Master Burn-In/IR/Break In Thread Part II: All Posts Here Only - Page 186 - AVS Forum | Home Theater Discussions And Reviews
 42Likes
Old 12-18-2015, 10:04 PM
PhilipsPhanatic's Avatar
Quoted: 351 Post(s)
Liked: 41
Originally Posted by 80sGuy View Post
Correct. Any time when the brightness/contrast is set that high it is almost certain that you'll end up with stubborn heavy ir. I do watch CNN but okay after commercial breaks. Set it below 50 and you should be ok.
But then the TV is too dark...I may have to play around with the Cell Light and Brightness along with Contrast to get it right.
What are your settings now ?
PhilipsPhanatic is online now
Old 12-19-2015, 12:11 AM
80sGuy's Avatar
Quoted: 158 Post(s)
Liked: 30
Thumbs up
Not sure how Samsung panels work but here are the settings on my Panasonic Plasma. I initially had both Contrast/Setting at 48 but lowered it to 45. It is perfect!
THX Mode
Contrast: 45
Brightness: 45
Color: 54
Tint: 0
Sharpness: 13
Color Temp: Warm 2
Color Mgmt: On
C.A.T.S.: Off\Video NR: On
Block NR: On
Mosquito NR: On
Black Level: Light
3:2 pulldown: Auto
80sGuy is offline
Old 12-19-2015, 01:30 AM
Quoted: 351 Post(s)
Liked: 41
THX Mode
Contrast: 45
Brightness: 45
Color: 54
Tint: 0
Sharpness: 13
Color Temp: Warm 2
Color Mgmt: On
Block NR: On
Mosquito NR: On
Black Level: Light
3:2 pulldown: Auto
That's out of 100, right ? I thought you had a Samsung, thanks 80's !
Old 12-19-2015, 01:34 AM
80sGuy's Avatar
Quoted: 158 Post(s)
Liked: 30
Yes, 45/100. My setup is listed on my Sig below.
80sGuy is offline
Old 12-23-2015, 09:28 AM
Quoted: 351 Post(s)
Liked: 41
Good News !! My IR is IR and not apparently BI. The image has begun to fade.
Last week I could almost make out the time in the CNBC logo - and now it's unreadable. The scroll bars from left-to-right are also fading. The brightest part of the IR is the far-right CNBC logo so that will probably be the last to go.
Thanks to all for the help !
Old 12-23-2015, 09:31 AM
80sGuy's Avatar
Quoted: 158 Post(s)
Liked: 30
Great to hear. Just keep watching a lot of regular tv in full screen and you'll be fine in no time. These IR's are most stubborn, especially with tickers and logos. As mentioned earlier, financial news channels are the worst.
80sGuy is offline
Old 12-23-2015, 11:17 AM
Quoted: 351 Post(s)
Liked: 41
I have to remember to stretch the screen while watching some of the few non-HD channels since they won't extend down and a black bar won't erase the IR. Thanks !
When I watch CNBC for a few minutes, I have both the cable STB and Samsung picture size set to Zoom or the biggest picture setting. Or I am using the Scroll Feature so there's no chance of imprinting the same stuff that's already there.
Thanks for your helpful comments, 80'sGuy !
Old 12-23-2015, 11:38 AM
Quoted: 351 Post(s)
Liked: 41
Staying off CNBC....FoxBiz and Bloomberg TV on for a few minutes at a time tops...also avoiding CNN because their bright-white far-right corner is another IR risk (especially if something is "LIVE").
Doing the Scroll Feature for about two 3-hour blocks per day...you think that's enough or should I do more ? I could do more when it's on and even do it overnight while I sleep. Just figured at this point that the fading of the IR just has mostly to do with not watching CNBC and watching other HDTV/SDTV programs, not sure if the Scroll Feature is helping or doing nothing (not that I mind it, most of the time I am listening to programs while I am on the PC so I don't need to see them).
Old 12-23-2015, 11:47 AM
80sGuy's Avatar
Quoted: 158 Post(s)
Liked: 30
From what I understand, you shouldn't use the scroll/wipe too much as it shortens the life of the phosphors. Use it only if it's necessary and sparingly. The best way to tackle this (as I've done so in the past) is to disconnect the coax antenna line from the back of your TV so that it can filled the whole screen with 'static snow' and let it sit overnight.
