Official Pioneer 5070/71 Flashing Blue Light Shut-Down Thread - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #751 of 779 Old 03-19-2016, 05:25 PM
Liked: 0
I di all this and now have no Picture! Any ideas why?
Dr4kds is offline
post #752 of 779 Old 03-19-2016, 05:28 PM
Liked: 0
Exclamation No Picture
I did all the steps and now have no picture!
Any ideas?
Dr4kds is offline
post #753 of 779 Old 04-22-2016, 06:25 PM
Rod#S's Avatar
Quoted: 386 Post(s)
Liked: 55
My Kuro starting exhibiting some disturbing behaviour today out of the blue and I was wondering if anyone has encountered something similar before. It's unplugged right now but when I get it up and running again, if the problem returns which I suspect it will I'll count the number of flashes and if it's 12 I'll see if I can do the system restore that I read about in this thread. My model is the PRO-150FD though, form 2008 and I don't really see much mention of this model in this thread. Unless I skimmed over it I don't think I came across a situation exactly like mine.
So here's my situation and story.
After I got home and powered up the system all seemed well. I was busy doing stuff for a while and when I came back to the tv I noticed there was no picture, a completely black screen and the blue power LED was blinking. I hard power cycled the tv and the picture came back and all seemed well. Sometime after the issue happened again. I cycled through the HDMI inputs but the picture was black on all inputs. I even checked my composite input, same thing. Like the 1st time the blue LED was flashing. I hard power cycled it again and the picture was back.
It happened a 3rd time, this time I powered it down and changed power cables. It powered up normally. The problem returned. This time instead of hard power cycling the unit I simply hit the standby button and the picture came back and the LED went back to the proper solid blue from flashing. It was interesting that hitting the standby button didn't turn the LED red and put the tv into standby mode. Instead it acted more like a reset for whatever was going on.
The problem continues, at 1st I thought roughly every 30 to 45 minutes but it's more like between 20 and 30. Going in behind the tv the mid to upper left side seems quite warm but of course these TV's get warm anyways so I'm not sure if what I'm feeling is elevated heat or not. Could be just paranoia.
I've now got the tv unplugged, it's been over an hour, I'll plug it back in shortly to see if anything has changed. I suspect it'll continue to do the same thing.
I've checked my power options and standby options and everything is disabled so it 's not one of those features kicking in.
In reading the manual it indicates a flashing power or standby light can indicate the protective circuits activating which I have seen mentioned earlier in the thread.
Has anyone experienced my exact situation?
Rod#S is offline
post #754 of 779 Old 04-22-2016, 07:35 PM
Rod#S's Avatar
Quoted: 386 Post(s)
Liked: 55
So after 35 minutes the screen shut off and there is 12 flashes of the blue LED followed by about 2 or 3 seconds with no light then it repeats. I had a coax plugged in which only had a feed of my apartment building's lobby camera so I unplugged that before I plugged the tv back in and powered it up just in case that had somehow started causing the issue.
I wanted to ask before I try the reset will this blow away my locked ISF calibration settings? If so I'll have to dig around to see if I can find the ControlCal files that were saved at the time of calibration.
Rod#S is offline
post #755 of 779 Old 04-22-2016, 07:47 PM
Rod#S's Avatar
Quoted: 386 Post(s)
Liked: 55
It just occurred to me, are the instructions to do the reset earlier in the thread applicable for the Elite models like my PRO-150FD? I'm was thinking they may not work at all, there could be a completely different set of steps to accomplish this.
Rod#S is offline
post #756 of 779 Old 04-23-2016, 12:42 PM
Jed1's Avatar
Quoted: 114 Post(s)
Liked: 59
The 12 flashing blue lights is a problem with the digital tuner which is the main assembly board. All inputs on the TV are connected to the main board so if you are not getting video and audio on any input then the board may need to be replaced. One of the issues that would cause the 12 blue lights on the 8G models would have been the TV Guide On Screen feature so if that is activated you can go into the TV Guide setup and enter all zeros for the zip code. But most likely the main board is going out.
