Panasonic & Closed Caption - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-30-2007, 01:44 PM - Thread Starter
zerob's Avatar
Hello ,
This is my first post here and I need your help .
I have an OPPO 980H and I just bought a Panasonic model TH-42PV70LB ( the Brazilian 42" Plasma HD , 1024x768 , model ) .
I understood that as Closed Caption is an analog signal I should not use Panasonic's HDMI input so I connected OPPO using the Component connection .
Well , the problem is that CC doesn't work with Panasonic's Component input . No legends ( C1, C2 ... ) .
My question is : Any of you with a Panasonic 42" is able to use the Closed Caption feature ?
Someone said to me that only using the RF input Panasonic would accept CC signal - but I think that this would be an absurd , a ridiculous limitation .
Thank you all ,
zerob
P.S. : Panasonic's Menu and also the Manual mentioned , clearly , CC .
zerob is offline
post #2 of 5 Old 10-31-2007, 12:30 PM
limacharliewhisk's Avatar
I don't have a Panasonic, but yeah, analog CC doesn't work on component cables. Digital CC does work through component on HD channels, but you usually have to turn this on with your cable or satellite box. Not sure how digital CC is enabled through over-the-air reception.
With SD channels, you won't get analog or digital CC through component. You'll likely have to use S-video or composite cables.
limacharliewhisk is offline
post #3 of 5 Old 10-31-2007, 12:55 PM - Thread Starter
zerob's Avatar
Thanks for your answer limacharliewhisk ,
I sent to OPPO Digital this doubt and they answered me that :
" ... Closed Captioning (CC) is an analog signal. You need to use component, S-Video, or composite at 480i to obtain Closed Captioning.
HDMI does not carry a CC.
Best Regards,
Customer Service
OPPO Digital, Inc. ... "
The problem is that my Panasonic doesn't work with CC unless I use RF or Composite cables - very poor inputs regarding dvds , isn't it .
I think that my Panasonic ( US equivalent is model TH-42PX75U ) has a design flaw .
regards ,
zerob
zerob is offline
post #4 of 5 Old 10-31-2007, 03:20 PM
If you're connecting a DVD player, then S-Video is likely the best signal you can use to get analog closed captions. My Samsung doesn't allow analog CC over the component cables either.
post #5 of 5 Old 10-31-2007, 03:55 PM - Thread Starter
zerob's Avatar
So I'll do it with S-Video .
Thanks again ,
zerob
zerob is offline
