Official Pioneer PDP-6070HD/5070-1HD/4270HD Owner's thread/merged thread - Page 251 - AVS Forum | Home Theater Discussions And Reviews
post #7501 of 7518 Old 02-21-2011, 07:00 AM
nornet's Avatar
Originally Posted by SilverCi View Post
hey guys. All of the sudden this morning, my TV that has been rock solid "blinked" and now the entire screen looks white washed EVEN WHEN ITS UNPLUGGED!
The picture now looks awful... there is nothing I can do. Has anyone seen this before?
thanks,
Jim
I assume you have tried to reset the unit by disconnecting the power. Also search this thread for reset.
nornet is offline
post #7502 of 7518 Old 03-27-2011, 02:27 PM
hkrause's Avatar
We have a PDP-5070 receiving OTA signal via antenna in the attic. Reception has been great, and we get all local channels in HD. One channel has started to "pixelate" frequently, as though we're not getting a good signal. It scrambles the picture for several seconds several times a minute.
Checking signal strenth shows arounf 69-71, which is actually better than several other channels, which are displaying perfectly. We're tried reorienting the antenna with no luck. Also re-scanned the channels with good signal strength on the problem channel. We've had the same system configuration for years and no problems previously.
Any troubleshooting steps we can take? Since it's only one channel, is it possible there's a problem with the tuner? For reference, this is on channel 5.1 (CBS) in the Kansas City area. Other channels (4.1, 9.1, etc) are fine.
Heather
hkrause is offline
post #7503 of 7518 Old 03-27-2011, 02:34 PM
Quoted: 1392 Post(s)
Liked: 587
More than likely, its a problem with the TV station that's transmitting.
If it was the TV, you'd see it on all channels.
JimP is offline
post #7504 of 7518 Old 06-21-2011, 01:28 PM
Angel L.'s Avatar
Comments welcome
My 6070HD is displaying fast motion loss of sharpness on the edges on both D* and DVD/BLURAY.
I wonder if this is because its getting old and the electronics cant keep up with new display algorithms. Noticeably getting worse on the ESPN and other motion tickers on the bottom of the display.
Can PDP's go bad with time?
If not for this issue my panel is still awesome and has been trouble free since purchase.
Angel L. is offline
post #7505 of 7518 Old 06-21-2011, 06:11 PM
Liked: 587
Angel,
I haven't experienced that on my 6070....yet.
I guess the first step is to try to get it repaired. It might be something fairly simple.
I've been very pleased with my 6070. Its a bit over 4 years old but I probably have double the amount of normal usage on it.
JimP is offline
post #7506 of 7518 Old 07-15-2011, 05:29 PM
Marky_Mark896's Avatar
My 6070 is as good as new...knock on wood. Purchased 11/06. Soon to be 5 years old. Maybe you just have to leave it on all the time. Mine is on almost 24/7 literally.
Edit: Just checked my hour meter: 28,852 hours on since 11/06. That worked out to about 3 1/4 years of use in 4 1/2 years of ownership. Granted, it sits unwatched with a static website on it alot of the time, or no one watching it but asleep in front of it. No burn-in, no dimming. I don't know what I'd buy to replace it if I ever need to.
It's not just a hobby, it's an obsession...
Marky_Mark896 is offline
post #7507 of 7518 Old 10-09-2011, 05:20 PM
bobbyTO's Avatar
I can't seem to get an optimum image on my PDP6070HD when I switch to the "FULL" aspect option. The images and graphics seem to be cut off at the bottom at the top and the bottom.
The only change that I did do is to switch my main input on TV to Input 5 from Input 2 and since I bought a new receiver and Blueray, replaced the component cables to HDMI.
Would really appreciate if somebody can help me out..Thanks.
bobbyTO is offline
post #7508 of 7518 Old 10-09-2011, 06:48 PM
Liked: 587
Bobby,
Check to be sure that your satellite box, cable box or new receiver to be sure that they're not stretching the image.
JimP is offline
post #7509 of 7518 Old 10-10-2011, 12:41 PM
bobbyTO's Avatar
That worked, it was the Satellite Box that changed to a Default Mode!
