Panasonic plasma input settings? - AVS Forum | Home Theater Discussions And Reviews
Old 07-13-2006, 01:12 PM - Thread Starter
JShadden's Avatar
Hello all,
I'm having a problem that I couldn't find an answer to yet. I bought a 42" Panasonic commercial plasma a while ago and just yesterday had cable installed. Up until then, I just watched DVD's through a DVI blade that I added. Anyway, I'm using a DVR box with component out, but I'm not getting a signal. I know the cable signal is good because I can hear the stations through the receiver, but no matter what option I change on the Panasonic, I still get "No Signal" on the screen. I did try it using a s-video cable and that did work. I did have to use RCA to BNC adaptors to hook into the screen. Is is possible that all three adaptors are bad or maybe I just bought the wrong type? I ordered them off of eBay and made sure they were 75ohm.
Any suggestions would be appreciated!
JShadden is offline
Old 07-13-2006, 01:33 PM
DougRuss's Avatar
Did you go into the Panny Menu and Assign the Connection you have the Cable Box as Component ??
Yamaha RX-V479
Cambridge Audio " Azur-650c
Rega RP-1 Turntable
YAQIN MS-12B Pre-amp
GemTune BL-02 EL34*2 Hi-end Tube Amplifier
Monitor "Bronze 5" Speakers
DougRuss is offline
Old 07-13-2006, 01:52 PM - Thread Starter
JShadden's Avatar
Yes, I did. Something I forgot to add was that I tried using composite video with a RCA to BNC adaptor and that didn't work either.
JShadden is offline
