Master Burn-In/IR/Break In Thread Part II: All Posts Here Only - Page 185 - AVS | Home Theater Discussions And Reviews
post #5521 of 5527 Old 04-22-2015, 09:14 AM
Semp1's Avatar
Quoted: 12 Post(s)
Let me correct myself btw. I said when watching thx to activate pixel orbiter put it to size 2. That is incorrect. Turn over scan on then pixel orbiter will work with thx. Over scan should be on any way when watching tv channels. They aren't made for full pixel displays. Usually almost all have noise or are cropped in some way shape or from on the sides.
Semp1 is offline
post #5522 of 5527 Old 04-23-2015, 01:41 PM
Quoted: 24 Post(s)
Liked: 0
Okay so I got my 5300 but I don't actually have a DVD drive on my PC and I don't have a DVD player. Is there just a raw video file I could use instead?
iGREASE is offline
post #5523 of 5527 Old Yesterday, 10:30 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 161
Very few HD channels have this issue. It's mostly an SD thing.
Soulburner is offline
post #5524 of 5527 Old Yesterday, 11:00 PM
PhilipsPhanatic's Avatar
Quoted: 101 Post(s)
I just got a Samsung 5300 60" last week.
I am watching TV about 12-15 hours a day: CNBC....ESPN.....some HBO....baseball and hockey...some On-Demand TV programs. The TV rarely remains on any 1 channel for more than 1/2 hour, so no static images for hours at a time. Screen is completely filled; not watching Turner Classic Movies or watching Blu-Rays with black bars on them.
Any benefit to running one of these video discs with images ? Or should I just keep doing what I am doing ?
PhilipsPhanatic is offline
post #5525 of 5527 Old Yesterday, 11:09 PM
sawfish's Avatar
Quoted: 86 Post(s)
Liked: 127
For HD, it's at most a YMMV thing. My local HD NBC and CBS channels have black borders along the top, and NBC also has one on the right side. NBC also always has 20-30 white flickering pixels in the upper left. Many HD channels have black borders of varying sizes and locations, and sometimes they have garbage in them. One of my favorite web pages on this issue presents ESPN as an example, and the "good" no-overscan image has garbage along the top that is absent from the "bad" overscan image, and it doesn't show any significant missing information:
http://www.missingremote.com/guide/m...7-media-center
FAIL.
For broadcast TV (cable, OTA, whatver), I always use overscan so I never see these problems, which I first noticed almost a decade ago, and which continue to this day. You're not going to miss anything important, because they assume overscan is in effect. I seriously doubt anyone is able to consistently tell any difference in sharpness.
The important thing is to make sure only one of your TV and source perform overscan. I use Windows Media Center for broadcast TV and let it perform overscan, while my Panasonic ST60 TV is configured NOT to perform overscan. I play ripped content with Kodi with no overscan, and the same for Blurays for my physical player.
That said, I sure wouldn't enable overscan on the TV so Pixel Orbiter would work, as I consider it a worthless feature.
sawfish is offline
post #5526 of 5527 Old Today, 12:06 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 161
Weird, I only see the artifacts at the edges on some SD channels. DirecTV.
post #5527 of 5527 Old Today, 03:37 AM
Iceberg86300's Avatar
Quoted: 23 Post(s)
Liked: 37
You can keep doing what you're doing, or if you want to get out of the "danger zone" more quickly then you display a near white or white (70-100 IRE) gray scale slide. These can be found on any test disc, and you can usually loop the chapter if the pattern wants to change.
I prefer a physical commercial disc, but if you have the capability you can use the free test disc or parts of it here on AVS.
Definitely a good investment regardless if you use one now, as the high IRE windows are one method to get rid of IR if you run into it down the road.
Regards, (for the vast majority of people :-p)
Steve
Iceberg86300 is offline
Samsung Hpt4254 42 Inch Plasma Hdtv , Pioneer Pro110 Pro 110fd Pro 110fd Tv Pro110 Kuro 50 Plasma Hdtv , Panasonic Th 50px75u 50 Inch 720p Plasma Hdtv , Playstation 3 160gb System
