The OFFICIAL Panasonic 9UK Owner's Thread - Page 170 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #5071 of 5075 Old 08-29-2016, 06:30 PM
TopShelf17's Avatar
Originally Posted by KC7EGF View Post
Does anyone own a TH-50PH9UK?
I purchased one for $25.00, not a thing wrong with it except no remote. Beautiful!
You got a steal.
I am selling mine now but want more than $25 for it.
TopShelf17 is offline
post #5072 of 5075 Old 08-29-2016, 06:40 PM
Techniwizard's Avatar
Cool Series 9UK
Originally Posted by TopShelf17 View Post
You got a steal.
The original remote for that model is
EUR7636070R
Panasonic no longer has these but eBay will have them once in awhile.
Techniwizard posts as an Independent Servicer
Techniwizard is offline
post #5073 of 5075 Old 12-02-2016, 01:43 PM
Liked: 0
I got a chance to pickup a TH-PF9UK for $100 on craigslist - should I go for it?
It does have a remote - it does not have a stand. So mounting this could be a pain.
Common problems and what kind of lifespan can I expect with this thing?
I plan to check the on/off cycles and the total hours
kawasakiguy37 is offline
post #5074 of 5075 Old 12-03-2016, 06:33 PM
meli's Avatar
Quoted: 184 Post(s)
Liked: 42
I don't think I'd do it. These sets are pretty old now, regardless of how many hours it's been turned on. Mine died after about 7 years. Not a terrible lifespan, but I'm the type of person who only turns on the TV when watching a movie. I never have the TV on as background noise. So I probably logged around 15 hours per week, less than 6,000 hours after 7 years.
When my Panny died, I bought a larger Samsung plasma for $500. I think the blacks were slightly better on my Panny (especially when it was new), but otherwise the Samsung has a as good as, or better, picture.
The biggest difference was the weight. Being accustomed to the weight of my 42-inch 2006 plasma, I couldn't believe how much lighter my 51-inch 2013 plasma was. To hang the old 42-inch plasma required 2 people because of the weight. I hung the 51-inch plasma easily by myself.
meli is offline
post #5075 of 5075 Old 01-06-2017, 11:02 PM
GnatGoSplat's Avatar
Quoted: 13 Post(s)
I wanted a smart TV in a spare bedroom. Nothing fancy, I really just want Youtube app, Plex, Crackle, etc. Stuff that comes on a typical smart TV. Then I had the big idea to repurpose my old TH-50PH9UK which has not been used for over a year now, converting it to a smart TV seemed like the more economical choice considering they're apparently only worth $25 on CL. So I picked up a Roku Premiere for $20 which I just got today. I have an HDMI2HDMI+Audio box coming to take care of the sound part of things, but thought I'd test it out by connecting it to the PH9UK using an HDMI to DVI-D adapter (my PH9UK has the TY-42TM6D DVI board in it). Well, this didn't work. The Roku boot screen shows up, but with a pink background and it kept bootlooping (Roku boot screen is supposed to have a black background). I assumed it was trying to autodetect the TV and failing, causing the bootloop, so I plugged it into an old 2009 Sony 1080p LCD and that worked. I got through setup and made sure it's 720p, a resolution the PH9UK should support. Plugged it back into the PH9UK and boot screen still pink, and when it gets to the home screen, it's just solid pink with nothing visible. To test the HDMI-to-DVI adapter, I plugged it into a PC monitor and that worked fine. The Roku detects both the PC monitor and Sony TV as supporting HDCP 1.4. According to Google, the TY-42TM6D only supports HDCP 1.1. Is this pink screen an HDCP issue? Can I get this Roku to work on the PH9UK if I buy one of those $12 HDCP stripping splitter boxes?
UPDATE: Was not an HDCP issue. I got one of those splitters that strips HDCP and it didn't make any difference. TH-50PH9UK w/TY-42TM6D is simply not compatible with Roku Premiere. Roku Streaming Stick works just fine with it, using HDMI2HDMI+Audio box to get sound out of the Roku.
Shawn
GnatGoSplat is offline
Panasonic Th 50ph9uk 50 Plasma Display
