LG 42PC3D - broken remote or tv remote sensor??? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 122 Old 02-26-2013, 01:24 PM
mar1234's Avatar
Originally Posted by vp123ca View Post
I had the same problem with my LG 42PC3. I have a few remotes that were programmed to operate the television. It was highly unlikely that all 3 of the remotes were defective or with bad batteries since the other components like stereo and the cable box would work with the same remotes. I assumed the problem lied with the receiver on the TV. It turned out to be the TV but not the receiver itself. Let me explain, there is a "REMOTE IN" jack on the back of the TV to connect an external wired remote. When you plug in an external wired remote, it deactives the IR sensor. But the problem was that I didn't have an external remote plugged in there. What happens is that some corrosion builds up in the connector behind the TV which causes the circuit to close and deactives the IR receiver, all that is required is to unplug the TV from power source, squirt some WD-40 (only a little) into the connector hole behind the TV and use any 3.5mm plug like a headphone jack and plug-unplug a dozen times to loosen any build-up in the plug which I did and now the TV receives the signals from the IR remote. It worked like a charm for me....the entire fix took less than a minute. I hope this helps anyone out there with the same problem.
Thank you vp123ca! I did'nt have ear phones so I used an attachment on my vacuum cleaner and all is well:)smile.gifsmile.gifsmile.gifsmile.gifsmile.gif
mar1234 is offline
post #92 of 122 Old 02-27-2013, 05:39 PM
Sam Williams's Avatar
Seriously. You saved me a bunch of money. I purchased a replacement remote and a universal remote which didn't work. I started searching online to see if anyone else had the problem. When I started reading this thread I was becoming very discouraged until your post. It worked like a charm. You have to love the internet! Thanks so much for sharing your knowledge!
Sam Williams is offline
post #93 of 122 Old 03-04-2013, 02:04 PM
douglasjames's Avatar
Thanks so much, i have a Lg 32 inch tv and my tv remote and cable remote both stopped working with the tv. I bought this from a rent to own place, i do have a 1 yr warranty but they would have to send it out, so i'd have no tv. Any ways i tried plugging head phone jacks in to the remote control hole about a dozen times like u said and it worked. Thanks for posting that on here. God Bless.
douglasjames is offline
post #94 of 122 Old 04-06-2013, 04:49 PM
Larry Witteborg's Avatar
Worked for me as well..but I spent $90 on a tech who could not figure it out...THEN I found this article..had it working in under a minute
Larry Witteborg is offline
post #95 of 122 Old 04-26-2013, 10:33 PM
Santanafan's Avatar
Thanks for your 'fix'. It took me longer to walk upstairs to the tv than it did to do the fix. So again thanks a million saved me a fortune in repair bills
Santanafan is offline
post #96 of 122 Old 05-23-2013, 09:55 PM
chan296's Avatar
Thanks!!! This solution was a quick fix and saved me from buying a new tv. It took longer for me to find the WD40 and the flashlight than to actually fix the issue. You are the man!!!! biggrin.gif
chan296 is offline
post #97 of 122 Old 06-07-2013, 07:46 AM
nullifx's Avatar
Wow never thought something so simple would fix this issue. I just blew some compressed air in the hole and plugged in a set of headphones a couple times and so far so good. Thanks!!
nullifx is offline
post #98 of 122 Old 07-03-2013, 06:44 AM
kjani's Avatar
You guys are geniuses!!! Ok we have a B&B business, guest comes down says remote is not working on the LG tv. I'm thinking ya right, so I go up to find out what they did wrong. Come to find out no remote is working on the tv - guest goes out to dinner and I ponder replacing this 40 inch!!! Really depressed, then by chance I land on this thread and read about your solutions with the remote input port thing on the back. I get a toothpick and do the nasty with the port. Then I use the blunt side of this particular toothpick and do the nasty again and LOW and BEHOLD all the remotes start working again on this tv - unfreaking' believable - THANK YOU!!!!
kjani is offline
post #99 of 122 Old 07-04-2013, 11:13 AM
aperegudin's Avatar
All I did, I remove the back cover, went very easy, removed the remote board an soldered three contacts of ir sensor, it solved my problem with the remote.
