Best Articulating Arm Mounts - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 134 Old 04-11-2009, 08:19 PM
a10pkt8's Avatar
Originally Posted by creemail View Post
I believe its a difference between black and silver. The 'B' references that the VMDD26 is black.
Chris
$220 difference for black vs silver for something that sits *behind* the TV! Wow! Black matches my TV's color anyway
a10pkt8 is offline
post #92 of 134 Old 04-11-2009, 08:25 PM
aymanme's Avatar
Look carefully at the different products on amazon. Price discussion is usually frowned upon. The difference is silver vs black. I got mine at amazon and am quite happy with it, 2+ years and stil working great. We move it daily from the kitchen to living room.
aymanme is offline
post #93 of 134 Old 04-12-2009, 12:34 AM
creemail's Avatar
Yeah I can understand. Not sure why the difference due to color. It could be based on demand. Not sure though.
Chris
creemail is offline
post #94 of 134 Old 06-24-2009, 11:26 AM
Goofoff's Avatar
color / price difference is usually ONLY on demand unless there is something completely subtle that is different with them...but in this situation there is not..(i don't think)
Chaos is how the world keeps moving along, order just inhibits the innovation it creates.
Goofoff is offline
post #95 of 134 Old 06-26-2009, 09:30 PM
jschillereff's Avatar
Hey everyone,
I just wanted to stop by and say that I just went through www.wallmountwarehouse.com for the Sanus VMDD26B wall mount and they were great to deal with. They had the cheapest price with shipping (plus a free 6ft. HDMI cable) and it was sent out right away. I'll be using it to mount a Pioneer KRP-600M and I can't wait to get it done.
Jason
jschillereff is offline
post #96 of 134 Old 08-01-2009, 07:34 PM
Mathelo's Avatar
I'm buying an articulated mount for My Pio FD151.
I've narrowed my choice down to the Chief PDR or the relatively new Sanus XF228.
I'm probably going to get the Chief mainly because it will extend 37", which is considerably more than any other articulated mount on the market. Both will collapse close to the wall.
But this new Sanus looks very attractive and I can get it for a bit less than the Chief.
Any recommendation will be welcome.
Louis
Mathelo is offline
post #97 of 134 Old 08-01-2009, 09:36 PM
GlenH's Avatar
Don't know about the XF228, but I really like both of my Sanus articulating mounts (VMDD26 for my Pioneer KRP-600M and VMAA26 for my 50" Fujitsu panel).
The VMDD26 is REALLY solid even fully extended with my 60" panel attached. No flex at all and it holds the tilt perfectly.
I second jschillereff's rec on wallmountwarehouse.com. Cheap, free HDMI cable and fast shipping.
GlenH is offline
post #98 of 134 Old 08-02-2009, 01:42 AM
flyers's Avatar
Louis
Chiefs quality is waaaaay better than Sanus and their motion is smooth as butta. In fact they are over engineered.
flyers is offline
post #99 of 134 Old 08-02-2009, 12:47 PM
Mathelo's Avatar
Thanks GlenH and flyers for your reply.
I’ve decided to go with the Chief. I can get the Chief for the Pioneer with either a universal attachment (PDRUB) or a custom attachment (PDR 2043B) to the plasma. Based on the drawings I found on the Chief website, the custom attachment looks a bit cleaner but other than that they seems functionally the same.
Are there any other differences between the universal and custom attachment that I should be aware of? I’m thinking that I should be able to find this mount with the universal mount quicker – and possibly for less – than the custom.
Thanks again,
Louis
Mathelo is offline
post #100 of 134 Old 08-17-2009, 08:49 PM
aseer's Avatar
I came across this excellent thread while doing some homework for a friend who is looking to wall mount his Pio 141FD. The location is a tight recessed inlet so he will need the mount to extend straight out (2 feet would be great). I saw a couple of posts that mention how the VMDD26B extends (saying the opposite of each other), so I thought I would check.
(the manual was not too clear)
Will the VMDD26B allow the plasma to extend straight out and back (also, is it a touch mechanism for out and back motion or will he need to reach around/under and unlock something to recess the plasma)?
As an aside, is there any reason it would not work with the 141FD?
aseer is offline
post #101 of 134 Old 09-09-2009, 06:59 PM
aymanme's Avatar
Yes, and it is touch -- nothing to lock/unlock
I am sure it would if it has standard mount pattern, but I am not familiar with that panel.
ayman
aymanme is offline
post #102 of 134 Old 09-09-2009, 07:25 PM
joebloggs13's Avatar
I purchased the AVF wall mount for my 42b450. It's the tilting model, and it looks solid as it's rated to 200lbs max. Price $119 at Costco.
joebloggs13 is offline
post #103 of 134 Old 09-10-2009, 03:28 PM
aseer's Avatar
ayman
Thanks, order placed.
(and I found a number of folk who use it for that panel, so it should be fine. Thanks again)
aseer is offline
post #104 of 134 Old 12-26-2009, 08:39 PM
ilaw's Avatar
I would like to mount a Pro-141FD to an Omnimount ULPC-XB. I've read a lot of forums and haven't found any reviews on the ULPC mount. I prefer this mount over others (including the UCL-XB) because I have 24" spacing between wall studs.
If anyone has comments or is using the ULPC-X I'd appreciate hearing about it - Thanks
ilaw is offline
post #105 of 134 Old 06-19-2011, 01:00 PM
booyaa's Avatar
Guys I hate to revive, but I am in a hurry.
I have a Pioneer PDP 6020 I need an articulating wall mount for.
