The OFFICIAL Panasonic 9UK Owner's Thread - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #5041 of 5069 Old 01-03-2011, 07:02 PM
Denon_Kid's Avatar
Originally Posted by Suzook View Post
Ok so they were out to look at my set. They are talking about replacing the whole glass??? Why on earth are they going to do that. Will this effect my ISF calibration?
Ugh
would it not be cheaper/simpler to just replace the whole set?
Denon_Kid is offline
post #5042 of 5069 Old 02-02-2011, 08:15 AM
jw1
jw1's Avatar
So I'm considering "cutting the cord."
Any suggestions for an affordable tuner and HD antenna for my 9UK?
Also, I live in Manhattan. Am I going to be able to pick up a decent signal (or any signal for that matter) with an antenna?
jw1 is offline
post #5043 of 5069 Old 02-02-2011, 10:53 AM
bretski's Avatar
There are many options out there...just depends on what you want to get out of it. Are you just looking to watch TV, or do you want DVR capabilities?
As far as antenna and signal goes, start with antennaweb.org. Then, check the OTA forums for the appropriate NYC thread:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=45
bretski is offline
post #5044 of 5069 Old 02-04-2011, 02:43 PM
jw1
jw1's Avatar
Thanks for the info.
I'd be interested in knowing what's been working for other people.
jw1 is offline
post #5045 of 5069 Old 11-01-2011, 07:19 PM
p3Orion's Avatar
Quoted: 13 Post(s)
Liked: 41
I don't have an HDMI blade so my options are VGA and component. Does VGA provide a better picture than component with the Xbox 360?
p3Orion is offline
post #5046 of 5069 Old 11-01-2011, 08:11 PM
Suzook's Avatar
Liked: 27
whoa and oldie but a goodie thread comes to life
Suzook is offline
post #5047 of 5069 Old 11-02-2011, 03:44 AM
Yaka's Avatar
Yes VGA would be better, on my panny 42 phd8 I grew tired of having to switch cables so now use hdfury, everything is connected via my amp, if your lazy like me then the cost of hdfury is worth it
Yaka is offline
post #5048 of 5069 Old 12-24-2011, 08:21 AM
jw1
jw1's Avatar
Is the TY-ST20K stand compatible with the 42PH9UK display?
jw1 is offline
post #5049 of 5069 Old 12-24-2011, 08:28 AM
Techniwizard's Avatar
Sorry but no.
You need TY-ST08K, TY-ST07K, TY-ST05K, TY-STPA20, TY-PF1, TY-PF3
TY-ST20 only fits newer Pro Series 20 and 30.
Techniwizard posts as an Independent Servicer
Techniwizard is offline
post #5050 of 5069 Old 12-24-2011, 09:12 PM
batpig's Avatar
Quoted: 2844 Post(s)
Liked: 2737
bummer, so they decided to change the post spacing on the new 20/30 series Pro displays?
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5051 of 5069 Old 12-25-2011, 02:01 AM
That is correct, also changed are the bolt mounting patterns and tread and pitch.
PIP (picture in picture) is eliminated in the Series 30 to make way for 3D capability.
And the 720p "PH" Series 30 models no longer feature option board slot 2.0
The 1080p "PF" Series 30 models DO have the option slot.
Merry Christmas or Happy whatever Holiday you may celebrate.
T Wiz
post #5052 of 5069 Old 08-05-2012, 08:23 PM
bretski's Avatar
Anybody out there have a stand for this panel that they don't need anymore? I'm interested in getting one...please PM me, if so.
bretski is offline
post #5053 of 5069 Old 11-08-2013, 09:58 AM
temesgen's Avatar
does anyone know off the top of their head if these TVs are better suited for RB limited or full using HDMI inputs?
temesgen is offline
post #5054 of 5069 Old 11-08-2013, 10:18 AM
batpig's Avatar
Liked: 2737
Consumer video sources are intended to work with component (YPbPr) color space, which includes range for "whiter than white" and "blacker than black" information. That corresponds with RGB limited (not full) for a typical source device like a cable box, blu-ray player etc.
temesgen likes this.
Setup Guide and FAQ
batpig is offline
post #5055 of 5069 Old 11-08-2013, 04:17 PM
TopShelf17's Avatar
My 50 9UK has a little more than 19,000 hours and 6,000 switch ons and is still going strong after almost 7 years.
The picture is still stunning.
TopShelf17 is offline
post #5056 of 5069 Old 01-09-2014, 01:04 AM
philapo's Avatar
So it's clear i'm using an old monitor and I may not get any help here but i'll try...
Came into owning a 9UK with all standard boards and a DVI board installed in slot 1. We use an HDTV Tuner/DVD combo plugged into the component slot (Slot 3) and have no problems with signal or picture. 480i to 1080i all clear.
It's when I try to use the DVI board that I run into issues. I've never been able to get a signal from any device while using it. Originally I was going to hook up an Xbox 360/PS3 with a simple DVI/HMDI converter. This didn't work and I assumed it was just the age of the TV. Fast forward and i'm trying to hook up a desktop computer running an Nvidia 9600 GT with DVI output to the PC. Still no signal at all, despite numerous resolution and settings changes. I'll be grabbing a VGA and s-video cable tomorrow to see if the computer can hook up via any other input...and to use a second monitor to see if the computer recognizes the TV at all.
Is my DVI board broken? Do I need to re install it? Is there a certain configuration that I need to set up? Or will it simply not work and i'm over my head?
