LG 42PC3D - broken remote or tv remote sensor??? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #121 of 122 Old 06-25-2016, 04:32 PM
Neild's Avatar
Another success story here. I'd previously "fixed" this TV by plugging in an IR remote sensor, but didn't realize at the time just cleaning the port would be enough. Removing the sensor and cleaning, it works.
Tip to other users: don't use WD-40 unless you don't want to use the remote plug in ever again. WD-40 does clear the fine corrosion that's causing this port to close by itself, but it can gum it up for the future. Try just clearing the problem by inserting and removing a plug a bunch of times. Or if you have to use WD-40, use the tiniest amount possible, maybe on the end of a q-tip or something.
Neild is offline
post #122 of 122 Old 12-08-2016, 05:47 PM
vp123ca's Avatar
I happened to stumble across this thread today, and I forgot that I posted the quick fix with the remote jack about 6 years. I am glad that I was able to help out so many people. FYI, I still own my LG plasma, and it is still working well after 8 years.
Happy holidays everyone.
vp123ca is offline
Lg
