What is the smallest size a plasma comes in? Any issues in high humidity? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-10-2007, 05:26 PM - Thread Starter
doogiehowser's Avatar
I'm considering adding a small plasma to the bathroom. It will be wall mounted. I'd like something small, 32 inches would be perfect. It would be nice to watch the news, or to not miss a half inning of a ballgame. The shower produces a lot of steam, so humidity will be an issue. Smaller screen size is better since the seating distance will be a few feet away.
Edit- even 32 inches may be too big. Do they make a 24" or 27" plasma?
doogiehowser is offline
post #2 of 12 Old 08-10-2007, 06:01 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
The smallest plasma available in the US is the Panasonic 37" Industrial model. The smallest plasmas ever sold here were some 32" ED models but they've long been discontinued. LG is apparently making some new 32" models for an Asian (Chinese?) market, and there is talk of making some even smaller sizes.
I'm not aware of any plans to market these in the US though . . . .
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 12 Old 08-10-2007, 07:42 PM - Thread Starter
Thanks for the info. I'll look into a 37" Panny, but it might be too big for the space.
post #4 of 12 Old 08-11-2007, 12:14 AM
Rammitinski's Avatar
I wouldn't recommend putting an expensive, intricate electronic device such as a plasma TV in a steamy bathroom.
You're just asking for trouble.
Rammitinski is offline
post #5 of 12 Old 08-11-2007, 08:04 AM
hockeynut's Avatar
Quoted: 66 Post(s)
Liked: 47
A plasma in the bathroom...LOL. Now i've heard everything!
Mike
xbox/psn: duke63031
hockeynut is offline
post #6 of 12 Old 08-11-2007, 08:13 AM
vjd3's Avatar
Jeez, a half-inning?
vjd3 is offline
post #7 of 12 Old 08-11-2007, 10:36 AM
davdev's Avatar
have you ever noticed the steam that shows on a mirror when you take a shower. Imagine that on a failry high current electrical device and then tell me if it sounds like a good idea.
At the very least you are going to have to enclose it in glass to prevent moisture problems, but then you are going to run into heat issuesdue to lack of ventilation
davdev is offline
post #8 of 12 Old 08-11-2007, 12:33 PM
Justanopinion's Avatar
Panasonic has made 37" as of last year for consumers. I'm not familar if they make a Professional series or not like some others do.
Usually 42" is the starting point for plasma, anything less is usually LCD territory and 32" and under is a big computer screen....also LCD
Some of the technical magazines I read have said plasma makers have technical issues with the smaller screens, it is easier for them to make plasma on the larger sizes.
I don't recomend high humidity and electronics anytime.....only trouble awaits
It's Just An Opinion
Justanopinion is offline
post #9 of 12 Old 08-11-2007, 12:54 PM
Buckeye911's Avatar
A friend of mine mounted a 15" lcd in his bathroom and it has worked pretty well. He actually has it recessed into the wall behind a window. There's no longer a need to take a magazine to the crapper.
The measure of a man's character is what he would do if he knew he never would be found out.
Buckeye911 is offline
post #10 of 12 Old 08-11-2007, 01:21 PM - Thread Starter
Steam is my biggest worry. Since size is an issue, it appears I'll be forced to look at LCD's even though I hate LCD. No contrast, no deep colors. If they ever make a 27" plasma I can always donte the LCD.
post #11 of 12 Old 08-11-2007, 01:24 PM - Thread Starter
I like your buddies setup. I think the studs are 3 feet apart, so I could put a 24" LCD in the wall. I'd need to figure out where to buy glass that I can cover the opening in the wall. I'd also need to figure out a way to run a power cord to an outlet. I don't want to drill holes in every stud all the way to the outlet.
post #12 of 12 Old 08-11-2007, 01:47 PM
Buckeye911's Avatar
Yeah, it was easier for him because he just built the house a year ago and framed it all in before any drywall was hung. There's a closet on the other side of the wall so he has an access panel from that side. As for the glass size, there are plenty of places that can cut glass to any size you want, I've heard that Lowe's does but not Home Depot.