Fro your TV it will be $785 for the part.
http://parts.pioneerelectronics.com/...elNum=PRO150FD
"You lose it in here you're in a world of hurt"
Jed1 is online now
post #757 of 779 Old 04-23-2016, 12:53 PM
Rod#S's Avatar
Quoted: 386 Post(s)
Liked: 55
Thanks for the response and link to the parts page. I'm surprised there are still so many parts available.
So far so good after the factory reset. The tv has been up and running correctly all day so far. I'm hoping that was all that was needed. Fingers very tightly crossed.
Rod#S is offline
post #758 of 779 Old 04-23-2016, 02:17 PM
Jed1's Avatar
Quoted: 114 Post(s)
Liked: 59
No problem! If your TV has the TV Guide feature it was that what was causing your issue. Mine got to the point where it would restart and never get past the TV is starting up screen so I could not even get to do the factory reset.
You main assembly board is much cheaper than the one for my 5010. Mine is currently around $1200. I paid $900 two years ago for one.
Jed1 is online now
post #759 of 779 Old 06-07-2016, 06:27 PM
timatraw's Avatar
Quoted: 24 Post(s)
Hey Rod#S,
Tim here with the same Kuro (150FD) and similar problem.
Is your Kuro still working ok?
timatraw is offline
post #760 of 779 Old 06-07-2016, 06:49 PM
Rod#S's Avatar
Quoted: 386 Post(s)
Liked: 55
Yep, so far so good. The factory reset did the trick.
Rod#S is offline
post #761 of 779 Old 06-07-2016, 06:55 PM
timatraw's Avatar
Quoted: 24 Post(s)
Rod#S
I can get to the "Final Setup Menu" but can't the "YES" to display- only the three dashes "---".
Do I go left or right?
How many times do I press to get to YES?
Do you remember?
timatraw is offline
post #762 of 779 Old 06-08-2016, 04:45 AM
timatraw's Avatar
Quoted: 24 Post(s)
Looking for help from anybody on how to do a successful factory reset.
I have a Pioneer Pro 150FD plasma tv with the blinking lights and am trying to do the factory reset
I can get to the "Final Setup Menu" for the reset on the tv but can't get the "YES" to display in the lower menu.
No matter how many times I press left or right-- "YES" never appears in the lower menu.
Is there something else I should be doing? Any suggestions?
timatraw is offline
post #763 of 779 Old 06-10-2016, 02:55 AM
Rod#S's Avatar
Quoted: 386 Post(s)
Liked: 55
It's odd that you can't navigate to confirm the reboot. I believe there may have been a couple different reboot procedures posted and it's possible there were slight differences between. I thought I had saved off the instructions I used but I can't seem to find anything so it looks like I didn't. Search back through the thread to find the postings of the instructions. There must be something simple that's being missed since you are almost complete.
Rod#S is offline
post #764 of 779 Old 08-07-2016, 12:10 PM
brentsg's Avatar
Quoted: 149 Post(s)
Liked: 276
Posting here as well as the owner's thread since both are nearly dead now.
I have been thru the TV Guide issue a couple of times and regained control. Yesterday the TV (5010) wouldn't get past the "turning on, please wait" message.
Today it boots and runs fine, except I no longer have video on the component inputs.. HDMI is fine. I've NEVER experienced any blinking light issues, oddly.
I'm going to go thru the reset procedure again, but posting in case someone else has encountered this.
brentsg is offline
post #765 of 779 Old 08-10-2016, 05:18 PM
Liked: 0
Hi, I have a Pioneer KRP600/M01 media receiver setup.
