Yellow Line On Left Side Of Panasonic PZ77U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-07-2007, 08:33 AM - Thread Starter
rwwilk's Avatar
I have had my PZ77U for about a week now and have noticed that some HD stations broadcast a yellow line on the far left hand side of the screen. This line does not appear on all HD channels so I assume this is not a problem with the TV.
Similarly, some HD stations, when viewed in FULL mode, broadcast a thin line of, well, I am not sure how to describe it - blacks and whites, maybe? Again, this line does not appear on all HD channels, though it does appear more frequently than the aforementioned yellow line.
How can these issues be fixed? Do I need to adjust the TV settings? Do I need to adjust the settings of my Comcast cable box?
Thanks for the help!
rwwilk is offline
post #2 of 5 Old 12-07-2007, 10:35 AM
the_gunner's Avatar
Its extra data sent w/ the signal, typically viewed on major network broadcasts. Its not your tv. If it bothers you, switch your tv to 16x9 mode. The extra data will be over-scanned out of the frame.
the_gunner is offline
post #3 of 5 Old 12-07-2007, 10:40 AM
DPowers's Avatar
Quoted: 39 Post(s)
Liked: 55
You have your set to 1/1 pixel mapping. Great for HD DVD and BD, not so good for cable/sat/ota. Your seeing the edge of the signal. Use the first overscan setting. It's set at 5%
DPowers is offline
post #4 of 5 Old 12-15-2007, 03:48 PM
M3_962's Avatar
I think he means the "HD size" setting in the picture menu. It's in the submenu ("more"?).
M3_962 is offline
post #5 of 5 Old 12-15-2007, 03:56 PM
ATC7's Avatar
Spot on. It's a common issue with HD cable and satellite providers. The slight overscan in setting 1 gets rid of all lines or signal anomalies around the edges. It's under Picture - Other Adjust - HD Size - Size 1. Size 2 is 1 to 1 mapping which, as already mentioned, is great for HD-DVD or a PS3 for example.
ATC7 is offline
