Panasonic TH-50PM50U screen location adjustment - AVS Forum | Home Theater Discussions And Reviews
Old 07-07-2006, 12:44 PM - Thread Starter
Socceteer's Avatar
Hi all
Does any one know how to adjust the screen location. I am not sure if it is my TV or my Dish Network HD DVR. It looks like the screen is not centered it is noticeable during some of the none HD shows I can see some lines on the top of the screen. I used a a calibration CD and it shows a little off also. But I do not know how to adjust it..!
I could use some help..!
Socceteer is offline
Old 07-07-2006, 12:51 PM
sportsnut's Avatar
Last year's Panasonic's (50 and 500 series) had no way to change the alignment of the picture, even within the service menu. This years models were supposed to rectify that issue but I haven't heard either way if it in fact is available now.
sportsnut is offline
Old 07-07-2006, 12:55 PM - Thread Starter
Socceteer's Avatar
WOW...do you know if that was a software change...?
If so will they be able to provide a way to update the software..?
Old 07-08-2006, 09:38 AM
sportsnut's Avatar
As far as I am aware there is absolutely no fix for this picture problem. In some of the threads here (several months ago) the people that had this problem and were under warranty actually had their sets replaced.
