post #389 of 4252 Old 06-11-2006, 07:38 PM
AnybodyM's Avatar
That sounds more like an interpolation issue to me. Even if you had a higher resolution this would only slightly reduce this effect. Text can only be read well with an 1:1 mapping of the PC pixels to the screen pixels.
Unfortunately, most TV-Displays do currently only support this over the VGA Input and not on the DVI/HDMI inputs :-(
(and VGA offers inferior quality as well as sometimes signal syncronisation issues)
How did you connect your PC to the display? Did you set your PC to the native resolution of your plasma display?
Regarding the new 427/507 Plasma:
The specifications looks like it will have a HDMI v1.3 capable connector. I heard that 1.3 will improve compatibility with PCs. So it might finally offer a working digital connection to PCs without beeing plagued by overscan and interpolation.
Isn't that worth waiting for, isn't that worth dying for ?
AnybodyM is offline
post #390 of 4252 Old 06-11-2006, 09:06 PM
a_ok2me's Avatar
Quoted: 42 Post(s)
You think? It does however look perfect in full screen.
The media box has a VGA input just like a regular LCD computer monitor.
HDMI would be nice.
a_ok2me is offline
