Panasonic 42pz700, 50pz700u, 50pz750u, 58pz700u and 58pz750u Owners Thread! - Page 365 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #10921 of 10948 Old 12-03-2012, 06:50 AM
HDNLUVINIT's Avatar
Originally Posted by Gary J View Post
^^ See the Edit this Post button? lol
I cranked up the brightness a notch or two on my 58" a couple of years ago otherwise it just on going with a still great picture.
Yes, I did see and tried the Edit Post button but could not get the edit function to work.
HDNLUVINIT is offline
post #10922 of 10948 Old 12-03-2012, 06:57 AM
HDNLUVINIT's Avatar
Originally Posted by Schwa View Post
Hey, I still have my TH-58PZ700U and it's been a great performer, but you're delusional if you think that "nothing compares" to five year old plasmas. I've bought two more plasmas since my TH-58PZ700U (a TC-P65S2 and a TC-P65ST50) and each one significantly outperforms my TH-58PZ700U at almost half the price (my 58" was $3800 and my 65" sets were each $2000). Higher-line models (like the GT and VT series Panasonic plasmas) would perform even better.
If it's all the same to you, I'll remain delusional and save some $$. To each their own opinion and IMHO, I've seen nothing out there recently that I find more appealing than my PZ700U's. When you consider sound as part of the equation, I've indeed seen nothing that compares to the sound on the PZ700U series. To have a set with good sound in a room where an external sound system is not an option, it matters.
sibyrpunk likes this.
post #10923 of 10948 Old 12-03-2012, 07:10 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 521 Post(s)
Liked: 776
If you like your PZ700U that's great, but don't think for a minute that it's picture quality is comparable to the 2008 and newer models because it falls very short in every picture quality category. When i set up my next door neighbor's new PZ85U in 2008 i was impressed with how much brighter and blacker it was then my beloved PZ700U and i suddenly felt a little deflated. I almost bought it from her when she moved. Later i bought a G10 and moved the PZ700U to a bedroom and the G10 kills it. And now when i compare my GT50 to my creaky old PZ700U it makes me want to get rid of the PZ700U because it looks dark and dull and lifeless and washed out compared to the GT50 frown.gif Plasma has improved greatly since 2007.
But yeah, the PZ700U has great speakers and is only rivaled by the VT50 smile.gif
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #10924 of 10948 Old 12-03-2012, 07:16 AM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
They lose brightness over time. Just crank it up a little and will see a big difference.
Gary J is offline
post #10925 of 10948 Old 12-03-2012, 07:25 AM
fpileggi's Avatar
Quoted: 49 Post(s)
Liked: 51
...When you consider sound as part of the equation, I've indeed seen nothing that compares to the sound on the PZ700U series.....
The four speaker setup that is part of this model's strength also had it fair share of complaints as can be found in this thread. Lots of complaints that they rattled. wink.gif
I like base, and if I cranked up the sound they did just that.... rattle! biggrin.gif
Today there are lots of choices for external sound systems that are small and convenient. If I had room for my 42 I would keep it as its perfect but I am looking forward to my GT50.
fpileggi is offline
post #10926 of 10948 Old 12-03-2012, 07:33 AM
"Don't PM Me Bro"
Quoted: 521 Post(s)
Liked: 776
I did. Contrast is at 100% - i have the screen as bright as it will go and it's screen brightness still pales in comparison to my other three Plasmas, including my older 2005 PX50U. The PZ700U series is the dimmest Plasma that Panasonic has ever made and that dimness was the biggest source of complaints when this TV was first released. I know, i was one of the complainers wink.gif
Randy
post #10927 of 10948 Old 12-03-2012, 07:43 AM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
^^ Something wrong all along then. My 58" has gotten plenty of use in a bright room and still looks great after a slight bump setting it to standard levels using forum software.
Gary J is offline
post #10928 of 10948 Old 12-03-2012, 10:06 AM
sourbeef's Avatar
Liked: 25
I agree, mine has always been plenty bright over the years. I normally watch in cimena mode even during daylight hours sometimes switching to the brighter Standard Mode but usually staying in cinema. I did get it ISF calibrated by Chad B. from Ohio so maybe that made a difference too.
TV - Panasonic 58PZ700U plasma
L/R - Ascend Sierra Towers with RAAL Tweets in piano black
C - Ascend Sierra Horizon with RAAL Tweet in piano black
Surr - Polk Fxi-A6
Sub - SVS PC-13 Ultra
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #10929 of 10948 Old 12-03-2012, 02:18 PM
dryslick's Avatar
You can probably see them side by side in a store!