Thanks for your help.
philapo is offline
post #5057 of 5069 Old 01-09-2014, 09:42 AM
denyart's Avatar
If your video output is set to 1366 by 768 at 60 Hz you should be alright. One thing to make sure is whether the adapter is running in digital RGB or digital component mode. I have mine running in digital RGB mode and it works fine, but I am not sure if the DVI board supported digital component (YCbCr). It is possible that it does (and likely I would include) support digital component video, so if you cannot get an image and everything is connected and configured properly you either have a bad DVI board or bad cable or adapter. FWIW, I had a monoprice DVI to HDMI adapter that I got that never worked when it was brand new, so don't discount that your cable could be your issue unless you are using tested cables.
Win7Ult x64:P8Z77V Deluxe, 8GB DDR3, ATI 6670, i5-3570k, 3 Ceton InfiniTV4 PCIe, Hauppauge 2250, Fractal Arc Midi SSP
denyart is offline
post #5058 of 5069 Old 01-11-2014, 06:35 AM
RIT
RIT's Avatar
Wow, this thread is still active. Panny is still running strong!
Home theater on a budget.
RIT is offline
post #5059 of 5069 Old 01-13-2014, 09:13 PM
mckennwa's Avatar
Has anyone recently upgraded from their 9UK to a new Panasonic Plasma? If so, did you notice an increase in picture quality or anything? I am looking at upgrading my 50" 9uk which is still going strong to pick up a 65VT60 before Panasonic stops selling plasmas all together.
mckennwa is offline
post #5060 of 5069 Old 01-14-2014, 09:56 AM
dawgfan1606's Avatar
Yes, I just picked up a VT60 last month and moved the 9uk to the bedroom. YES, there is a HUGE difference in the picture, but the 9uk still looks awesome in the bedroom!
dawgfan1606 is offline
post #5061 of 5069 Old 01-14-2014, 12:34 PM
mckennwa's Avatar
Thanks for the feedback. My only concern is the brightness of the new VT60 as it will be going in my living room which has a few windows. The 9uk is in there now and does perfectly well. Did you feel that the VT60 was brighter than the 9uk?
mckennwa is offline
post #5062 of 5069 Old 01-14-2014, 12:53 PM
pdawg17's Avatar
Liked: 26
Similar situation for me. Had a 9uk in the family room where there are several shuttered windows behind me and an uncovered slider door on the left. Now I have a vt60 and it is MUCH easier to watch during the day now. Reflections are minimum and my eyes are much more relaxed. Brightness seems great to me although I am used to a "calibrated" plasma anyway. Very happy and although I love my 9uk the vt60 is a huge upgrade imo.
Sent from my Nexus 4 using Tapatalk
pdawg17 is offline
post #5063 of 5069 Old 04-28-2014, 03:28 PM
wildgoose's Avatar
I am thinking about buying a used TH-50PH9UK locally from craigslist.
Can anyone tell me how to find out how long the panel has been used or powered on for this model? I found some instructions/videos but they appears to be for the consumer models and I am not sure if the professional series have the same access code or menu structure.
wildgoose is offline
post #5064 of 5069 Old 04-28-2014, 04:07 PM
baniels's Avatar
Quoted: 86 Post(s)
Liked: 108
Funny. I was searching this thread for an answer, and finally found myself answering the question from 7 years ago. Answer quoted below.
Originally Posted by baniels View Post
Hold the "volume down" button under the screen - continue to hold it while you press the status button (the one that normally shows you which TV input is in use) 3 times. make sure the remote is pointing at the IR receiver on the TV.
Menu will appear on the top right section of the screen - you can let go of the volume button now. Move to SD and select. I can't remember the names, but the number on the left is the on/off cycles and the number on the right is the hours of use.
DON'T CHANGE ANY SETTINGS UNLESS YOU KNOW WHAT YOU ARE DOING.
Originally Posted by yllau View Post
Sorry if it has been asked here before. How do I get the total on time (the number of hours TV is on) from the menu? Thanks.
baniels is offline
post #5065 of 5069 Old 06-12-2014, 11:00 AM
Liked: 0
Originally Posted by phussey View Post
Quote: Originally Posted by phussey
My Panny has started to exhibit this weird green haze every 30 mins or so. It does it on satellite and bluray. The green haze just appears, covers most of the screen, although it doesnt cover the whole screen , just parts of the image, and then goes away. It looks like maybe interference but I've checked all my leads etc Anyone have any ideas ?
I need to change the description of this malady. It is not really a haze as such. I would say more like scattered green snow. It rolls across the picture for 10 seconds then is gone for another 30 mins.
Did you ever find a fix for this? My trusted 9uk is starting to have this happen. Bought in 11/2006. Love the tv but wondering if its starting to go.
Anyone with any advice, please let me know.
tkuhe is offline
post #5066 of 5069 Old 01-02-2015, 05:25 PM
renlopez's Avatar
Mine is 8 years old. A few months back, the screen started flickering and it would get progressively worse for about 5-10 minutes before going completely black. After turning the panel off for a while the picture would come back on but then start happening again. Doesn't matter what input it's on, they all behave this way now.
Possibly the fan is not working and it starts to flicker from overheating. Anyone have any suggestions? Is it time to sell it for parts (HDMI Card)?
renlopez is offline
post #5067 of 5069 Old 01-02-2015, 05:45 PM
jw1
jw1's Avatar
Anyone have a solution for red snow?
jw1 is offline
post #5068 of 5069 Old 05-19-2015, 02:07 AM
Liked: 1
Does anyone own a TH-50PH9UK?
I purchased one for $25.00, not a thing wrong with it except no remote. Beautiful!
KC7EGF is offline
post #5069 of 5069 Old 05-19-2015, 04:44 AM
Bruce2019's Avatar
Quoted: 305 Post(s)
Liked: 173
Red snow in the blacks?
Yes, lower the R-cut value in service menu
Bruce2019 is offline
Panasonic Th 50ph9uk 50 Plasma Display
