Accessories for Panny 600u - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-11-2006, 09:55 PM - Thread Starter
ninmess's Avatar
All,
Just bought my Panasonic 42px600u and I need your help in buying the accessories to go with it. The existing equipment is -
Television: Panasonic 42px600u
Home Theater: Bose Lifestyle 800 series
DVD: JVC XV-421 and DeSay DS-5701
I assume that these peripherals are pretty old, but with this configuration, what hardware/accessories/cables would you recommend for an optimal experience?
What surge protector should I consider? Will HDMI/Composite/Component work with these peripherals?
I do not have Cable/Direct TV yet but lets assume I go HD soon.
Thanks for your help!!!
ninmess is offline
post #2 of 3 Old 07-11-2006, 10:55 PM
Mr. Plasma's Avatar
Look at Monster Cable surge protectors, for a start. They are a little pricey but seem pretty solid. I am getting an HTS 3500 mk II.
For an optimal experience, first find out whether your DVD player is a progressive scan or not, if not you will want to update that so it will give you the best quality video.
Mr. Plasma is offline
post #3 of 3 Old 07-12-2006, 09:47 AM - Thread Starter
ninmess's Avatar
Thanks, will check out monster. My DVD is progressive scan. I assume I will need to go with composite cables for now.
ninmess is offline
Closed Thread Plasma Flat Panel Displays