I started getting blue blinking LED error switching HDMI after the set had been on for an hour or so over the past two months. Unplugging the receiver for 5-10 mins from the mains solves the issue - I never unplug the TV. The issue started not long after I purchased cheap HDMI 1.4 cables which are in a very cramped space. The receiver has got the all clear from Pioneer service, they've asked me to bring in the TV. I'd rather avoid the hassle as the issue only arises on switching HDMI. In fact, I can access all menu's, Digital tv, satellite with no problems - so the issue must be some kind of HDMI related cause?
Any possibility the blue light shut down issue could be as simple as a communication error with these HDMI cables? Could this issue really be related to the main TV as the HDMI etc are all located in the receiver?
I have tried a new Display Port cable as well but no luck. Haven't tried a factory reset or different AV cables.
Many thanks in advance
liveswired is offline
post #766 of 779 Old 09-08-2016, 04:58 PM
Craif Baggio, MC's Avatar
Has anyone ever tried removing the CMOS battery from the mainboard and then putting it back in?
Without fail, my 5070 always comes back to life from blue blinking light syndrome, but only after being left entirely unplugged for 30 to 60 days. Evidently something happens with the faulty TV Guide software after that period of time. Some sort reset that allows it to work again until the power goes out once more. Then it's another 30 days of leaving it unplugged. Try to turn it on any sooner and the counter just resets.
I was thinking that removing the CMOS battery then replacing it it several seconds or a minute later might completely wipe the system settings or any sort of data that the TV stores and immediately return it to a working state-- if only until the main electrical power to the TV is lost again. Even if that works, I don't know how feasible it would be to leave the TV in a state where I would have access to the main board enough to quickly get at the CMOS a few times a year.
I've got my 5070 on a UPS battery backup that allows it to run for hours if the power goes out while the TV is in standby mode. If the power goes out while the TV is actually on then it will eat through the battery backup in 15 minutes or so while pulling the like, 600 watts or whatever this TV uses.
Time to move on to OLED I guess. Didn't care at all for the LCDs that became popular after plasma.
Craif Baggio, MC is offline
post #767 of 779 Old 09-24-2016, 09:21 AM
Rod#S's Avatar
Quoted: 386 Post(s)
Liked: 55
Does anyone know how to turn the fans on in a PRO-150FD? I noticed the tv is running very hot at the back and the fans aren't even engaged. I did a factory reset early in the year so I'm wondering if that broke whatever logic the tv would normally have to know when to engage the fans. I assume this is something that can be done in the service menu??
Rod#S is offline
post #768 of 779 Old 03-31-2017, 09:54 AM
Liked: 0
Hi folks,
Short time lurker, now member with a question and not sure if this is the correct place so kindly bear with me.
My PDP-6010FD has recently succumbed to the 8x and then 12x blinking blue light, no picture syndrome.
Did a few resets etc to no avail and took to a service depot for an estimate. Yikes!
Prognosis is it's the mainboard with 66k hrs on it. They want to refurbish the board at the component level in lieu of a $1,700 cnd board replacement. Still $1K to do a refurb.
Something I did not realize is the mainboard remains energized because of the tuner even though the panel is in standby, hence the high hrs.
What I find disturbing is that the technician showed me a photo of the status information displayed on the plasma's screen. If the mainboard was shot, would he be able to do this? I commented that "hey! you got it working" he told me he had to get in by some other means (unfortunately I now forget what that was).
So, I'm wondering if I'm being taken advantage of given a 60" Kuro walks in the door. They seem trustworthy but I remain skeptical.
Is $1k reasonable for a component refresh of the main board?
Appreciate any/all comments and advice.
Many thanks,
shoefly
shoefly is offline
post #769 of 779 Old 04-05-2017, 07:57 PM
GqMagic's Avatar
Originally Posted by Cetrian View Post
Edited my original post so it's all in one place.
