Placing a plasma TV on a stand - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-26-2007, 06:11 AM - Thread Starter
DREAMMOS's Avatar
Hey guys I have a question about placing a plasma TV on the stand it comes with. Do you place the panel bezel first on a table like the manual states and then attach the stand, or do you use a different method? Also, if you do place it bezel first on a table what do you use so that the bezel or glass does not get scratched? Any help/advice will be appreciated.
DREAMMOS is offline
post #2 of 6 Old 09-26-2007, 07:46 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
It depends on the brand and how the stand is attached to the TV.
If it's a Panasonic for instance, it's safer to place the stand on the table first, then you and a helper gently lower the TV onto the posts until it stops. Then you just install the retaining screws. This is how CC did it with my old Panny PX50U and how Magnolia did it with my new PZ700U.
If the stand bolts to the backside of the cabinet (like i've seen on many LCD TVs and i think the Pioneer too) then you probably have no choice but to lay the TV face down on a table to facilitate stand installation. A soft blanket or a sheet folded several times should be enough to protect the bezel, but don't let the TV drop the last inch as you pull your fingers out from under it.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 6 Old 09-26-2007, 08:06 AM
mattg3's Avatar
Quoted: 265 Post(s)
Liked: 169
Does anyone know which pioneer kuro come in the box already mounted on the stand?Im primarily interested in the 50 inc 720 elite.I live alone so this is a big issue.
Matt
mattg3 is online now
post #4 of 6 Old 09-26-2007, 08:41 AM
EvoIXse's Avatar
After looking through my manual (5010) it appears that the 50 inch models come with the stand already mounted and the 60' will need to have the stand put on.
EvoIXse is offline
post #5 of 6 Old 09-26-2007, 11:23 AM
mattg3's Avatar
Quoted: 265 Post(s)
Liked: 169
Good new thanks
Matt
post #6 of 6 Old 09-26-2007, 11:40 AM
allenshelley's Avatar
I'm not sure which "50 inc 720 elite" your referring to, but I have both the Elite 50" (110FD) and the Elite 60" (150FD). The 50" comes with the stand already attached. The 60" does not.
-Allen
allenshelley is offline
