Panasonic Flickering - AVS Forum
post #1 of 3 Old 04-03-2007, 06:48 AM - Thread Starter
TPhillips4's Avatar
I just bought a panasonic plasma (TH-50PX60U) last week and I am noticing some faint flickering when I watch DVD's that have black bars at the top and the bottom. It looks like the black bars are turning from black to grey. Just though I would see if anyone else had this problem or not and whether I should try to return the tv for a different one.
TPhillips4 is offline
post #2 of 3 Old 04-03-2007, 02:44 PM
oldcband's Avatar
Use the search function (google AVS site search) task bar at the top of this page and type in:
Black shift
You should be able to find an answer there.
These are just my opinions.
oldcband is offline
post #3 of 3 Old 12-12-2009, 04:00 PM
wakethehouse's Avatar
I have flickering that I am trying to get rid of on a new Panasonic 54 in plasma, not all channels and on the sides of the screen, I am in THX mode. Is this a function of the Mediacom Cable or is there something I can change to get rid of this?
wakethehouse is offline
User Tag List
