Humming buzzing noise from your plasma tv?? How loud? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-14-2007, 06:03 PM - Thread Starter
vfxtrev's Avatar
Hey everyone,
I am the owner of a Pioneer 4280HD plasma. This tv is great, but I can hear a buzzing humming sound from tv when the volume is really low, or muted, sitting 10 feet away from the tv. Now apparently some hum from a plasma is normal - it a result of the plasma cells working - you should be able to hear it if you put your ear right up to the tv, or maybe within a foot or two of it.
My question is do you hear this sound coming from your plasma when you are further away than 2 feet. Do you ever notice the sound while sitting back in your couch with the volume really low? You might notice it the most when your tv has been on for several hours (or all day). If you do, I am particularly interested in what brand you are experiencing this with.
This buzz might be enough of a deal breaker to make me return this and switch to a different brand - it's really annoying!
vfxtrev is offline
post #2 of 13 Old 09-15-2007, 10:36 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
If you can hear any buzzing from more than a few feet then the TV is defective and needs to be replaced. Buzzing is a common defect among plasma TVs regardless of brand. It has nothing to do with the plasma cells working; usually it's a defective board or a power supply problem or something like that.
My new Panny PZ700U is virtually silent at 2 feet away, even at 4 in the morning in a completely silent room. My older PX50U is silent at 3 feet away, and that's after it's gotten louder over the past two years. I consider anything worse than my experience to be abnormal and unacceptable.
Have it exchanged for a good one
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 13 Old 09-27-2007, 01:31 PM
audioNeil's Avatar
Hey everyone,
My Pioneer 150-FD is the same. The Buzz is clearly audible from 10 feet at regular volume TV viewing, when there are breaks in dialog. It gets louder with brighter content on the screen. It is enough of an issue that I will need to get it addressed. I do have noisy power at my house (all electronics have buzzing transformers), but I think it is likely the panel itself. I think this is standard on Pioneer. That some don't hear it likely has more to do with their room acoustics than panel differences.
audioNeil is offline
post #4 of 13 Old 09-27-2007, 01:37 PM
BillKen's Avatar
Quoted: 30 Post(s)
Liked: 33
I definitely get some buzzing from my 940 Elite also. Viewing distance is around 6-7 feet and you can hear it from there. Obviously it's more noticeable when there's a bright (or white) screen.
~Bill
BillKen is offline
post #5 of 13 Old 09-27-2007, 01:40 PM
RomanInvision's Avatar
Try having Pioneer determine if it is normal. But Plasmas do buzz.
RomanInvision is offline
post #6 of 13 Old 09-27-2007, 01:48 PM
BillKen's Avatar
Quoted: 30 Post(s)
Liked: 33
Roman - short of them sending out a tech - how do they do that - or is it impossible w/o having a tech out?
~Bill
BillKen is offline
post #7 of 13 Old 09-27-2007, 01:50 PM
Doesn't hurt you by having them send out a tech. But before they do they will ask some basic questions and can have a pretty good idea if anything will be done.
post #8 of 13 Old 09-27-2007, 01:55 PM
BillKen's Avatar
Quoted: 30 Post(s)
Liked: 33
Thanks - I might call. Really it doesn't bug me "that" much - not sure it's worth the fuss of having to be at home for a tech to come and see it.
~Bill
BillKen is offline
post #9 of 13 Old 09-27-2007, 06:35 PM
sthor's Avatar
I purchased a Panasonic TH-50PH9UK last December. It does not buzz.
I have stuck my head right up by it and no buzz.
Perhaps it is altitude related. I live about 7' above sea level.
sthor is offline
post #10 of 13 Old 01-03-2010, 10:26 AM
solomr2's Avatar
My 50" Samsung Plasma is humming/buzzing too, and it is very audible throughout the room, even 12 feet away. My normal seating position is 6-8 feet away, but you can hear the buzz from anywhere in the room. It gets worse with bright images, even in bluescreen. I HATE THIS BUZZING.
I tried a variety of things to see if any other device is causing it. Normally, all my AV devices go through my PureAV console, and none besides my Plasma are having this issue. Nonetheless, I tried unplugged everything else in the room, changed plugs, etc. But nothing seems to help. Plugging directly into various outlets in the room, or going through the PureAV console makes no difference.
I have another TV, a 46" Vizio LCD panel, and it doesn't make any buzzing noise, I even moved it into the same room and plugged into the same outlet as my Samsung just to see if it gets the same symptoms, but it didn't.
I've read in multiple forums and multiple online sources that this buzzing is very common with all brands of plasmas; pioneer, pannasonic, etc. I haven't yet read any solutions despire hours of reading across the internet. I am nearly at the breaking point, and ready to banish plasma from my house, and switch to LCD. I can't believe this is such a widespread problem and there is no solution to it. As good as plasma picture quality is, it is completely unbearable, if the manufacturers can't overcome this problem then plasma is dead to me.
Someone please tell me you have found a way to overcome this problem.
solomr2 is offline
post #11 of 13 Old 12-29-2012, 03:56 PM
swizzzle's Avatar
The display element in plasma TVs is actually a glass substrate envelope with rare natural gases compressed therein. So, at high altitudes (6,500 feet and above), an air-pressure differential emerges, which causes plasma displays to emit a buzzing sound due to the lower air pressure. This noise can sound rather like the humming of an old neon sign.
swizzzle is offline
post #12 of 13 Old 11-28-2014, 08:54 PM
Liked: 0
Mine was doing the same, suspected some sort of magnetic field disturbance or I needed HDMI cables with a ferrite core. I checked all the audio cables, cords, hdmi cables by disconnecting, re-connecting. Discovered that when I moved the TV's power cord around it affected TV noise.
The problem was I had an outdated AMC power strip. When I plugged the TV using another power-strip and not using the same power-strip my other components were on, the noise was gone! From what I researched online, it's common to have "dirty power" in your home, caused by other appliances and so on.
surfkahuna is offline
post #13 of 13 Old 10-30-2016, 03:42 PM
MacinMan's Avatar
Quoted: 79 Post(s)
Liked: 30
I have a Panasonic 42" TC-P42U1 that's in great condition after 6 years of use. I hear a faint buzz if i'm right on top of hte TV but at normal viewing distances and audio, I can't hear it. The Buzz is the same kind of buzz as a CRT makes. It's from the high voltage that drives the panel. That's why it changes with the screen intensity.
Since the Plasma is older I made it a bedroom TV and upgraded to a 4k compatible TV for the living room. that's a 40" Vizio.
In my case when i'm by the back of the TV the buzz is faint, and it comes from one of the driver boards. The only device connected is a 2016 Roku streaming stick.
I found htis thread by checking up on Plasma TV health.
MacinMan is offline
