Panasonic TH-37PX60U Input Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-13-2006, 04:06 PM - Thread Starter
Sirluckyj's Avatar
I purchased this PDP for a retired priest friend of mine. It will be delivered Thursday. Since there is only one RF input, is there a way to input cable and OTA at the same time? I read the manual and it shows that you must, via the setup menu, designate whether you are inputing cable or OTA. I want to keep this as simple as I can for the Monsignor. Thanks.
Jim
Sirluckyj is offline
post #2 of 2 Old 08-13-2006, 04:16 PM
martyj19's Avatar
Unfortunately, cable and OTA frequencies overlap, so cannot be used at the same time. This is the reason for the restriction. One common workaround is to use a VCR as a tuner and go into another input.
martyj19 is offline
Closed Thread Plasma Flat Panel Displays
