50 inch HD Plasma TV w speakers and cable card? Recommendations please? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-15-2006, 08:28 AM - Thread Starter
chris7469's Avatar
I am in the market for a 50 inch HD Plasma TV with a cablecard slot.
Which ones offer the best overall value?
Thanks. CM
chris7469 is offline
post #2 of 3 Old 08-15-2006, 08:44 AM
optivity's Avatar
In the $4K range, either the Pioneer PDP-5070HD or the Panasonic TH-50PX600U. If you can go up about $1K - $2K in price you might consider the Pioneer PRO-1130HD "Elite" PDP or you could get a HUGE 58" Panasonic TH-58PX600U
optivity is offline
post #3 of 3 Old 08-15-2006, 03:38 PM
dtrell's Avatar
optivity, he asked for OVERALL value. in that case id go with the 5070 or the 50px600u. both about the same price. all in whether you like the panny or the pio picture better.
dtrell is offline
Closed Thread Plasma Flat Panel Displays