What are the popular units most guys are going with now?
booyaa is offline
post #106 of 134 Old 06-19-2011, 01:30 PM
spdntrxi's Avatar
I use a Sanus XF228
Johnny
Klipsch,Denon,Parasound,Sunfire
spdntrxi is offline
post #107 of 134 Old 06-19-2011, 01:36 PM
Suzook's Avatar
Liked: 27
Peerless
Suzook is offline
post #108 of 134 Old 06-19-2011, 06:06 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Guys I hate to revive, but I am in a hurry. I have a Pioneer PDP 6020 I need an articulating wall mount for. What are the popular units most guys are going with now?
The most popular mounts could be all wrong for your particular requirements or too entry-level for your 6020.
The opposing-arm scissor-type seem to be more popular than the single-arm types, but the single-arm type has more range of travel and usually allows the TV to be turned 90 degrees to the wall (or more) which is handy if you want to turn the TV toward a kitchen that's off to the side (like one of the installs i did for someone). His wife likes to watch Food Channel from the kitchen during the daytime so she turns the TV 90 degrees so she can see it straigth on and just uses the built-in speakers, then at night they move it flat against the wall and use the surround sound system when they sit on the couch.
And the budget mount's arms are more prone to twisting and sagging than the arms on the more expensive name brand mounts. I installed my best friend's 6020 so i know it's heavy!
I have a Peerless PLA50 because not only is it a single arm, it's also vertically offset with the wall plate being located below the TV's centerline which enabled me to bolt it under my big front window but still place the TV at an appropriate height. It's solid, and i can turn the TV 90 degrees to the wall and beyond. They make a larger PLA60 for larger TVs.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #109 of 134 Old 06-21-2011, 05:48 AM
RFDLP61's Avatar
I'm also in the same situation. I just returned a Monoprice and looking for something that will hold a P65v10 (at least 150lbs). I found some good deals on a Peerless SA770PU, a Sanus VXF220 and VLF210 and also an Omnimount UCLX. They all seem to be high quality but they also sit between 4" and 7" from the wall when not extended which kinda defeats the purpose of a flat panel. The Sanus VLF311 was promising but I just discovered that it's rated at a max of 125lbs wich makes me uncomfortable to use it with a TV that's 135lbs to be mounted on metal studs (granted that they are thick metal studs.
Any help will be appreciated.
P.S: Also checked out Chief but they are pricey.
RFDLP61 is offline
post #110 of 134 Old 06-21-2011, 08:15 AM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Originally Posted by RFDLP61 View Post
..... I found some good deals on a Peerless SA770PU, a Sanus VXF220 and VLF210 and also an Omnimount UCLX. They all seem to be high quality but they also sit between 4" and 7" from the wall when not extended which kinda defeats the purpose of a flat panel. ..... Also checked out Chief but they are pricey.
Since you're price concious that rules out the various recessed in-wall hidden mounts (they're very expensive), but can you open a large cavity in the wall where the TV will be mounted and fabricate some sort of mounting plate set back between the studs so you can install a low profile articulated mount inside the wall? That could reduce your overall depth by maybe 2-3 extra inches.
Randy
post #111 of 134 Old 06-21-2011, 06:39 PM
RFDLP61's Avatar
Thanks for your reply Randy, I did indeed look at some in wall mounts and they are a little more expensive. My installer just vetoed any sort of articulating mount as he doesn't believe that it will be safe enough in the long term especially in Socal unless we do some major kitchen cabinet-style reinforcement which I vetoed. So now, I'll be just looking into geting a very low profile mount that has a wall plate big enough to cover 3 24"-spaced studs :§
RFDLP61 is offline
post #112 of 134 Old 07-06-2011, 10:24 AM
kafkhami's Avatar
sorry
kafkhami is offline
post #113 of 134 Old 07-06-2011, 10:25 AM
kafkhami's Avatar
i need three posts
kafkhami is offline
post #114 of 134 Old 07-06-2011, 10:25 AM
kafkhami's Avatar
so that i can post this...
kafkhami is offline
post #115 of 134 Old 07-06-2011, 10:27 AM
kafkhami's Avatar
http://www.newegg.com/Product/Produc...82E16882021119
BANG for your BUCK
This thing is beast. I own it.
kafkhami is offline
post #116 of 134 Old 07-06-2011, 10:46 AM
aymanme's Avatar
Covering 3x24" studs will be tough. I haven't seen many (or any?) that have that. You might end up putting something between the wall and mount that can then distribute the load across the 3 studs.
aymanme is offline
post #117 of 134 Old 07-06-2011, 02:11 PM
smitty's Avatar
Do these articulating wall mounts allow you to move the TV straight up or down or shift over to the left or right a couple of inches once it is more or less fully extended?
I will be installing at 65" TV on a wall, and the TV will extend out on the arm so that it sits flush with the front of a big cabinet that is open at the back. It would be nice if the mount enables you to shift the TV up or down or left or right a little bit, so the TV will be centered perfectly in the cabinet. The descriptions of the various units on the websites often talk about pan, tilt, swivel, horizontal adjustment, vertical adjustment, etc., but it's not exactly clear what these mean (at least to me).
smitty is offline
post #118 of 134 Old 07-06-2011, 07:23 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Good question, bump
whipit is offline
post #119 of 134 Old 07-07-2011, 07:00 PM
RFDLP61's Avatar
Yeah, the biggest plate I found was only 45.75".... I ended up using Chief's Fusion XTMU with 4 Toggler Snapptoggle 5/16" on the studs.
Here is a link that contains some pics post installation.
http://www.avsforum.com/avs-vb/showt...1#post20666910
I also wanted to thank everyone for the advices.
RFDLP61 is offline
post #120 of 134 Old 07-12-2011, 11:56 AM
smitty's Avatar
Originally Posted by whipit View Post
Good question, bump
Bueller? Bueller? Anyone?
smitty is offline
