Panasonic Plasma Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-06-2006, 09:17 PM - Thread Starter
Boris968's Avatar
I have a TH42PD50 with a cable card. I've had it for a little over a year and everything has been fantastic. All of a sudden, on all non-HD channels, the right third of the screen is dark. I know that some sets have required firmware fixes, but I have no idea if this is the problem here. Has anyone experienced anything like this? How do I fix it?
Thanks...
Boris968 is offline
post #2 of 3 Old 07-06-2006, 09:51 PM
BruZZi's Avatar
Try the Self-Check Function :
Press VOLUME (-) button on The TV & SLEEP button on the remote simultaneously.
On the Screen Display, anything other that "OK" indicates a problem.
Press Channel + / - to exit.
NOTE: On the 60/600U Models The Self-Check function is also the factory reset. Not sure about the 50/500U Models so write down the pictures setting (if you need to) just in case.
__________________________________________________ _
Samsung 55KS800 • Pioneer Elite VSX-90TXV • Oppo BDP-103D
Paradigm Studio 10's • Paradigm Studio CC-490 • Sunfire HRS-8
BruZZi is offline
post #3 of 3 Old 07-07-2006, 08:08 PM - Thread Starter
Boris968's Avatar
Thanks for the suggestion... I will try it.
Boris968 is offline
Closed Thread Plasma Flat Panel Displays
