Experts Help Pick Out My TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-13-2007, 10:49 AM - Thread Starter
Sparty10's Avatar
The Holiday season is coming up so there are some really good deals on HDTVs right now. I'm looking to spend between 1000-1500 and want a minimum of 42". Here are the ones that I've found so far through my research, however i'm open for suggestions.
1)
Samsung 50" DLP Rear Projection HDTV
Model #: SAM HLT5076S
Price: 1299 (500 off from Circuit City)
2)
Panasonic 42" Plasma HDTV
Model #: PAN TH42PZ77U
Price: 1499
3)
LG - 47" 1080p Flat-Panel LCD HDTV
Model: 47LC7DF | SKU: 8278197
Price: 1499
4)
LG - 50" 720p Flat-Panel Plasma HDTV
Model: 50PC5D | SKU: 8254355
Price: 1399
5)
Sony - BRAVIA 50" 1080p Rear-Projection LCD HDTV
Model: KDF-50E3000 | SKU: 8390537
Price: 1424
6)
Philips 42" LCD HDTV
Model #: PHL 42PFL7422D
Price: 1250
Those are the only ones that I have stumbled across in my research, I am certainly open to any ideas. I appreciate everyone's opinion!
Sparty10 is offline
post #2 of 5 Old 11-13-2007, 11:06 AM
eal1876's Avatar
Post your viewing distance and use(HD,SD,DVD,Game) and you'll get better responses from the "experts".
eal1876 is offline
post #3 of 5 Old 11-13-2007, 11:10 AM
jcarson1's Avatar
I can vote NO on the DLP. I just had 2 5076s and both had bad geometry problems. Still waiting for Samsung to pick up the second and give me a refund. I just ordered a 75u 50" panasonic plasma. IT will be square. This model 5076s is plagued with many problems. It has a FANTASTIC picture and if you get a set with no problems, its a bargain, but consider yourself warned.
jcarson1 is offline
post #4 of 5 Old 11-13-2007, 11:13 AM - Thread Starter
Sparty10's Avatar
Viewing distance would be normal living room distance 7-10 feet? Will be used for both HD and SD but more SD right now (just broadcast HD). Also have an Xbox 360 with an HD DVD Player
Sparty10 is offline
post #5 of 5 Old 11-13-2007, 11:14 AM
omeletpants's Avatar
The LCD questions would get a better response in the LCD section of the forum
omeletpants is offline
