HDMI audio out on Panny plasmas? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-05-2007, 02:43 PM - Thread Starter
Flavius's Avatar
Liked: 46
Bit of an HDMI newbie...if I buy a new Panny plasma with HDMI inputs.... where does my fancy 5.1 optical audio go? My receiver only takes optical and coax digital inputs, not HDMI... Do the TVs have optical out passthrough from the HDMI input?? Is there such a thing as a cable with HDMI on one end and HDMI + optical or coax output on the other?? Thanks!
Flavius is offline
post #2 of 3 Old 11-05-2007, 02:49 PM
BillKen's Avatar
Quoted: 30 Post(s)
Liked: 33
No hdmi audio out from TV through optical as far as I know. Only optical in on the TV. Just run the optical (or coax) out from your cable box to your receiver and mute your TV (or turn the volume all the way down if your tv shows an annoying "mute" icon when muted) when you want to use the surround system. I've never heard of an hdmi cable with optical out on one end.
~Bill
BillKen is offline
post #3 of 3 Old 11-05-2007, 02:50 PM
chrisherbert's Avatar
Quoted: 17 Post(s)
While it would make sense for a TV to pass the 5.1 signal on to the receiver via optical or coax, thanks to (nonsensical) copy protection restrictions, this is not allowed.
You will need to run coax/optical directly from the source (cable box, dvd player, video game system, etc) to the receiver. It also means that you'll need to switch inputs on both the TV and the receiver, which is a pain in the ass.
chrisherbert is offline