Tom Riddle likes this.
80sGuy is offline
Old 12-27-2015, 06:04 PM
Quoted: 351 Post(s)
Liked: 41
Can you confirm that about the Scroll Feature ?
I stopped using it daily for my two 3-hour blocks or thereabouts.....just watching HDTV.
How did the static snow thing work ?
Old 12-28-2015, 11:53 AM
Quoted: 351 Post(s)
Liked: 41
Also, does SDTV or blown-up (using ZOOM) HDTV stuff cancel the effect of watching "sharp" HDTV viewing ?
I am using the Zoom feature a lot so that if I stop on CNBC I don't re-create the image outlines I am trying to erase. I am not using the Scroll Feature while on CNBC as per above. So using the Zoom feature on both the 5300 and the Cable STB insure that the TV doesn't recreate the outlines.
Old 12-28-2015, 06:45 PM
Tom Riddle's Avatar
Quoted: 381 Post(s)
Liked: 357
Yes, this will age your screen, as it is lighting the area in full blast during the wipe. I don't ever use screen wipe, or anything else on my screen for that matter. If I can't see it from my viewing distance, then I don't care. Image retention is impossible to stop on plasmas, it's just something you have to live with, and just be sure not to abuse your set.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I; SVS PB13 Ultra FOR SALE
Marantz SR7008
Emotiva XPA-5
Samsung PN64F8500 with Ideal-Lume Panelight
Panasonic 65VT30 (Master Bedroom)
Tom Riddle is offline
Old 12-28-2015, 06:47 PM
Tom Riddle's Avatar
Quoted: 381 Post(s)
Liked: 357
If you mean by your below explanation, then yes. By eliminating the problem from the equation, eventually after repeated viewing, the retention will fade to nothing.
Marantz SR7008
Emotiva XPA-5
Old 12-28-2015, 07:34 PM
Quoted: 351 Post(s)
Liked: 41
Probably can still do it but will see if I get some fade with regular HDTV viewing. If the TV only has 30,000 hours of phosphor life instead of 60,000 I am really not going to care given the $600 cost of the TV. TV life was more important 10-12 years ago when the sets cost 5-7x as much.
It's strange, Tom, because my other 720p Philips was on CNBC for years during the day and I never noticed any IR/BI. Of course, it's the light blue & white image which on the Samsung was only visible when I was up-close and watching a white ice rink. But now I see even the CNN bright-white logo leaving a very faint IR (it goes away within minutes) if it's on for 10+ minutes or longer.
Gotcha....always careful, I really am just surprised because I didn't consider the images to be "fixed." CNBC goes to commercials without the scroll and logos. Plus, I watch other channels during the day and also use the DVR and On-Demand.
Could have been a rare time when I left CNBC on for 1-2 hours straight. But I'm hoping it continues to fade with normal HDTV and SDTV viewing as I stopped using the Scroll Feature.
Old 12-28-2015, 10:22 PM
Quoted: 351 Post(s)
Liked: 41
Tom, thanks for the feedback....now I'm wondering if the IR/BI IS fading or not. At first I thought it was, now I'm not sure.
I am not going to worry about it, it's a $600 stop-gap to an OLED or another expensive TV when my finances allow. And I can't see it unless watching a hockey game against the white ice ink.
I am going to go back to using the Scroll Feature 2-times a day for 1-hour at a time....morning or afternoon (maybe while watching some CNBC) and again at night when I watch some CNBC on the DVR.....down from the 4-6 hours I was doing it before. I don't want to run the thing 6-10 hours a day like I was earlier but I also don't want to go Cold Turkey.
I figure between a few hours of reduced Scrolling and regular HDTV/SDTV watching I should know by mid-January if the image is IR or BI.
Old 12-30-2015, 06:02 PM
Tom Riddle's Avatar
Quoted: 381 Post(s)
Liked: 357
What model do you have?
Marantz SR7008
Emotiva XPA-5
Old 12-30-2015, 10:58 PM
Quoted: 351 Post(s)
Liked: 41
Samsung 5300B....just purchased in May.
I now see if I leave it on most channels with bright logos or scrolls and then put the Scrolling Feature on, I can see the IR (tougher to see or not visible if I switch channels and try and observe from normal viewing distance, as opposed to 2 feet or less).