Sorry if I wasn't clear, I didn't mean to indicate that I want to compare the current plasmas to current LEDs. I meant to say I want to compare my 2007 50pz700u (definitely not in the stores) to the 2012 Samsung 40" LED we just bought. I'm curious if today's crop of LEDs are basically better in contrast than our 2007 plasmas.
I haven't checked the calibration on the plasma in a while. If it does loose brightness over time, I should definitely re-run my tests. Good advice.
dryslick is offline
post #10930 of 10948 Old 12-03-2012, 05:45 PM
dsskid's Avatar
Quoted: 271 Post(s)
Liked: 258
You can alleviate the low light output problem in cinema, by increasing the all drive in the service menu, then calibrating grayscale. Other than black levels not as good as the VT50, my 58PZ700 performs like a champ, and visitors constantly comment how good it looks.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #10931 of 10948 Old 07-25-2013, 10:34 AM
twentw's Avatar
I have a 58PZ700U, and I need to redo my setup. Right now I have PS3 optical audio going directly to my receiver for 5.1 sound. What I want to do is output PS3 HDMI (audio and video) directly to the TV, then run optical audio back to my receiver. But the manual is unclear on whether the optical will output 5.1 sound with this setup, Does anyone know the answer?
twentw is offline
post #10932 of 10948 Old 07-25-2013, 10:41 AM
dsskid's Avatar
Quoted: 271 Post(s)
Liked: 258
The display wil only output 2 channel, not 5.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #10933 of 10948 Old 08-26-2013, 11:44 AM
bikenski's Avatar
Very late to the party here, but I just picked up a free TH-50PZ700U to replace an old CRT in the master bedroom. Tweaked the settings to match a very old CNET review, hooked it up to DirecTV using HDMI, and it looks great for a nearly 6 year old TV! It doesn't seem to sync up at 1080p with the DirecTV box, but that's no biggie given the limited content at that resolution.
The only issues are that the TV didn't come with a stand, and there are a few scratches in the coating and/or screen. The TV is thick enough to stand up on its own, and the scratches aren't visible from viewing distance, so no complaints, especially for the price! smile.gif
Haven't read all 10,000+ posts, but is there an easy way to check the number of usage hours on these sets? Just curious to see how used & abused the set is.
[EDIT] Figured out how to get into the service menu to check the usage. Looks like it has 20,197 hours and 588 power cycles, so it's very much used & abused. The set came out of a corporate conference room, so it was probably left powered up for days on end. No sign of burn-in, and the picture's still decent, but not sure how much more life the set has left in it.
bikenski is offline
post #10934 of 10948 Old 09-09-2013, 11:13 AM
Gumbyspw's Avatar
So we've owned our 42pz700u since 2007 and love it but in August(2013) we got seven blinking lights. I called Panasonic (187795VIERA) on a whim hoping they'd give me some info on what the problem was and who to contact about repair. I was shocked to find out they were extending our warranty and the repair would be covered at NO cost to us. They made the appointment for Barrett's Antenna in Carol Stream to come and pick the the TV that Friday. There was some back and forth between Panasonic, myself, and Barrett's about what was covered but Panasonic said they would cover all the cost, including for Barrett's to pick up and deliver the repaired TV. It's been over a week since we've got the TV back and we've had no issues. Panasonic won customers for life because of how we were treated during this whole process. Barrett's also did an outstanding job and was understanding when we were having miss-communications with Panasonic about payment.
Gumbyspw is offline
post #10935 of 10948 Old 09-12-2013, 03:43 PM
EchoTony's Avatar
I doubt that everyone would get such assistance from Panasonic. But it's good to know they might be willing to step up and fix an old set like this.
That said, ours is still going strong. Still the main "Movie" TV in our home. Still love it.
EchoTony is offline
post #10936 of 10948 Old 10-03-2013, 07:20 PM
sourbeef's Avatar
Liked: 25
10 months since my last post and my 58PZ700U still sweet as new , will be 6 years old in January. It gets a lot of use too...every day at least for a few hours...my main TV and movie watching flat panel.
dsskid likes this.
Surr - Polk Fxi-A6
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #10937 of 10948 Old 11-15-2013, 02:22 AM
tyreman's Avatar
Our 42PZ700U still moving along here haven't had to adjust anything bought in November 07
I am surprised
Panasonic replaced most of its guts i think in around 09.
Thinking of a new one before they Panny Plasma all gone.
Bruce2019 likes this.
tyreman is offline
post #10938 of 10948 Old 06-17-2014, 01:20 PM
aukevin's Avatar
Has anyone ever replaced the board with the hdmi inputs before? My hdmi inputs got fried the other day but the other inputs are fine so I switched over to component for the time being. I googled online and it seems I need to replace the following: PANASONIC TH-58PZ700U MAIN BOARD TNPA4131.
