Samsung xx34, xx44, xx54, xx64 Series Plasma Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8389 Old 03-29-2007, 03:38 PM - Thread Starter
oxfdblue's Avatar
I think it's about time for this... Samsung's new HP-T 4254 & 5054 and the 4264 & 5064 deserve their own thread.
Enjoy!
oxfdblue is offline
post #2 of 8389 Old 03-29-2007, 03:42 PM
SuperTool's Avatar
Enjoy!
I agree. Love my 5054.
SuperTool is offline
post #3 of 8389 Old 03-29-2007, 03:49 PM
tomanystraydogs's Avatar
I put this in another thread but why waste it.
Differences between the new T**54 and older 4253 and 4273:
Looks like the MSRP of the T4254 is 2299.
Right now about 100 more than the 4273 and 200 more than the 4253.
Warranty back to 1 year, 4273 is 2 years.
T4254 has 18-bit processing, previous models were 13-bit.
T4254 has 15,000 contrast ratio, previous models were 10,000.
I do not see a cable card on the T4254.
In addition to the 2 HDMI ports on the back of all the models, the T4254 adds a third one to the side panel.
An extra zoom mode called "Just Scan".
From the manual:
16:9 :Sets the picture to 16:9 wide mode.
Zoom1 :Magnifies the size of the picture on the screen.
Zoom2 :Expands the Zoom1 format picture.
Wide Fit :Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 :Sets the picture to 4:3 normal mode.
Just Scan :Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
be set.
In TV,,VIDEO,S-VIDEO,and COMPONENT(480i,480p)modes,all screen
modes can be selected.(16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
In COMPONENT((720p,1080i)or HDMI(720p,1080i)mode,16:9,4:3 and
Wide Fit can be selected.
In Zoom1,,Zoom2 and Wide Fit modes,you can move the picture on the
screen by pressing the ▲ or ▼ button..
You can not change the picture size when PIP is set to Double.
When Double ((,)mode has been set in PIP,the Picture Size cannot
Wide Fit can be used when watching a Digital HD ((High Definition)signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically.For example,you can reset the picture in 4:3 format to 16:9.Wide Fit
does not support all external devices (DVD,VCR etc.).
Size T V
16:9
Zoom1 Zoom2
▲ More
Color Tone :Cool1 Detailed Settings Digital NR :Auto Active Color :On Picture T V
Enter Move
Still doesn't look like there is a way to zoom sub 720p signals without cropping. I think the Panny's can do this.
Looks like there are a lot more picture settings.
From the T4273 manual:
Black Adjust:Off/Low/Medium/High
You can directly select the black level on the screen to adjust the screen depth.
Dynamic Contrast:Off/Low/Medium/High
You can adjust the screen contrast so that the optimal contrast is provided.
Gamma:-3 ~3
You can adjust the middle brightness of pictures.
Press the ◄ or ► button until you reach the optimal setting..
Color Space:Auto/Wide
Color space is a color matrix composed of red,green,and blue colors.Select your
favorite color space and experience the most natural color.
You can set the color reproduction space for the input signal to Auto or Wide .
White Balance:R-Offset/G-Offset/B-Offset/R-Gain/G-Gain/B-Gain/Reset
You can adjust the color temperature for more natural picture colors.
R-Offset/G-Offset/B-Offset/R-Gain/G-Gain/B-Gain:Changing the adjustment
value will refresh the adjusted screen.Select the desired option by pressing the
▲ or ▼ button,,then press the ENTER button.Press the ◄ or ► button until you
Reset:The previously adjusted white balance will be reset to the factory defaults.
My Color Control:Pink/Green/Blue/White/Reset
This setting can be adjusted to suit your personal preferences.
Pink/Green/Blue/White:Select the desired color by pressing the ▲ or ▼ button,,
then press the ENTER button.Press the ◄ or ► button until you reach the optimal
setting.➢
When using the My Color Control Feature,the current picture remains in
movement.Reset:
The previously adjusted colors will be reset to the factory defaults.
Edge Enhancement:Off/On
You can emphasize object boundaries.
I don't see any of the above settings in the previous models.
That's all for now.
Samsung Plasma TV FAQ - read it, learn it, live it.
tomanystraydogs is offline
post #4 of 8389 Old 03-30-2007, 06:01 PM
fireballz's Avatar
I'm anticipating the 64 series, cause I really need that USB port!
