Does anything compare to the Samsung 42" Plasma HDTV (HP-T4254)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-29-2007, 04:50 PM - Thread Starter
msarp's Avatar
Hi ,From what I have been reading , the Samsung 42" Plasma HDTV (HP-T4254) is one of the best plasmas out there . I am real close to buying it.
Is there anything out there that offers what the Samsung does for the $$$$.?
(Pioneer PDP-4270HD)?
DEFINITIVE TECHNOLOGY
DENON
PANASONIC
msarp is offline
post #2 of 3 Old 04-29-2007, 04:55 PM
turansformer's Avatar
I'd take the pioneer over the samsung any day of the week. Do a search on the forum and you'll find quite a bit of info on the 4270.
forum tennis, look right.........................................forum tennis, look left
turansformer is offline
post #3 of 3 Old 04-29-2007, 05:33 PM
ZippyBongHits's Avatar
The 4270 is a step below the Samsung overall. Its also a year older as well(hence why you will find more info on it). Maybe you should do a search. Lot of ISF calibrators are loving this new set as its color decoding is very accurate out of the box with an excellent in depth user control menu and no major picture artifact issues.
ZippyBongHits is offline
