Plasma | In-Wall Surge Protection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-30-2006, 07:59 PM - Thread Starter
Stinky Pinky's Avatar
I just want to go on record saying how much the search on this forum sucks... completely useless. I know this because I've read countless threads over the last two years talking about hospital-grade surge protection outlets being used in home theater setups, but now I can't find a single thread using the search feature.
So, I just picked up the Leviton 8280 with isolated ground for use above my fireplace where my plasma will plug in. Here's the stats on it:
Maximum continous operating voltage: 150V
Maximum single-pulse transient current (8 X 20 ms Amps peak) 24,000A (L-N), 12,000A (L-G), 12,000 (N-G)
Rated single pulse transient energy (10 x 1000ms, impulse) 320 joules
Is this going to accomplish what I need it to do? I really don't want one of those nasty surge strips hanging off the back of my plasma and I figure if it's good enough for hospitals then it's good enough for my baby. Am I off the reservation on this one?
SP
Stinky Pinky is offline
post #2 of 3 Old 12-01-2006, 08:26 AM
HFXguy's Avatar
It will work fine but you could have bought a Leviton 5280 as hospital grade does not give you anything extra. The thing about receptacles is they have a low joule rating. A half decent power bar rating is approx. 2000-3500joules.
The best way is a service entrance surge suppressor unit (at the house panel) which will protect the whole house from a surge from outside plus a receptacle or power bar which will help protect from any surges generated from within your house.
HFXguy is offline
post #3 of 3 Old 12-01-2006, 09:30 AM
Kr8z1's Avatar
I found several posts by searching this way:
+hospital +surge
If you go Advanced Search, then click on Advanced Search Help it will tell you how to search with better results
Kr8z1 is offline
Closed Thread Plasma Flat Panel Displays
