I've got a 50" Panasonic wallmounted using the Peerless flat mount (SF-660). I used a flashlight to look behind the TV and noticed that the upper corners of the mount are slighly pulled from the wall. Nothing drastic, but I'm guessing you could slide a baseball card between the mount and wall.
Is this normal? Are the mounts designed to give a little?
It's just the edges and not where the screws go into the wall/studs. Anyway, I was a little surprised given that the TV is only half of the rated load (up to 200lbs.).
By the way, what's up with your sig? VY was 30-2 as a starter and only one of those losses was to OU (2004). The other was the 2003 Holiday Bowl vs. Washington State.
Originally Posted by the juggernaut
I know that I hit the studs. The other side of the wall is attic space, so I was able to inspect the studs after I drilled in the screws.
I would take the plasma down and inspect the mount. Not worth the risk otherwise
for starters, I would inspect the bolts and see if they reversed on you (doubtful) and tighten them.
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
