QAM Tuner, Rochester NY, Time Warner - AVS Forum | Home Theater Discussions And Reviews
Old 01-27-2007, 05:57 PM - Thread Starter
TheJimbo's Avatar
Trying to figure this out. I searched and read a lot here, but haven't got a definitive answer. I have a TH42PX60U and like it very much. I can pull in 5 HD channels with an antenna, OTA. However, if I take the coax cable out of my Time Warner box and plug it directly into the TV to have the QAM tuner pull HD channels over cable, I don't get ANY! What gives? Yes, I have set the ANT in from 'antenna' to 'cable' and did an auto program search. Doesn't pick up a single HD channel. Pull the cable and put the antenna back, and I get 5 HD channels OTA.
Anyone in Rochester NY using Time Warner cable have this same issue???
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is offline
Old 01-27-2007, 06:05 PM
dhark's Avatar
word is the QAM in the panasonics suck and are nearly useless
dhark is offline
Old 01-27-2007, 08:14 PM
ZoneFighter's Avatar
According to the message boards at rochesterhdtv dott com (I can't post links yet.)
Rochester TW QAM:
80-3 WXXIQ
80-4 WXXI
80-300 TNT
82-2 WOKR (ABC)
82-3 WXXIHD
83-1 INHD1 (Scrambled as of April 1, 2006)
83-2 INHD2 (Scrambled as of April 1, 2006)
91-6 WXXIKIDS
92-1 No Signal
92-10 Scrambled
92-10 Scrambled
100-1 Scrambled
100-6 Scrambled
102-1 WHEC (NBC)
102-2 WHEC Doppler Radar
102-3 - WROC (CBS)
103-4 Jewelry Television
105-10 On Demand Previews
113-11 RNEWS
114-11 On Demand Previews
115-1 DiscoveryHD
115-2 WB
116-2 Scrambled
116-3 Scrambled
116-4 Scrambled
116-9 Scrambled
ZoneFighter is offline