(and can we make this the official thread, cause there are way too many sammy threads on the new plasmas!)
fireballz is offline
post #5 of 8389 Old 03-30-2007, 06:47 PM - Thread Starter
oxfdblue's Avatar
The 64 series is now online at J&R, B&H Photovideo and DataVision in NYC. The prices at J&R and DataVision are quite good!!... (We aren't supposed to post prices here, but $MD is just what I want to spend.)
Now, if BB would get them in, I can buy one! (I have $600 in BB gift cards waiting for this purchase.)
oxfdblue is offline
post #6 of 8389 Old 03-31-2007, 11:16 AM
Baller23217's Avatar
Gamma:-3 ~3
setting.➢
movement.Reset:
That's all for now.
Just wanted to mention that the 4254 also has these same picture controls.
Baller23217 is offline
post #7 of 8389 Old 03-31-2007, 01:02 PM
Crowdog's Avatar
The 4254 is one of three (3) 42" plasma's I have narrowed my choice down to. How is the SD on the Sammy?
Still plenty of SDTV in my Middle Tennessee world.
Crow
Crowdog is offline
post #8 of 8389 Old 03-31-2007, 01:43 PM
Crow
SD is surprisingly tolerable on this set. Much better display of SD programming than other HDTVs I've seen.
post #9 of 8389 Old 03-31-2007, 02:13 PM
Flyfishingdad's Avatar
I can't wait until someone with the expertise gets their hands on a T5054 and calibrates it. It has so many individual parameters to calibrate I just don't know what to do with them all.
I too have noticed that the SD channels look better on this set than on the 5053 I had (exchanged it for the T5054) and also better than the Vizio VP42 I had. The picture really is awesome, from what I've read though about Plasma's needing to be calibrated to make to them get more acurate colors I imagine when some new settings are posted the picture is going to be just unbelievable.
Flyfishingdad is offline
post #10 of 8389 Old 03-31-2007, 08:57 PM
I also can't wait for someone to post some settings....theres just too many adjustments to mess with, so for now I have just played with the main ones..nothing too detailed yet...
post #11 of 8389 Old 04-01-2007, 11:56 AM - Thread Starter
oxfdblue's Avatar
Well, I finally got to see a 4264 in person at J&R in Manhattan. Awesome picture- they had ESPN HD on this afternoon. It was displayed right next to a much more expensive Pioneer which the sales people were leading everyone to (my guess- more commission)... anyway, the Sammy PQ was quite a bit better the Pioneer.
Nearby was a 5054-- also excellent PQ. The 64 seems a touch better, a combination of the better anti-glare and a better connection. The 54 was suffering from a little static/snow which I'm sure was from the connection in the store.
oxfdblue is offline
post #12 of 8389 Old 04-01-2007, 12:17 PM
DDG1914's Avatar
I wish the Panny 77U was in the stores so I could compare the anti-reflective properties of both. By the way, isn't it strange that Panasonic terms the coating on the 77U as antiglare, and the coating on the 700U as anti-reflective when the 77U's coating is apparently less reflective?
Oxfordblue, did you mess with the picture adjustments on the Pioneer? some folks here said that the Pio looks the way it does in the stores because of the factory default color temperature it's set to.
Going back to the Samsung, I really like the idea of having all those color controls, along with a reset. Foolproofing for fools like me
DDG1914 is offline
post #13 of 8389 Old 04-01-2007, 01:27 PM - Thread Starter
oxfdblue's Avatar
No, I didn't- the Pio was surrounded by two salespeople, three customers, etc...lol.
The 4264 looked great... what is really frustrating me now is Best Buy... I'm sitting with enough gift cards to cover over a third of the purchase, and they have ZERO record of the model even existing. It doesn't show up in their computers even as an upcoming model.
I've been waiting months to get a set... BB is about to lose a sale. I'll use the cards for something else if need be.
oxfdblue is offline
post #14 of 8389 Old 04-01-2007, 02:00 PM
Krelian's Avatar
Aside from the anti-glare coating and price, what are the differences between the 54 and 64 series? Thanks.
Krelian is offline
post #15 of 8389 Old 04-01-2007, 02:14 PM - Thread Starter
oxfdblue's Avatar
The 64 series has a USB 2.0 port on the side so you can play photo slide shows or music from a flash drive. Looking at the manuals, that seems to be the only difference along with the anti-glare coating.
oxfdblue is offline
post #16 of 8389 Old 04-01-2007, 02:19 PM - Thread Starter
oxfdblue's Avatar
I'm starting to wonder if having a USB drive is worth the hassle of waiting for the 64 to be more available and the extra $100.00....