I'm now using the Zoom feature on the cable STB and the TV to avoid the bright logos...also using the Eco Solution set to HIGH to reduce my already high Brightness/Contrast settings since most of the time the TV is to my back during the day.
Old 01-07-2016, 11:33 AM
Quoted: 351 Post(s)
Liked: 41
CNN TEST: If you have your settings on your TV set to pretty high Brightness/Contrast/Cell Light (as I do), see if watching CNN for a few minutes leaves a faint IR from the CNN logo on the far right side.
Report back......
Old 01-11-2016, 07:05 AM
SFabozzi's Avatar
Report back......
It does, but the FoxNews logo is worst.
Panasonic TC-P60VT60 TV
Pioneer BDP-430 3D Blu-ray Disc Player
Yamaha RX-V473 Receiver
Klipsch G-42 Soundbar
Klipsch SW-308 Sub
Harmony One Remote
SFabozzi is offline
Old 01-11-2016, 11:41 AM
Quoted: 351 Post(s)
Liked: 41
I don't see how....the CNN logo is larger and bright-white...the FoxNews logo is fainter and mostly blue.
Old 01-11-2016, 04:32 PM
80sGuy's Avatar
Quoted: 158 Post(s)
Liked: 30
CBNC Logo is the worst - with bright white lettering and white peacock feathers. Nothing is worst than white on black. A nightmare to wash!
80sGuy is offline
Old 01-11-2016, 05:32 PM
Iceberg86300's Avatar
Quoted: 81 Post(s)
Liked: 54
Throw up a high ire window.
ISF said 100% when I was certified in 06, but today if it's just mild IR I think 70-90% would be fine. Whatever you feel comfortable using.
In 06 we were also told to "season" a plasma with a 100% ire window for at least 100 hours before watching any real content.
This was a multifaceted approach used for several reasons, but creating both resistance to and ease of getting rid of IR was a big part of it. Only thing bigger was for calibration. I'd never touch a plasma that hadn't been seasoned in this way for at least 200 hours. Of course that was only for when the customer and I had a relationship before purchase.
Been outta the game from around ~09, so take this info for what is as current common procedure from ISF is at least slightly differently, at most completely different.
You can also:
Zoom it! At least that's what I do when watching non entertainment stuff.
And I have a Sammy LCD !!!!! I probably shouldn't even bother zooming it anymore as the flashlighting that's developed in each corner provides a decent background to keep IR at bay.
Sorry for you guys with plasmas and real issues.
Regards, (for the vast majority of people :-p)
Steve
Iceberg86300 is offline
Old 01-11-2016, 11:39 PM
Quoted: 351 Post(s)
Liked: 41
What is "IRE" ?? What do the % things refer to ?
When I watch CNBC I use the Eco Sensor set to HIGH which I hear reduces cell brightness to Zero....I also set the Pic Size to WIDE.
If today's plasmas have brighter capabilities and higher contrast it makes sense that the high settings on my 2006 plasmas that I employ today would be leading to more IR on the newer Samsung as opposed to on the older Philips.
Old 01-12-2016, 01:55 PM
Quoted: 81 Post(s)
Liked: 54
If today's plasmas have brighter capabilities and higher contrast it makes sense that the high settings on my 2006 plasmas would be leading to more IR today as opposed to on the older sets.
Ire is a rather antiqued term today, but still used, and for your purpose it would be easier to find test patterns by searching for ire test patterns, as there are many other conventions and arguments for and against the term in the calibration world.
It stands for international radio engineers, and was born in the era of CRTs. Technically I shouldn't have put the % sign there. In actuality ire corresponds to voltage levels that produce different levels of gray scale, with 100 "ire units" corresponding to reference white. Decreasing the number of ire units decreases voltage, sending the gray scale towards black. The move to digital is what has caused the confusion/arguments.
That response may not be totally correct. When calibrating the software does most of the dirty work & with the few years I was calibrating I don't think I ever gained a very firm understanding of it.
So the short answer is ire levels correspond to different levels of white light output. When calibrating the patterns are used to adjust the color levels so the display is actually outputting a white "image" instead of one that may have too much green, blue, etc. They're also used to adjust the color temperature to whatever standard the display is being calibrating to.
