Panasonic Plasma - Display Current Input Resolution? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-29-2006, 04:57 PM - Thread Starter
freestyle's Avatar
I've searched for this, but am GUESSING that maybe it is a service menu trick? Or doesn't exist.
Is there an easy way for me to get my Panasonic TH-50PH8UK to give me a text display of the current input signal resolution it is receiving? I used to be able to do this on my old Sony, but haven't found a way on this unit.
This is obviously useful for determining if your devices are sending the signals they are supposed to be sending. (I question whether I'm getting 480p every once in a while).
Thanks for any info, or links to resources!
PSN ID: free
Gamertag: X freestyle X
freestyle is offline
post #2 of 7 Old 11-29-2006, 05:25 PM
orogogus's Avatar
so far as I know, it isn't possible, or at least isn't documented anywhere that I've seen.
however, I ususally can infer something about the signal by what zoom modes are allowed- ie you can't zoom HD content, you can only see 'full' no option for 'just' or 'zoom'.
I agree it would be nice to know what the TV thinks it is getting via a particular input.
I have a 7UY for what it's worth...
orogogus is offline
post #3 of 7 Old 11-29-2006, 05:31 PM
JagNL's Avatar
Hit the "Recall" button (It's next to the Favorite Button), it will desiplay what mode you are in (Full, Just, 4:3 etc...) as well as what signal it is receiving (480p or I, 720P or i or 1080I etc...)
Oh, for reference I have a Panasonic TH-42PX60U.
Let me know if that works for you!
-Best Regards,
Todd
JagNL is offline
post #4 of 7 Old 11-29-2006, 05:58 PM
DeltaOne's Avatar
You're right, the recall button will provide all that information. But...my STB (Motorola 6412) is locked on 1080i, so the TV always thinks it's getting 1080i, even on SD channels. So it'll depend on how the other poster has his STB configured.
It's been awhile since I configured the 6412, but I don't think it has a pass-through option like some of the STBs. You have to choose a set resolution. I couldn't see any difference between 780i and 1080i so I left it set for 1080i.
DeltaOne is offline
post #5 of 7 Old 11-30-2006, 03:24 PM - Thread Starter
freestyle's Avatar
I don't know... I've tried every button on the remote...
What I get is:
Component 3
FULL
No resolution to be found anywhere. :(
PSN ID: free
post #6 of 7 Old 11-30-2006, 04:27 PM
ressom's Avatar
Per bruzziforum.com:
How can I check what resolution is being fed on Commercial Models ?
..Hold Down the " VOLUME (-) " Button ON THE PLASMA DISPLAY.
..Press the Status Button (The one above Set Up Button) 3 times on the Remote.
..The Computer Aided Test menu (Service Menu) appears on.
..Using the cursors keys on the remote select " IIC " Mode.
..And press the action button ( ) to access the menu.
..The resolution* will be displayed on the top left side.
..To exit, press the Return (R) button.
..To exit the Service Menu, use the status button.
..Press the power button on the Plasma to exit the Service Mode.
* What kind of resolution is 525p ?
NTSC signals have 525 lines of information but only 480 are active for video information.
Some manufacturers choose to label the full signal 525 i/p instead of 480i/p .
The same applies to 750 (720p) & 1125 (1080i) HD Signals.
http://www.bruzziforum.com/vbf/showthread.php?t=5
ressom is offline
post #7 of 7 Old 11-30-2006, 05:02 PM - Thread Starter
freestyle's Avatar
Nice... Thanks you ressom... I'll test this out as soon as I get home!
PSN ID: free
Closed Thread Plasma Flat Panel Displays
