need recommendation on ceiling mounts for two (2) Panasonic TH-42PX60U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-28-2006, 12:23 PM - Thread Starter
ojready's Avatar
These will be over a bar. It looks like peerless and other companies sell the ceiling mount and the bracket separately. Is there an all in one ceiling mount/bracket? The cheaper the better, of course. Thanks a lot. Any specific companies I should look into that specializes in ceiling mounts? Anyone have any suggestions?
ojready is offline
post #2 of 2 Old 01-14-2007, 06:40 PM
hacker-pschorr's Avatar
Location: I can see Lambeau Field from my bedroom window
Bump
I'm looking for the same thing to use with a Samsung HPS4253
I'm helping my parents build a new home theatre - they have a "cubby hole" a projection TV was mounted in. Option 1 is to install a shelf to put the plasma on, the screen will be the same height as the old projection.
It would look very cool if the new Samsung plasma were mounted on the ceiling of this cubby hole, on a mount that swung down to place the panel in the same location as the previous screen.
Concert discs are the bread and butter of HD ownership.
hacker-pschorr is offline
