Need Help Panasonic Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-14-2006, 08:14 PM - Thread Starter
Jamie571's Avatar
I purchased a TH-42PD25 42" Panasonic plasma TV a little over 2 years ago. Everything been great until today.
I have just analog cable plugged into ANT A input. I get sound but no picture, the menu still works and the display header comes up, but blackness.
I tried component input 1 which is connected to a DVD player. The picture comes up just fine with the DVD in progressive 480p or 1080i mode, but as soon as I select 480i mode the picture goes black just like the input on ANT A.
So I put the DVD in 480p mode and then select split screen tuner and the input on ANT A works fine then I turn off the DVD player and the picture goes black again.
I usually have solutions for problems like this, but I'm at a loss this time.
Any help will be greatly appreciated.
Jamie571 is offline
Closed Thread Plasma Flat Panel Displays