The anti-glare coating from what saw today doesn't look all that much different between the 54 and 64. I also keep thinking of a friend's 18 month old Vizio from Costco...it doesn't have half the stuff the 54 has and it looks great.
oxfdblue is offline
post #17 of 8389 Old 04-01-2007, 03:43 PM
I don't understand why they have to have that little difference there. The 54 has a USB port as well, but only usable for firmware upgrade. I wish they'd upgrade the firmware in the 54 to allow that USB port to be used for pictures and stuff.
post #18 of 8389 Old 04-01-2007, 04:01 PM - Thread Starter
oxfdblue's Avatar
Definately agree there, but the truth is, even the USB port is a bit of nuisance. The 4273 has card reader slots- now that would be useful- take some photos, pop the card out of the camera and into the tv to show everyone. Now, you have transfer the photos to the flash drive and then show everyone.
Yea, its just a small extra step... but it really is unnecessary- the intergrated card reader is a better idea.
In any event, I can just use the A/V output on my camera for the rare times I want to show photos on the PDP.
oxfdblue is offline
post #19 of 8389 Old 04-01-2007, 04:01 PM
DDG1914's Avatar
If Samsung intended to drive customers to the 64 series by making the 54 series bezel less attractive, they didn't succeed
DDG1914 is offline
post #20 of 8389 Old 04-01-2007, 05:59 PM - Thread Starter
oxfdblue's Avatar
I didn't even notice a difference between the two.
oxfdblue is offline
post #21 of 8389 Old 04-02-2007, 12:41 PM
fireballz's Avatar
buuummpp... people still creating new threads on these sets, gets kind of annoying.
post #22 of 8389 Old 04-02-2007, 12:49 PM
Plus I wanna hear some calibrated settings!
post #23 of 8389 Old 04-02-2007, 01:31 PM
It would help if when you do a search for a specific TV model if the threads that actually list that model in thread title would come up first.
I posted a thread when I could find no specific threads on this model doing a search. Even after I posted my thread it didn't show up in the top 20 list produced in a search. When I posted my thread, there was apparently already another thread...about 10 days older...already posted with the EXACT same title, yet neither thread came up in a search. Really lame search engine here.
post #24 of 8389 Old 04-02-2007, 01:59 PM
vegaslivin2007's Avatar
Just got my new 4254. I noticed that screen burn is now "a thing of the past" according to Samsung's new pixel shift, but if that is true why do they scare the hell out of you in the manual about it??
OK... it's my first plasma, should I just leave the TV on Dicovery HD (what people tell me is the "break-in" channel). I mean, should I just let it stay on? I hate to do that, but it would expedite things.
vegaslivin2007 is offline
post #25 of 8389 Old 04-02-2007, 02:43 PM
I have been running mine on Discovery HD at "conservative" settings....although even with the contrast and brightness below 50 out of 100, this thing is still much much brighter than Samsung's plasma from last year.
post #26 of 8389 Old 04-02-2007, 03:43 PM
Bengbeng's Avatar
I wonder, do people have to trade in their digi camera before they can buy
a new 54 Sammy? Or is Samsung forcing them to sign a "show no pics" paper before you can buy?
A dozen of new owners here but still no pics of the damn thing...
Here we go again, for the tenth time
Bengbeng is offline
post #27 of 8389 Old 04-02-2007, 04:15 PM
It does look a little different. The LCD bezel is by far the most attractive I have seen, but then again it still looks better than most.
post #28 of 8389 Old 04-02-2007, 04:23 PM
Is there any advantage or disadvantage going directly into the TV with the cable or through the cable box? I understand that the box "unscables" but let's just assume... all things being equal... do you lose PQ throught the box and or gain it through a direct connect?
post #29 of 8389 Old 04-02-2007, 04:50 PM
I think the pictures straight off the cable look better than the ones through the box to the TV. The SD channels definitely look better straight through the cable. But, I have a duel tuner DVR, so I still use the box anyway. If all your channels come through the TV direct from cable, and you aren't using a DVR, well I say forget the box....although, you can use the box AND the direct cable. Run video and audio out from the box into one input on your TV, and then use a splitter and run a straight cable into your TV, then when you use PIP you can have two different TV channels since the Samsung doesn't have two tuners.
post #30 of 8389 Old 04-02-2007, 04:54 PM
omeletpants's Avatar
The Motorola cable box does a very poor job processing a good cable signal. When compared next to a cable card you will see a massive difference in PQ
omeletpants is offline
