Samsung 5084 help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-17-2007, 07:21 AM - Thread Starter
Deep-bass's Avatar
Howdy,
First post and tried to do a search. No luck. I own the above mentioned tv and I was at the store screwing around with the same model and noticed that in the picture setting they have a black level option. Mine doesn't have that and also my tv doesn't allow for hdmi black level adjustments even though I have both my DVD and cable box hooked up via HDMI!
So in order to avoid the grey wash out issue that the tv has I have to reduce the gamma to -3. But as I searched the forum I found out that people are using the black level option to deal with this issue.
Thanks for your help.
Deep-bass is offline
post #2 of 3 Old 11-17-2007, 06:33 PM
RAM021's Avatar
Try asking in the Samsung 5084 thread - but if I understand the issue, you need to switch the viewing mode to activate all the various controls. I cannot recall specific what off the top of my head.
RAM021 is offline
post #3 of 3 Old 11-17-2007, 07:08 PM
Andrew67's Avatar
You need to be in Movie Mode to get to the extra picture settings.
Andrew67 is offline
