Need help to pick new Pioneer Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-06-2006, 01:09 PM - Thread Starter
Janjan's Avatar
My Pio 503CMX is 3 years old. I had a $1000 repair done a year ago (as well as the power supply upgrade), now the same problem has returned. I'm told it needs a new panel for $3000. Yeah, right. Anyway, Pioneer is going to work with me. I need to pick a couple of models I'm interested in to replace it and they will let me trade mine in. I did my research when I bought the original Pio, but now I'd like to rely on your opinions. I want another 50". What do you think? Thanks. :confused:
Janjan is offline
post #2 of 7 Old 07-06-2006, 01:17 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2000 Post(s)
Liked: 2162
2 options:
Pioneer PDP-505CMX (Click Here)
http://www.pioneerindustrialav.com/p...angled_std.jpg
Add the Key Digital Xplorer Card and you will have a Pioner Elite picture quality with alot more inputs. Click Here
http://www.keydigital.com/images/Vid...lorer_v2_a.jpg
There is no other panel on the planet with these kinds of inputs:
4 hdmi (supports HDCP)
DVI(supports HDCP)
2-VGA, Component
Composite
S-Video
or the
Pioneer PDP-5070HD
Cleveland Plasma is offline
post #3 of 7 Old 07-06-2006, 01:22 PM
cheridave's Avatar
Personally, I don't know all of your specifics but if Pioneer is willing to work something out with you and you are more than satisfied with the Pioneer product then I would recommend that you stay with Pioneer.
Maybe try the consumer line. A lot of satisfied members here already with the XX70s.
You are already familiar with its features and picture characteristics.
There is no guaranty that you would not have any issues with any other model you select.
Good luck.
Dave
"Appeasment only makes the Aggressor more Aggressive"
cheridave is offline
post #4 of 7 Old 07-06-2006, 01:46 PM
dssturbo1's Avatar
see how well they really want to work with you on a fhd1 the new 50" 1080P model :)
HD HD HD I Need more HD, Yes I am a HD Addict :)
dssturbo1 is offline
post #5 of 7 Old 07-06-2006, 09:24 PM
BruZZi's Avatar
I would get the Pioneer PDP-5070HD.
__________________________________________________ _
Samsung 55KS800 • Pioneer Elite VSX-90TXV • Oppo BDP-103D
Paradigm Studio 10's • Paradigm Studio CC-490 • Sunfire HRS-8
BruZZi is offline
post #6 of 7 Old 07-06-2006, 09:54 PM
athens2005's Avatar
I just bought the pdp5071 from bb and all i can say is WOW, the picure is amazaing and thats coming from a 480p dvd player i havent gotten my Toshiba HDA1 yet. Basic cable looks very good too.
athens2005 is offline
post #7 of 7 Old 07-07-2006, 09:03 AM - Thread Starter
Janjan's Avatar
Thanks everyone for your input. I will talk with Pioneer today and see what kind of deal we're talking about.
Janjan is offline
Closed Thread Plasma Flat Panel Displays
