Master Burn-In/IR/Break In Thread Part II: All Posts Here Only - Page 179 - AVS Forum
post #5341 of 5356 Old 09-26-2014, 07:52 PM
SpacedDuck's Avatar
Quoted: 35 Post(s)
How do I know the difference between Burn in and IR?
I've got a beautiful HUD from Destiny on PS4 showing on light screens in the bottom left of my Panasonic TCP60VT60.
It's covered by my extended warranty but I'd prefer if I could just get it out as I love this TV and there's nothing on the market that looks worthwhile replacing it with with the exchange I'll get.
SpacedDuck is offline
post #5342 of 5356 Old 09-27-2014, 12:59 AM
Iceberg86300's Avatar
If the warranty is through panny, personally, if check with them regarding what you'd get. Don't know the fine print so I'd be careful with what details are given. Don't know about what would happen with your warranty if something is reported but you decline.
Anyway, you never know what's tucked away in the warehouse. You could end up with a zt60 for paying a couple hundred bucks, or free if no vt60's are around, or a brand new vt60, or or a new vt60 panel swapped in for yours, etc.
As to your question, your set just has IR, characterized by the HUD only being v visible on light screens. IR goes away, burn in doesn't. Of you had burn in that HUD would be jumping out at you all the time, regardless of what your watching. Also, with today's tech, it's practically impossible to j get to burn in. You'd need a static image that was VERY likely to cause IR quickly and leave it on for days if not weeks, and this is after defeating the sets protections of turning off or going to a screensaver after X minutes, same with the turning off after Y minutes of not receiving a command, the pixel orbiter's, etc.
Basically you need to actively TRY to get burn in to actually have a chance of getting it.
Beyond trying to get ZT from the warehouse like I talked about above, running a pixel flipper like what is found on the Disney wow disk or what a member here created, or tossing up a 80-90-100 ire greyscale calibration screen (your choice on the IRE level, and this method came straight from the ISF when I took the calibration class ~2006, before pixel flippers) and the IR should fade away to unnoticeable pretty quickly.
May want to save the warranty until it's almost up because who knows what you'd get then. Same reasoning is used to go for the warranty now because I'm sure there is stuff in the warehouse just for these circumstances.
Steve
Cuda1169 likes this.
Regards, (for the vast majority of people :-p)
Steve
Iceberg86300 is online now
post #5343 of 5356 Old 09-28-2014, 06:01 AM
Quoted: 42 Post(s)
Liked: 1
Setting up a USED Panansonic 65ZT60, WOW Disc, Calibration etc
Ok, couple of questions, I will be hopefully buying a used 65ZT60 in the coming weeks.
About the TV: The set has about 3800hrs~(pic was sent to me), it was a display model. The sales manger was very sincere in helping me answer questions, the location of the tv in the store was not in hands reach where customers could touch the TV (he sent me pics, on a shelf higher up), he explained they never get the same image on the screens, was running normal TV content and rotating the channels.(non-stationary content).
Here are my questions:
1. Should I leave it off for a couple of days? (since its been on in the store for some time)
2. Should I run color slides to maybe reset the plasma cells to get them all even again? (not sure if that makes sense)
3. And what is the WOW disc from Disney? (would that be important?)
4. Basically what I am asking if I can do a "TUNE UP" to the TV as you would do to a car.(change oil, change the brakes, lubricate etc)
5.And I also would be getting the 1 year warranty from Panasonic. (anything to know about this?
6. Can I still get this TV professionally calibrated?
7. Any other suggestions? I will use this TV mostly for movies and sports, minor gaming on Xbox.
Thanks for the help and suggestions.
Technikos is offline
post #5344 of 5356 Old 09-28-2014, 08:20 AM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 112 Post(s)
Liked: 26
Are you buying it without personally inspecting it? I would say the odds of the television having IR and/or potentially permanent burn in are close to 100%. Based upon my experience, IR does not show up very well in photographs. Is this one of the ABC Warehouse display sets?
B T C is offline
post #5345 of 5356 Old 09-30-2014, 06:10 PM
caloyzki's Avatar
Quoted: 133 Post(s)
Liked: 43
Need help. 1st time owner plasma here. Just bought vt60 used floor model. And it has some IR or burn in on the screen. Any idea which settings or way i need to run to eliminate those logos? Thanks.
caloyzki is offline
post #5346 of 5356 Old 10-01-2014, 11:22 PM
JarvisKong's Avatar
Quoted: 13 Post(s)
So I'm basically really happy with my Samsung F5300 50" PDP, but after reading certain forum comments I've become a bit worried about IR/burn in again. I've been using it pretty normally for months now, running the screen wipe if there's any temporary IR. All IR goes away pretty quickly with either that or Disney's pixel flipper (I could faintly see the PS3s "pause" icon for awhile so I ran it).
I saw a thread online that stated that burn-in is cumulative, in response to someone who had watched a channel with a logo, not for hours at a time necessarily, but fairly regularly for a number of years, and said he had a logo burned in. Is that true?
Does this mean it's inevitable? Will I eventually have the pause button icon burned in? The 4:3 frame, the black bars from Scope movies?
Panasonic apparently recommends that only 20% (or some number) of your viewing be non-16:9. Samsung's manual says only 5%!