aperegudin is offline
post #100 of 122 Old 07-04-2013, 11:54 AM
Will Pinder's Avatar
Just wanted to say thank you to the person who posted the fix-it to the remote sensor problem. This was amazing I was gonna buy a new set tomorrow after this quit working about a week ago !! I thought the repair costs would justify a new tv purchase !! What a remarkable fix !! Thanks Thanks Thanks
Will Pinder is offline
post #101 of 122 Old 07-21-2013, 07:38 AM
aa5flyer's Avatar
Great solution! Worked like a charm on my LG 42" lcd. Thanks a lot!
aa5flyer is offline
post #102 of 122 Old 07-27-2013, 07:07 PM
meedar7's Avatar
OmG. I just fixed my tv remote situation with a q-tip and wd-40. It's been not working of 4 months. I was gonna buy another tv....
meedar7 is offline
post #103 of 122 Old 08-10-2013, 09:01 AM
kathdawson's Avatar
Stupid question alert.... I can't find a 'remote in' hole in the back of the telly. I have an LG 47LD450 and the remote has stopped working (again). I am trying to apply that magic solution that seems to be working for everyone. The TV is screwed to the wall so its hard to see the back clearly however the manual available here http://www.lg.com/uk/support-product/lg-47LD450 doesn't mention a remote in jack. Could it be named something else on my telly? Thanks!
kathdawson is offline
post #104 of 122 Old 08-24-2013, 06:42 PM
will e's Avatar
Thanks, vp123ca! Worked on a Zenith Z50PX2D smile.gif Wired remote input is on the back, next to the AC input.
will e is offline
post #105 of 122 Old 09-01-2013, 07:47 PM
Jeremy Brown's Avatar
This post is a lifesaver. I went to visit my 87 year old Grandfather and he was having issues with the volume control on his LG 32LG30 TV. He assumed it was the new Time Warner cable box and / or the universal remote causing the issue. The nice person from Time Warner who set it up originally could not get the universal remote to work with his TV for any code for LG at all.
I tried my hand at it and came up with nothing. No code would work to control the TV. I grabbed the LG remote that came with his TV and got a big clue when it wouldn't even turn the TV off or on. So I knew it has noting to do with Time Warner's equipment or universal remote. I did a Google search on the model of TV with "remote not working" and it brought me to this thread.
After reading through a few of the posts I started to think "oh no, he's going to have an expensive repair on his TV"... Then I came to this post and went "hmm..."
Looking at the back of the TV, I saw the jack for the wired remote and had a big "ah-ha" moment... Grabbed my 50 cent pair of cheap earbud headphones, pushed the connector into the jack a few times, and boom. Remote and volume control all working great! Universal remote works great! Native remote works great!
Saved a mountain of frustration for an 87 year old senior citizen who really doesn't have the ability to haul his TV back and forth to a repair shop for such a simple fix.
Bravo!
Jeremy Brown is offline
post #106 of 122 Old 09-01-2013, 08:03 PM
On mine it was labeled "Wired Remote". It was on the back of the TV on the left hand side if you are looking at the front of the set, or to the right if you're looking at the back.
It sits in a recessed area where all the other jacks are located so if you have your TV mounted on your wall, I think you'll have to unmount it to clearly see the correct input jack. I doubt you'll have much luck locating it if the TV is flush or close to the wall.
Good luck!
post #107 of 122 Old 09-13-2013, 07:54 PM
isell's Avatar
Just tried the WD40 and the air dust in the "Remote Control In" (is that correct?)confused.gif and still cannot get the remote to work. The "Input List" will not go away and I cannot get the TV to turn off. Please HELP...confused.gif
isell is offline
post #108 of 122 Old 10-07-2013, 02:09 AM
delfincek's Avatar
Quoted: 28 Post(s)
Liked: 53
Maybe you need cleaning of the contacts inside that remote input. Do not ever use WD40 on the electronic parts as you can do more damage with that. Just use bare 3.5mm mini jack (from headphones) a couple of times in and out and you are well done. Also alcohol is ok.
