Runco XP-65DHD 65 inch 1080p plasma monitor is here. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-25-2006, 05:24 PM - Thread Starter
Jonesky's Avatar
So if it is a 65/1080p then it must be a Panasonic (pf9uk) glass, correct? I think they are bundling it with their DHD video processor. What a setup, if my assumptions are anywhere near correct it should provide interesting competition to the coming Fujitsu 65/1080p Plasma (also using Panasonic glass) with their new AVM III processor. Choices, choices. Wonder which one will take the prize for being the most expensive and which will actually be superior?
Jonesky is offline
post #2 of 7 Old 12-25-2006, 05:30 PM
omeletpants's Avatar
omeletpants is offline
post #3 of 7 Old 12-30-2006, 04:42 AM
Frost147's Avatar
My bet will be on Runco - for biggest dollar per inch cost!
Ottawa Ontario Canada
Frost147 is offline
post #4 of 7 Old 02-22-2007, 03:03 PM
HiDef Bob's Avatar
Runco makes their own glass
Bob
If it is not HDTV it is not worth watching!
HiDef Bob is offline
post #5 of 7 Old 02-22-2007, 03:38 PM
EJRothman's Avatar
I believe that this in incorrect.
EJRothman is offline
post #6 of 7 Old 02-22-2007, 07:49 PM
RaiChris's Avatar
Is this not the same TV as this?
RaiChris is offline
post #7 of 7 Old 02-22-2007, 08:24 PM - Thread Starter
Jonesky's Avatar
I've got a ten spot that says all three use the same glass.
Jonesky is offline