Many Thanks Jim
bobbyTO is offline
post #7510 of 7518 Old 10-18-2011, 01:32 PM
thedo's Avatar
Heather
Call Pioneer up and ask for a tech to come out to update your TV's firmware. I have the same issue and the firmware update fixes the problem for good. This update cannot be done by enduser since the tech has a PCMCIA card to do it. It cannot be done by USB. Good luck
thedo is offline
post #7511 of 7518 Old 09-17-2013, 04:19 PM
greytheo's Avatar
My parents have a Pioneer 4271 and recently they have been unable to change channels. The controller appears to work fine with switching inputs and adjusting the volume. What's stranger still is that when I go into split-screen or PIP I can change channels fine. Anyone run into a similar issue?
greytheo is offline
post #7512 of 7518 Old 09-17-2013, 08:57 PM
Liked: 587
See if any of the buttons on the side of the display are stuck in the detent position and if so, try to wiggle them loose.
Got to visiti my old 6070 that I sold to some friends last year.
Darn picture look great. Wish I had It back.
JimP is offline
post #7513 of 7518 Old 09-18-2013, 03:56 PM
greytheo's Avatar
I checked the channel buttons on the display and they were not stuck and function just as the controller channel buttons function. On further examination, the TV Guide button causes the screen to go black with NO interruption to the audio. The only way to get the image back was to turn the tv off and then on again. The INFO button didn't do anything either. I remember reading that the TV Guide software causes various problems with these Pioneer plasmas. Maybe changing channels invokes the TV Guide software, and if that software has crashed then one couldn't change channels. Any solutions to the TV Guide problem?
greytheo is offline
post #7514 of 7518 Old 09-18-2013, 10:32 PM
greytheo's Avatar
SOLVED: I unplugged and replugged the tv and that reset the TV GUIDE feature. Now I am able to change channels and check the non-existent TV GUIDE features. I would love to uninstall the TV GUIDE: anyone know how to do this?
greytheo is offline
post #7515 of 7518 Old 06-13-2015, 07:21 PM
Liked: 0
Originally Posted by jfleming View Post
I was trying to access the Home Menu to adjust some settings on my Pioneer PDP-5070HD today and was unable to get the menu to appear. When I click on the Home Menu (or even Menu) button on the remote with the TV on, nothing happens. The little red light at the top of the remote doesn't even light up. In fact, the only buttons on the remote that do seem to work are the power button, input selecters, the row of buttons just below the input selecters, the channel selecters and channel/volume up/down buttons.
I have tried 3 different sets of batteries and had the same result with each. Is there something I am missing? I have a universal remote and usually do not touch the TVs native remote, but I know I was able to access the home menu before. Is there any other way to access the Home Menu other than the TVs native remote?
Any help would be greatly appreciated. Thanks.
John
John: having the same problem now on my PDP 5070DH also. Can't get the home menu button to work to resent the screen option for the cable box. Did you find a fix for your problem? Would also appreciate any help. Thank you Jeff
jjans is offline
post #7516 of 7518 Old 09-25-2015, 01:50 AM
Bryan_CoxPHX's Avatar
Quoted: 112 Post(s)
Liked: 52
Is there anyone hosting firmware updates for these CableCARD Pioneer TVs?
I cannot find anything using Google or the Pioneer Support site.
I searched this thread and found the following, I doubt Pioneer still supports a tech coming out, any other way?
TiVo Bolt, Roamio Pro, Premiere XL4, Premiere 2TB-WD20EURS, TiVo Mini
Cisco Tuning Adapter Status Troubleshooting
Bryan_CoxPHX is offline
post #7517 of 7518 Old 02-26-2016, 04:53 PM
vurbano's Avatar
PDP-5070HD buzz
does anyone have the PDP-5070HD service manual? I friend has one and it has developed a loud buzz that I think is fan noise. looking for specs on the fan for replacement and disassembly instructs. I guess the power supply has one a well?
vurbano is offline
post #7518 of 7518 Old 02-27-2016, 08:05 AM
mczolton's Avatar
I sent you a PM. It's the service manual for the PDP-5070PU. Not sure how closely that matches the 5070HD, but maybe it will be helpful.
mczolton is offline
