Direct Sunlight bad for Plasma TV's?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-29-2006, 10:35 AM - Thread Starter
r3zon8's Avatar
i bought a panny 50px60u over the summer based solely on of the readings i did here on this forum and id like to thank everyone for their help. its by far one of the best purchases ive ever made and im a panasonic customer for life. some of my friends have plasmas as well, and everytime they come over i hear this.."how come my plasma doesnt look this good?"...and i just smile.
my question is, during them morning hours the tv gets about 3 hours of direct sunlight from the large window to the right of it
Is this something i should worry about? Does sunlight hurt the plasma at all, or only when its turned on/off? should i get a cover for it, or some vertical blinds for that window?
thanks again everyone.
r3zon8 is offline
post #2 of 6 Old 11-29-2006, 11:30 AM - Thread Starter
r3zon8's Avatar
also, its only about half the screen that gets the sulight on it, not the entire unit.
r3zon8 is offline
post #3 of 6 Old 11-29-2006, 11:57 AM
Elemental1's Avatar
You should NEVER let direct sunlight hit any electronics. :eek:
My HT
In the words of English philosopher Edmund Burke, ÂAll that is necessary for the triumph of evil is that good men do nothing.Â
Elemental1 is offline
post #4 of 6 Old 11-29-2006, 12:29 PM
CruelInventions's Avatar
Quoted: 459 Post(s)
Liked: 593
aren't you being just a tad alarmist?? I'm not sure how sunlight hitting the outer panel surfaces can damage internal components. Certainly, the sun is notorious for fading surfaces over time and it might warrant guarding against that, or at least, be on the lookout for any evidence of that (small piece of non-light transmitting tape placed inconspicuously on panel side or back, which can be peeled off after some time in order to determine if any fading has taken place). But beyond that, unless the sunlight is seeping in through some air ducts and directly pounding on the inner electronics, I fail to see how this could be a problem for him.
I don't speak with any knowing authority, so I would welcome any supporting info, pro or con.
CruelInventions is offline
post #5 of 6 Old 11-29-2006, 12:32 PM
miniz's Avatar
Tint your windows or put up a shade. I would not allow direct unfiltered sunlight to contact it. Besides, what is good a TV that you can't watch for 3 hours a day because it is so yellow washed from the sun that you can't even see it?
miniz is offline
post #6 of 6 Old 11-30-2006, 05:43 AM
robert123's Avatar
robert123 is offline
Closed Thread Plasma Flat Panel Displays