Factory Reset Procedure
1 With tv off/in standby....press home menu.
2 Within 3 sec turn tv on , Integrated Menu will appear.
3 Hold Display button until Final Setup appears in the top menu.
4 Arrow left or right until yes appears in lower menu.
5 Hold enter until menu disappears.
6 Wait 1 min.
7 Power tv off and unplug from the wall for 5 or more min.
I have a Kuro 151, if I mistakenly turn the TV off and try to rapidly turn it back on, I get 8 flashing blue lights. It would normally power up after a few minutes.
Tonight it would not, so I searched our trusty AVS database here and found this thread and post. I loaded new batteries into the original remote, had to search the Kuro Operating Manuel (kept in a convenient table tray with the remote) to find the Home Button! (its been so long since I used this remote).
Did Steps 1 & 2, didn't get to 3 and the picture is back.
Thanks AVS !!
GqMagic is offline
post #770 of 779 Old 04-09-2017, 07:55 PM
eurisko's Avatar
Gqmagic, I have a 151FD and it too has the blinking light syndrome. My symptoms are exactly like yours except if it does an auto shut down (tv already on) I'll see 2 blue blinks. Other times when I try to turn it on and it won't it'll go into a continuous slow blink. I've tried to use the reset procedure and all I end up with is the Home Menu. I must be doing something wrong but I don't know what. Any tips?
eurisko is offline
post #771 of 779 Old 04-12-2017, 05:46 PM
Liked: 0
Guys! Very pleased to say that piecing things together in this forum I found the solution! And it cost me $0!!! Thanks so much to everyone here. For those who have arrived here (like I did) after a google search:
1. If you have a 8th gen (8G) 50" Elite (model PRO-1150HD) and your problem is 12 blinking blue LEDs and NOTHING ELSE, then this is 99% also your problem.
2. The issue is with the digital tuner. The main OS shuts the TV down when it has an issue getting its guide info over the air. Remember this set was built during the transition between analog and digital broadcast TV, and has some quirks because of it. You need to do TWO THINGS to prevent this from happening again:
2a. Disable the TV Guide subsystem from running at all. To do that, you need to bring up the "Integrator Menu" or other engineering menus and do the reset. Mine said "reset aborted" but it still worked. Then, you power the TV back on, be patient (it should show up at analog channel 1, then after ~30 sec) it should display a "Welcome your TV has this awesome TV guide feature!" You want to select the last one: never remind me again.
2b. You need to set the clock manually. Hit the home menu, then tuner setup. Arrow over to Clock and set up your time manually.
3. The problem is a lot of these services are simply not broadcast in the same way that the tuner in our TV's was designed to receive it. Turning these off prevents the power-off-12 blink cycle. It had nothing to do with mainboards, power, etc. It was all because I decided to "cut the cord" and plug in an antenna after years of just using this TV as a monitor for my HTPC.
Thank goodness for you great people here at AVSForum. As always, I find the best, most reliable info here. Check out Page 20 for a ton of good 1150HD info on this thread.
Edit: Here are the instructions from earlier in this thread:
Factory Reset Procedure (Integrator Menu)
6 Wait 1 min.
I have a PRO-111FD and the 8 blinking blue light issue started now. I have tried the Factory Reset Integrated menu procedure .. I get to the integrated menu but the holding of Display button or mute button for several minutes gets me nowhere. All I get is the baud rate at the bottom of screen and you can left-right to different baud rates. Does this procedure work for 12 blue blinking and nothing else? Also, is there a different recipe to get to the Final Setup menu?
Hope someone is reading and replying to the posts on this subject as I would like to save this nice TV. Desperately seeking some advise here and guide me in the right directions.
Shailesh Patel is offline
post #772 of 779 Old 06-12-2017, 01:53 PM
smalltownguy's Avatar
5080 Owner here. Had a power outage from storms yesterday, and I'm back to the 12 blinks of death.
  • I unplug the set, press the power button a few times to drain out all power.
  • Plug the set back in, wait at least 45 seconds (any shorter and hitting the power button won't take me to blue yet, it's still red).
