connecting laptop to Plasma tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-06-2006, 08:36 AM - Thread Starter
geem's Avatar
I have a dell 9300, and i'd like to connect it to my Pioneer PDP-5071HD.
this are the connections I have on the laptop http://www.notebookreview.com/assets/3936.jpg
I know before I connected the laptop through the S-video, but I'd like to use the DVI if possible. if i get a DVI to HDMI cable, would that work? also that should take care of the video AND audio right?
geem is offline
post #2 of 7 Old 07-06-2006, 08:59 AM
coastalb55's Avatar
HDMI carries an audio signal and DVI does not. So you'll need to figure out another way to get your audio if you have to use DVI.
[EDIT] Brain not communicating properly with hands - fixed my mistake
coastalb55 is offline
post #3 of 7 Old 07-06-2006, 09:08 AM
thegurujim's Avatar
Originally Posted by coastalb55
DVI carries an audio signal and HDMI does not. So you'll need to figure out another way to get your audio if you have to use HDMI.
Reverse what ^ he ^ said.
As far as the audio is concerned you'll have to use the laptop speakers, headphones, or hook up some external speakers to it.
thegurujim is offline
post #4 of 7 Old 07-06-2006, 09:09 AM - Thread Starter
geem's Avatar
I am pretty sure HDMI carries audio.
geem is offline
post #5 of 7 Old 07-06-2006, 09:13 AM - Thread Starter
geem's Avatar
ok cool. will the video be better if i use the DVI rather than the VGA or S-video then?
and I could use this to connect the laptop to my receiver right? http://www.cablestogo.com/product.as...2033&sku=40236
geem is offline
post #6 of 7 Old 07-06-2006, 09:14 AM
malaugh's Avatar
You need :
1) A DVI to HDMI cable to route the video to the TV
2) A 3.5mm to RCA audio cable to route the headphone audio from the PC to the audio input on the TV
Set your the video in your laptop to 1280 x 768
malaugh is offline
post #7 of 7 Old 07-06-2006, 09:17 AM
Pdogg320's Avatar
i have a simalar question but if i have a laptop that supports only a vga out and i get a vga to component (since the tv dosent have a vga in - 50px60) would that work?? Cause from what i know u cant do vga to hdmi cause u cant do analog to digital, u can only do dvi to hdmi correct?
Pdogg320 is offline
Closed Thread Plasma Flat Panel Displays