best, d.
delfincek is offline
post #109 of 122 Old 11-04-2013, 06:21 PM
kware12's Avatar
Thank you so much.  I see your post was three years ago and LG is still having the same problem.  My remote stoped working last week and I had no idea what to do.  I dreaded calling a repair man as the TV is out of warranty.  I just stuck a pair of headphones in the remote in jack and "voila" the remotes are working again.
kware12 is offline
post #110 of 122 Old 11-16-2013, 07:02 AM
holmes12's Avatar
OMG---it worked.  Got out the WD-40 & headphones and just never thought it would work, but much to my surprise, it took care of my remote working again.  Thanks a bunch!!  Hope it continues.:)
holmes12 is offline
post #111 of 122 Old 11-16-2013, 06:06 PM
Rdfeibleman's Avatar
Finally tried it and yup, a few in and outs with the earphone jack, presto, working. Thanks.
Rdfeibleman is offline
post #112 of 122 Old 12-01-2013, 04:34 PM
allenp109's Avatar
I have a LG Plasma 42PC3D and my remote operated my Dish Box and not my TV. I tried the recommended procedure and it worked like charm. Sprayed a little WD40  in the exterior remote jack on the back of the TV, worked the headphone jack in and out, and then I sprayed a little canned air just for grins. Fired that baby up and presto - all systems go! Great job! Thanks for posting.
allenp109 is offline
post #113 of 122 Old 01-02-2014, 05:21 PM
destindolfin1's Avatar
Thank you so much for the advice you gave about the "remote in" malfunction. I didn't have any WD40 so I used coconut oil, and it worked like a charm!
destindolfin1 is offline
post #114 of 122 Old 01-12-2014, 07:48 PM
Michael Gabriel's Avatar
OMG, vp123ca, I had the problem and that fixed it!!! you rock. saved me a load.
Michael Gabriel is offline
post #115 of 122 Old 02-12-2014, 07:35 PM
bopp1's Avatar
OH, MY Goodness…. getting up for a month or more to turn the tv off or on , volume up or down… well you know…. You guys made my day, month, year!!! this worked immediately!
bopp1 is offline
post #116 of 122 Old 03-15-2014, 07:29 PM
Marblehillfarm's Avatar
VP mate you are a genius the WD40 into the remote jack hole at rear worked a treat....Thankyou so much.
Marblehillfarm is offline
post #117 of 122 Old 04-29-2014, 03:42 PM
Unbelievable's Avatar
I joined just to say I read the article on the fix for my LG 42PC3D hand remote which was not working. I ran around to LG here in Toronto's head office to my cable supplier and various other sources and no one was sure what the problem was. They said the remote was working and it must me the remote sensor in the T.V. I was getting crazy with it especially not being able to turn the set off at night without getting out of bed.  I decided to check on line and read the article about squirting a little WD40 in the back of the T.V. set in the remote input plug as suggested.
 Unbelievable how it worked perfectly right away. I was even able to program my cable suppliers remote now.
Bravo Bravo to this fix!!!!!!!
Unbelievable is offline
post #118 of 122 Old 11-09-2014, 08:36 AM
Liked: 0
I registered on this forum only to thank you! You saved me buying a new TV and the hassles of installing it.
All I had to do was plug and unplug a 3.5mm jack into the remote - remote port ten times.
THANK YOU THANK YOU THANK YOU!!!!
Thank Youu! is offline
post #119 of 122 Old 11-13-2014, 03:38 PM
bigmark59's Avatar
Liked: 0
I fixed it right in front of the 2 guys from Comcast who told me the TV remote sensor was bad!! Thank you!!
bigmark59 is offline
post #120 of 122 Old 03-06-2016, 02:45 PM
TommmyJ's Avatar
Thanks for the fix. Had the 42LG50 tv since 2009 and no problems. Remote stopped working this morning. Tried the WD-40 trick and it fixed it. Thanks very much for the fix!!
TommmyJ is offline
Lg
