Gamecube image shifted on Panasonic Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-29-2006, 11:34 AM - Thread Starter
erickotz's Avatar
Liked: 30
I just picked up a Panasonic 42" HDTV Plasma, and for some reason, the image is shifted to the right on my plasma (it almost looks like the gamecube is feeding 16x9, but the image spans from about the left 4x3 border to the right edge)
The Gamecube is being fed right into the plasma using _COMPONENT_ cables. No switcher/anything in between. I've yet to try the composite cables. The problem appears unchanged in both 480i and 480p mode. The same GameCube had no problem driving my Infocus X1 projector previously with the component cables.
Any ideas?
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #2 of 6 Old 11-29-2006, 11:35 AM
paddlefoot's Avatar
Any ideas?
Check with people on the Nintendo HT gaming forum
paddlefoot is offline
post #3 of 6 Old 11-29-2006, 12:54 PM
maharg18's Avatar
If I recall, you can start up the Gamecube without a disc inserted, and get into a configuration menu that allows you to shift the image as needed until it looks good on your screen.
maharg18 is offline
post #4 of 6 Old 11-29-2006, 01:02 PM
Elemental1's Avatar
Nintendo removed the digital output on all new GC's. What are they thinking?
My daughter plays on my Panasonic and it actually looks ok with composite.
My HT
In the words of English philosopher Edmund Burke, ÂAll that is necessary for the triumph of evil is that good men do nothing.Â
Elemental1 is offline
post #5 of 6 Old 11-29-2006, 01:42 PM - Thread Starter
erickotz's Avatar
Liked: 30
Hmm, I shall have to look in the Gamecube options and see if there's anything there.
Regarding the digital out being removed. last I knew, if you called Nintendo's customer service line saying you had the cables and couldn't plug them in your Gamecube, they would swap your GC with another one that does have the "Digital Out"
There was no charge for this, but I think I had to pay shipping to them.
erickotz is offline
post #6 of 6 Old 11-29-2006, 01:42 PM
Tarzanman's Avatar
They were probably looking for a way to cut costs on unit production
Tarzanman is offline
Closed Thread Plasma Flat Panel Displays