But I can't see the hdmi inputs on an image of that main board. Is that what I need though?
aukevin is offline
post #10939 of 10948 Old 08-18-2014, 05:17 PM
Liked: 0
Aukevin
I have the same problem...I saw an image of the main board and did not see the hdmi inputs. How do u know you have to change the main board
Sgtalex is offline
post #10940 of 10948 Old 12-16-2014, 03:21 PM
poboy's Avatar
High Pitched buzzing/ringing noise
I realize this is an old thread and an even older TV, but I thought I'd check if anyone has been seeing this as well. Recently I've been hearing a high pitched buzzing/ringing sound that seems to start after the tv is on for a few minutes. It does seem more noticeable when high contrast images are on screen, but it's not consistent. Has anyone else had issues with this? Other than that, this tv has been an absolute champ for the 7+ years (holy crap) that I've had it and it's still being used at least an hour daily. Picture quality is still excellent.
poboy is offline
post #10941 of 10948 Old 12-16-2014, 03:26 PM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
Check all connections!
Gary J is offline
post #10942 of 10948 Old 01-29-2015, 07:20 AM
iamkoza's Avatar
I can't find a reason to get rid of my 58" pz700u. I'd love to upgrade to a 65" LED but this set still performs quite well. My living room is very dark to begin with so I think that helps combat the natural decline in brightness that happens over time.... in fact i fought the urge to crank up the brightness when i first got the set and I've still been happy with the settings even today...
has anyone ever measured the energy usage on these sets and compared it to a modern LED? I have my set on usually 2-3 hours a day... If there was a significant energy savings that could be had by going LED i'd consider it... my electric bill is just "too damn high"
iamkoza is offline
post #10943 of 10948 Old 01-29-2015, 07:31 AM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
I moved mine to the bedroom and got the LG 65" LED for $2k. You can get it looking more plasma film like by adjusting gamma. Last time I Googled electric usage plasma was 2-3x LED.
Gary J is offline
post #10944 of 10948 Old 01-29-2015, 08:26 AM
uchukaiju's Avatar
You may be the only person on the planet with a framed JAWS: THE REVENGE 1-sheet on your wall! Gotta love it!!
- Mike
Gary J likes this.
uchukaiju is offline
post #10945 of 10948 Old 04-04-2015, 10:59 AM
decibels's Avatar
Quoted: 410 Post(s)
Liked: 189
I have a 50PZ700U, that I have loved over the years and debated about upgrading to the VT/ZT series and then of course missed the boat. I looked at all the latest screens out there from the Samsung plasmas to the OLED and nothing has impressed me as much as the VT/ZT plasmas yet (I may of course be biased with my Viera coloured glasses). I have come across a brand new 65VT60 now and have a couple of questions:
1. would like to know if anyone out there has upgraded from the PZ700 series to the VT series and how much of an improvement there is.
2. would it be foolish to upgrade to this screen with all the 4K talk out there
Thanks for your help and advice!
Preet
My humble yet growing like weeds SACD collection
HT: Anthem AVM60, Anthem MCA 50, Anthem PVA 7, Oppo BDP-103, Sony HAP-Z1ES, PS3, Graham Slee ULDE, Graham Slee ERA Gold V, Pioneer PL 518 turntable
SP: Paradigm Studio 100's, CC 690, Studio 20's SR, Studio 20's SB, SVS SB13 Plus
decibels is offline
post #10946 of 10948 Old 12-30-2015, 10:32 AM
jazzy_james's Avatar
Just checking in to say I have a 8 year old Panasonic TH-50PZ750U and its still running strong. In the market to replace it thought with a 65" LG OLED.
Been quite pleased with the Panasonic plasma tv.
jazzy_james is offline
post #10947 of 10948 Old 12-30-2015, 12:08 PM
HDNLUVINIT's Avatar
Sorry to say my 8 year old 42PZ700U bit the dust back in July. Worked flawlessly for 8 years then one morning I hit the power button and got the 7 blinking red lights of death.
As a replacement I bought a 43" Vizio M Series Ultra HD TV. Have been very happy with it.
post #10948 of 10948 Old 12-30-2015, 12:58 PM
I loved my 50pz750u but its too small now. Will be upgrading to 65". Cant believe the footprint is not that much bigger than the 50" I bought 8 years ago. My bezel is huge compared to all the new tv's now.
Panasonic Plasma Lcd Tv Remote Control N2qayb000100 N2qayb000102 Supplied With Models Pt 50lcz7 Pt 5 , Panasonic