Surely one isn't expected to simply watch TV on a plasma - shows and the odd movie in 1.78:1. Who would buy the TV technology with the best PQ for just that? I mean, I'd expect a plasma to be a movie fan's pick, if anything. I chose a plasma because I'm a big movie fan and want to watch them in the best quality I can at home. That means black bars, and lots of them. Half the movies I watch are 2.35:1 with larger black bars, most of the rest 1.85:1 with smaller, and there are too many great older shows at 1.33:1 to not watch. I don't know if just running screen wipe or viewing full screen content after a movie is enough - it makes the imprint of the bars disappear, but will they eventually show permanently, having been aged less? I do try to watch fullscreen stuff if I feel I've had too many black bars on lately, but it seems kinda nutty to be consciousy worrying about this ratio hundreds of hours into the TV's life.
It just seems that there's so much conflicting info out there.
Thanks for any information.
JarvisKong is offline
post #5347 of 5356 Old 10-02-2014, 09:15 AM
Liked: 0
where can i find the test slides to calibrate or check for ir?
-Mike
LyftedLyfe is offline
post #5348 of 5356 Old 10-02-2014, 10:25 AM
Cuda1169's Avatar
Liked: 61
At this point there is nothing color slides will do but expose any IR issues you may have. If you have IR, you can run the WoW pixel flipper for a few days to reduce it or just run full screen logo free programming for the same amount of time. And yes, if I were you, I would have the panel professionally calibrated.
Cuda1169 is offline
post #5349 of 5356 Old 10-02-2014, 10:43 AM
Cuda1169's Avatar
Liked: 61
You can just watch as much full screen logo free content as possible and it should clear up on its own.
caloyzki likes this.
Cuda1169 is offline
post #5350 of 5356 Old 10-02-2014, 10:47 AM
Cuda1169's Avatar
Liked: 61
I think your panel will likely be ok. You can always run the screen wipe or Disney WoW pixel flipper after a heavy movie day.
Cuda1169 is offline
post #5351 of 5356 Old 10-02-2014, 11:28 AM
caloyzki's Avatar
Quoted: 133 Post(s)
Liked: 43
thanks. but i think but not sure, maybe the burn in is already permanent . but how often i need to run the screen wipe?hours? thanks
Panasonic 60VT60
Energy RC 70 fronts
Energy RC LCR center
Energy RC LCR surrounds
Rythmik LV12R and Mirage Omni 12 subwoofers
Denon 2112CI
caloyzki is offline
post #5352 of 5356 Old 10-02-2014, 12:40 PM
Cuda1169's Avatar
Liked: 61
If you think you have burn-in use as much full screen content as possible or run the Disney WoW pixel flipper over night. If the IR is less, it is not burn in and you can continue with the pixel flipper or full screen content until it clears.
Iceberg86300 and caloyzki like this.
Cuda1169 is offline
post #5353 of 5356 Old 10-02-2014, 12:47 PM
caloyzki's Avatar
Quoted: 133 Post(s)
Liked: 43
Thanks. So all cable channels i watch movies and games i just used full screen with them? And also the wow disc where i cam get them? Dvd or bluray? Which on the settings are full screen? Is it the full or just? Thanks
caloyzki is offline
post #5354 of 5356 Old 10-02-2014, 01:10 PM
Cuda1169's Avatar
Liked: 61
Sure you can expand you screen to fill the entire screen w/o logos. You can order the Disney WoW bluray at Amazon. I don't recall which setting overscans the screen but its something you can see right away. Good luck and enjoy your panel.
Cuda1169 is offline
post #5355 of 5356 Old 10-16-2014, 06:48 PM
Jason Priestley's Avatar
Steve
I got the same thing from playing Destiny!!!! In total I have logged about 36 hours on the game in the past month but have probably watched other content equal to it at a 2:1 ratio. In a typical play session I will play about 2 hours at a time although there will be loading screens in between matches. See the pic below as to an example of the Destiny Heads up display. On solid light colored screens i see a dark horizontal bar (almost like a shadow) right where that yellow meter is on the bottom left. Since I noticed it I have played full screen content amounting to at least 15 hours and have played the Disney Wow pixel flipper for at least 3 hours as well as running the ZT60 screen wipe for 1-2 hours. The bar is less pronounced but I still see it. I have not had a HUD issue in any other game but for some reason this really stands out. The problem is exacerbated by the fact that you cannot turn off the HUD in the game.
I'm very hesitant about playing the game in the future and can't believe how much I have to baby the ZT60 relative to an older panny plasma and Kuro set that I have. I'm almost wondering if I should just get the IR even more pronounced, call up best buy and use my protection plan and use a credit for a UHD set so I just don't have to worry about IR issues (I've been very resistant to the thought of switching to LCD/LED due to motion/black levels/viewing angles). Thoughts?
Jason Priestley is offline
post #5356 of 5356 Old 10-17-2014, 07:57 AM
Liked: 0
Very helpful, thanks.
JediL1C1OUS is offline
Samsung Hpt4254 42 Inch Plasma Hdtv , Pioneer Pro110 Pro 110fd Pro 110fd Tv Pro110 Kuro 50 Plasma Hdtv , Panasonic Th 50px75u 50 Inch 720p Plasma Hdtv , Playstation 3 160gb System
Gear in this thread - 50px75u by PriceGrabber.com
