my new setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-18-2007, 10:41 PM - Thread Starter
whityfrd's Avatar
Quoted: 63 Post(s)
Liked: 52
50ph9uk
Motorola DCT6412
Xbox 360
360 Hd-dvd add on
finished this setup about 2 weeks ago. Forgive the crappy camera, its a walmart christmas special. tv pics look a little blown out. Built the cabinet myself (took me a month) and am extremely satisfied with the outcome. what you guys think?
the build process in progress:
the finished product..
the biggest baby ever born in Louisiana. Herman Johnson 6"7 370lbs.
more setup pics
some sd on the screen, looks good. forgive the mess, the wife is a kindergarten teacher.
and a little extra, the wife and i on the honeymoon. were loving our new setup.
she still cant believe i made the tv stand. the nerve of the woman!!
whityfrd is offline
post #2 of 7 Old 01-18-2007, 10:49 PM
savedviewer's Avatar
Great piece of woodworking there! Feels pretty good to be able to make something like that yourself I bet. Thanks for sharing.
Keep looking up... <*{{{><
savedviewer is offline
post #3 of 7 Old 01-19-2007, 06:08 AM
why2not's Avatar
Nice job on the stand, wish I had that type of woodworking skill....
why2not is offline
post #4 of 7 Old 01-19-2007, 06:43 AM - Thread Starter
whityfrd's Avatar
Quoted: 63 Post(s)
Liked: 52
well i didnt think i had any to begin with. i just had a determined vision of what i wanted and alot of motivation. and a home depot right down the road. heh
whityfrd is offline
post #5 of 7 Old 01-19-2007, 07:42 AM
dlconner's Avatar
Nice setup, and great job on the stand. Enjoy your new set, the 9UK is an awesome display
dlconner is offline
post #6 of 7 Old 01-19-2007, 07:46 AM
CHolleman's Avatar
man that looks really good. when you were building the stand, did you just screw and glue the joints and fill the holes with putty? i need to build some racks for my media and can't find what i'm looking for to buy. what kind of wood is that? birch ply? good job dude.
CHolleman is offline
post #7 of 7 Old 01-19-2007, 10:34 AM - Thread Starter
whityfrd's Avatar
Quoted: 63 Post(s)
Liked: 52
ya its birch ply from home depot. dirt cheap. but forewarned it doesent absorb a stain too easily. as far as the joints it was really a top over place and screw. i had predetermined that the granite countering would go on top so i just countersank the screws and let them be. i did some on the sides of the unit and filled those with putty. shelves are held with shelf pins on the inside and countersunk screws on the outer door side. a couple of things i would have done differenly. the molding i used was glued on with gorilla glue. stay away from this stuff for heavy application, its real messy. i should have used a nail gun and tapped and puttied. I also should have made an effort to find cheaper supplies as the perforated aluminum cost me 40 bucks and only needed a fouth of the sheet. Another thing is that i used a stain/poly combo mix sold by minwax. i would suggest to stain and poly separate. they both achieve the same results but the combo needs alot more coats to get the desired color as advertised. the granite countering was also expensive. 80 bucks for an 8x6 sheet and i only needed half of it.
whityfrd is offline
