Best Flat Panel for Xbox, PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-01-2007, 07:58 PM - Thread Starter
Yada Day's Avatar
Hi, When it comes to choosing a flat panel TV for HDTV I've developed a preference for Plasma's over LCDs; to me the LCDs don't handle motion (sports, etc.) as well as the Plasmas.
But setting aside HDTV sources (satellite, etc.), if you were going to purchase a 40-42" flat panel just for Xbox and PS3 gaming, would you still stick with a Plasma or would you prefer a LCD?
Some other questions:
1. Any concern about Plasma burn-in, or is that a thing of the past? (this would be used by kids - they might not turn off games, etc.)
2. Which would give a better picture for Xbox and PS3, LCD or Plasma?
3. I like Pansonic Plasmas, but is there any concern on the 37" and 42" models that the native resolution is 1024 x 720 (instead of 1366 x 768) - when it comes to games?
4. Any particular brands/models you (either Plasma or LCD) that you like best for Xbox and PS3?
Thanks, Yada
Yada Day is offline
post #2 of 2 Old 03-02-2007, 08:05 AM
hdplasmas's Avatar
You can't go wrong with the pioneer 4270hd, 5070hd or 6070hd. They have 1366 x 768 resolution so it can process 1080i better and even 1080p 24hz signals. 1080p signals have to come in through hdmi only but it won't accept 1080p from ps3 cause it outputs 1080p 60hz and ps3 doesnt have a scaler chip in it. The xbox 360 does 1080p through component but most plasma screens aren't native 1080p anyway. Colors, detail, fast motion and black levels are freaking amazing on these pioneers. Back when prey came out for xbox 360 I was stuck playing it on a philips plasma I had for a few months and I switched to the pioneer which made the difference very obvious.
hdplasmas is offline