  • Hit the power button, blue light comes on for approx 60 seconds, set clicks and displays "starting up" message for about 60 seconds. During this time, I have limited menu control from the remote.
  • After about 60 seconds of "starting up" it shuts off and blinks 12 times repeatedly.
This has happened before. Unplugging the set (admittedly in frustration, both times) has allowed the set to come back to life the next day.
This time, I tried leaving it unplugged for 1 hour, then 2 hours, then 4 hours, then overnight. Nothing. Still same 12 blinks.
This time I will leave the set unplugged for 24 hours and report back.
How very annoying.
smalltownguy is online now
post #773 of 779 Old 06-15-2017, 08:58 AM
I'm about the pull the trigger on the eBay option for reprogramming my main pcb. Has anyone used this service? What exactly is the eBay seller doing to correct the issue?
post #774 of 779 Old 06-15-2017, 09:23 AM
VeeCee's Avatar
Liked: 0
Hi.
Have been following this thread since this past weekend.
Found my 1150HD on Sunday morning with 12 blue blinks.
( Saturday evening power went out for a few seconds )
Had the set unplugged until this morning. This am, plugged into a different wall outlet and it came back to life !
I went into TV Guide settings and set zip to 0's.
Turned it off waited a few , minutes and started it up !
Just beautiful !!
( I was also considering sending off board to eBay vendor )
BBB99 / Tapatalk
VeeCee is online now
post #775 of 779 Old 06-15-2017, 09:27 AM
That's the problem. I cannot even get it to come on fully for me to be able to get into the full menus. Yes, I could leave it unplugged for a week and maybe it will come back to life, but what's going to prevent this from happening again? I don't want to deal with this again in the future.
post #776 of 779 Old 06-15-2017, 09:38 AM
VeeCee's Avatar
Liked: 0
Forgot to mention :
I had tried previous attempts at plugging in on it's usual spot on the power bar.
This was always resulted the blue blinks.
This morning went straight into the wall outlet and it worked !
BBB99 / Tapatalk
post #777 of 779 Old 06-15-2017, 07:50 PM
VeeCee's Avatar
Liked: 0
So as of tonight , my Pro-1150HD is still working.
I am keeping my fingers crossed that the blue blinking won't come back.
Meanwhile have already saved the vendor from eBay.
smalltownguy - any luck in making it work or did you end up going with the eBay option ?
BBB99 / Tapatalk
post #778 of 779 Old Today, 07:00 AM
BBB99 / Tapatalk
Apparently just a hair over 24 hours is what's needed to drain all the voltage out of all the caps on every board in my TV. When I tried plugging it into another outlet in the living room Thursday night, the TV came up just fine. I went into the menus and entered all zeros in the TV Guide setup.
I looked at my extension cord running across the living room and thought, "yeah, my wife's not gonna go for THIS setup for very long." So I shut down the TV, turned off the power button, and unplugged it, moving it to the regular outlet under the TV stand.
12 blue light special again
So, I left it off from 6pm Thursday night until 9pm Friday night. She came back on again no problem. THIS time I wasn't going to monkey around - I performed a factory reset on the TV, and at the TV Guide message I chose "Do Not Remind Me Again."
Hopefully disabling the TV Guide will prevent these errors from happening again when the TV is unplugged. Time will tell. In the mean time, I'll leave things as is, and report back if there's ever a time when there's a power outage or the TV gets unplugged. I'm not going to mess with it right now, as it's now become our daily driver.
Just for kicks, I went into the service menus to get an eyeball on the total hours on the set. Just a hair over 12,000. I bought the set in 2011 used with 7900, so that's not bad. We've averaged about 2 hours a day with the set since we took ownership. At this rate the panel should outlast us.
post #779 of 779 Old Today, 07:13 AM
VeeCee's Avatar
Liked: 0
Fantastic , great to hear you got it running again !
BBB99 / Tapatalk
