Question to users of Pioneer Media Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-02-2006, 06:44 AM - Thread Starter
Jediphish's Avatar
For those of you who have Pioneer Plasmas with the Media Receiver, and also use an external A/V receiver to process audio signals, which method are you using for routing/switching your audio and video signals? (I can think of these three possibilities)
A. Video Out from sources to MR; Audio Out from sources to A/V receiver; Audio Out from MR to A/V reciever (for TV tuner audio) (using both receivers to perform switching of sources)
B. Video Out from sources to A/V receiver; Audio Out from sources to A/V receiver; Audio Out from M/R receiver (for TV tuner audio); Video Out from A/V receiver to MR (using the A/V receiver as a switcher for most viewing (except TV tuner))
C. Video Out from sources to MR; Audio Out from sources to MR; Audio Out from MR to A/V receiver (essentially using the MR as the sole switching device)
Does one of these work better than the others with respect to audio/video synch? I generally like to be able to customize setting for both audio and video and option A seems like the best method, although the most complicated.
Thanks in advance for the feedback.
Jediphish is offline
Closed Thread Plasma Flat Panel Displays
