MX-5020HPM Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Old 10-18-2007, 03:23 AM
billt1111's Avatar
how did you get to the service menu?
bill
billt1111 is offline
Old 10-18-2007, 09:11 AM
Oh2Smooth's Avatar
Read up a little bit in the thread.
Oh2Smooth is offline
Old 12-24-2007, 04:12 AM
randym431's Avatar
ANyone have a hdmi issue when using a hdmi switch with this set?
I've tried several hdmi switches, to add more hdmi inputs, and have not as yet found a switcher that works. I get "no signal" using a hdmi switcher with either of the tv's hdmi inputs. Especially have had no luck with a dish 622 hd dvr, a hdmi switcher, and this plasma. Seems only direct hdmi source to tv hdmi 1 or 2 will produce a signal. Putting a switch in between... "no signal", using the dish 622. This is really strange. I guess adding a hdmi switcher for more hdmi inputs is out.
randym431 is offline
Old 12-24-2007, 10:03 AM
NiteWrider's Avatar
I'm using a 1st generation monoprice.com hdmi switcher with this tv successfully.
Input 1: satellite box
Input 2: hdmi switcher (PS3, DVD, PC)
Sometimes this tv has trouble with handshake when equipments to input 1 & 2 are both on. In this case, I just turn off one of them.
Good luck.
NiteWrider is offline
Old 01-09-2008, 07:01 PM
randym431's Avatar
What do youu mean 1st generation? I think my switch said 2.4.
And what on turning off one of the hdmi ports? You mean nothing plugged into it? Or is there a way to actually turn these off?
ps,
I know this will probably be a useless attempt, but just wondering if anyone else has hdmi issues or if Im doing something wrong.
I just added a blu-ray player to my maxent MX-5020HPM, using hdmi, and the tv shows it as DVI connection. And no audio is coming thru. I also have this same thing connecting a dlink media lounge dsm520. And the weird thing is the dsm520 "was" displaying as a hdmi connection before.
Its like the tv hdmi has been reset to dvi.
But my dish hd dvr, using hdmi also, always lists as a hdmi connection
with audio.
I know its not the hdmi port itself since I swaped connections and all work.
And the blu-ray is setup as it should be as far as output connection and audio settings.
Its like the tv has defaulted into some dvi mode on some devices.
I also got new hdmi cables ver 1.3 thinking it was that. No change.
Anyone?
Old 06-17-2009, 11:33 PM
littlechou's Avatar
having issue with HDMI on my PS3 recently. It stopped work on HDMI port 2 a year ago and it stopped working on port 1 yesterday as well. There is just a blank screen... i have powered off both my TV and PS3, even format my PS3, but still no output on HDMI. PS3 works with HDMI to DVI on my monitor, and my TV works with HDMI of my DVD player. So both TV and PS3 are fine, somehow they just don't talk to each other. Any idea?
littlechou is offline
Old 06-18-2009, 07:06 AM
braclark's Avatar
I actually had a similar problem with mine except with my computer. Tested the computer with another monitor and the Maxent with the HD cable box, and both work fine, but I can't get the DVI out from the computer to work with the Maxent. I haven't been able to fix it, so I'm using the analog monitor out.
braclark is offline
Old 10-14-2010, 07:18 AM
Combatsylvania's Avatar
Sorry to revive an old thread... I been lookin all over the web for parts for this TV.. I recently got one for a bargain (read: free) because it was acting up.. There is a warped or cold solder joint on one of chips on the main board.. I am able to watch the TV, occasionally i have to tap the chip to bring the picture back...
My options are to take the board out, and take it somewhere to be reworked (solder reflow on the chip) or by a replacement board.... or both..
I would like to get another board just incase the reflow kills this board...
any ideas?
PS: one caveat is, i live in Canada.. the one board I found on eBay, the seller will not ship outside of the US.
Combatsylvania is offline