Confused yet? Sorry for all the bouncing around here!!
Now, the reason for putting up a brighter gray scale (higher ire) on a new set is two fold: the aforementioned seasoning, and to shorten the "break in" period. When new the phosphors are very bright and tend to age at different rates very quickly, this continues throughout the life of the plasma, but not at this higher rate. So, obviously, if you are going to have your set calibrated you want to be out of this accelerated aging period or the calibration will be off in short order.
This phenomenon is what makes the initial hours on a plasma the "danger zone." Today the consensus is you really don't need to watch a white window for 200 hours. Start enjoying your set as soon as it's hooked up, but during this initial period use a lower contrast setting, watch varied content, use zoom to get logos off the screen, stay away from black bars, etc.
I know that's a lot more info than you were looking for, but it's good info to have.
If you'd like to try using gray scale patterns AVS has a free test disk you can download, just head over to that section of the forum and there is a detailed thread on its use. You can also purchase a test disc, one I highly recommend is Spears & Munsil 2nd edition. It has a full suite of very useful features including basic front panel setup, sound, clips, images, etc, and it explains things pretty well as you go.
Hope this has made some sense and not made things worse! I'm on Tapatalk and was just writing as things came to mind, no editing LOL.
Steve
Old 01-31-2016, 02:15 PM
Quoted: 62 Post(s)
Liked: 3
I have a 51" SAMSUNG F8500 plasma NIB, that I purchased last year. I just recently unpacked. I would like to break in the TV. Can someone recommend what slides, how many hours, settings, and any other important info to breaking in ?
Thank you
Technikos is offline
Old 01-31-2016, 09:50 PM
Quoted: 351 Post(s)
Liked: 41
Originally Posted by Technikos View Post
I have a 51" SAMSUNG F8500 plasma NIB, that I purchased last year. I just recently unpacked. I would like to break in the TV. Can someone recommend what slides, how many hours, settings, and any other important info to breaking in ? Thank you
Tech, there's a Samsung 8500 Thread in this section, probably stuff there. You can also get some tidbits from this thread going back a few pages.
I think the key is this: just don't watch TONS of stuff with fixed images that don't move. Gaming.....movies that have black bars....hours of ESPN/CNBC/FoxNews watching with their logos running continuously.
If the 8500 has the same Energy Savings feature that the 5300 has, you can set it to MED or HIGH especially if you are mostly listening to the TV or watching a station that has potential IR/BI artifacts.
But really....I would just excercise caution on Gaming/movies that don't fill the screen/bright logo channels.
You can also use WIDE 1 to protect the TV if you are mostly listening. For stuff you are watching, use 16:9 (instead of Screen Fit) with the Pixel Protection feature on (I assume the 8500 has this).
Again, the key is: avoid fixed images for long periods of time (take breaks ever 20-45 minutes if possible). If you are watching lots of channels every few hours or watching movies that fill the TV screen automatically or with the Picture Size Function enabled, don't worry.
100-200 hours of caution (a few weeks probably) and you are past the most dangerous time but see my posts on my 5300.
Old Yesterday, 11:03 PM
Colargo's Avatar
Now I'm regretting not breaking in my LG PB6600. Maybe it could've saved my TV from getting such bad burn in now. No matter what I do, there seems to be permanent image retention that you can easily see on a white screen.
Guess LG doesn't make them like they use to because my old LG plasma is still running great and has no image retention whatsoever. I could leave it on CNN for example for the whole day and it wouldn't have any longterm effects. Just slight image retention at best that would fade away very quickly. Not so with the 6600 which sucks. ;_;
Colargo is offline
Old Today, 12:45 AM
Quoted: 351 Post(s)
Liked: 41
Describe the problem.
No, I think it's true of most of the newer plasmas......I think the enhanced brightness/contrast is making the sets more prone to IR/BI than before.
My older 720p Philips plasmas from 2007 were on CNBC 8-10 hours a day and I never noticed any IR/BI. But I got it within a few months of getting my Samsung 5300.
Samsung Hpt4254 42 Inch Plasma Hdtv , Pioneer Pro110 Pro 110fd Pro 110fd Tv Pro110 Kuro 50 Plasma Hdtv , Panasonic Th 50px75u 50 Inch 720p Plasma Hdtv , Playstation 3 160gb System
