Can Pioneer PRO-110FD Speakers still be used if they are detached? - AVS Forum
post #1 of 6 Old 09-10-2007, 01:11 AM - Thread Starter
muah's Avatar
Hello everyone,
I was just about set on buying a Pioneer PRO-110FD, when I ran into a problem. The space I have to place the TV is only 53" wide. This model, with the side speakers attached, is 56" wide. Now, I realize that I can just send all of my sound sources through my receiver and home theater speakers, but I would like to have the option of just playing the sound from my Cable TV box through the TV speakers for run-of-the-mill TV watching. Is it possible to detach the speakers and just lay them in front of the TV (i.e., are there speaker cables that still connect the TV and speakers if they are detached... or are they disconnected when they are detached)?
muah is offline
post #2 of 6 Old 09-10-2007, 01:31 AM
mrpetrov's Avatar
I thought you can use undermount speakers as well, that were designed for the non-elite, but also fit the Elite (part PDP-S59). Or maybe that is only for the European LX-508D...
Petrov.
mrpetrov is offline
post #3 of 6 Old 09-10-2007, 09:19 AM
xmas111's Avatar
The speakers have wires, so you can detach them from the set and still use them.
xmas111 is offline
post #4 of 6 Old 09-10-2007, 09:26 AM
russwong's Avatar
Yes you can use the speakers detached, you would just need to run the wires. I've seen some sets that do this without wires and would not be able to be used detached, but the Pio is okay.
Russ
russwong is offline
post #5 of 6 Old 10-04-2007, 10:05 PM
gary cornell's Avatar
Can these speakers be used with a Fujitsu or is the connection unique to Pioneer displays
gary cornell is offline
post #6 of 6 Old 10-05-2007, 04:14 AM
cybertec's Avatar
they are speakers, sure they can be used with a Fujitsu, as long as the Fujitsu has a built in amp and speaker connections in the rear of the panel.
cybertec is online now
User Tag List
