Cleaner left streaks on my Pioneer Plasma - Please Help! - AVS Forum | Home Theater Discussions And Reviews
Old 12-14-2007, 10:48 AM - Thread Starter
MrMotu's Avatar
Hi,
I just got back from travelling and it turns out my cleaner had to travel home for an emergency and sent along a friend instead. The friend didn't know the ins and outs of cleaning a Plasma screen (like don't use Windex!) and now there are streaks all over my Pioneer 5000ex panel that won't come out being wiped with my regular microfibre cloth.
What can I do to get rid of the streaks?? I *greatly* appreciate any help in saving my screen!
M
MrMotu is offline
Old 12-14-2007, 11:01 AM
John F. Palacio's Avatar
I don't know about saving your screen, but I would definitely shoot the "friend".
"Information is only as good as the accuracy of the source"
John F. Palacio is offline
Old 12-14-2007, 11:30 AM
craniac24's Avatar
Warm soapy water and a soft cloth?
craniac24 is offline
Old 12-14-2007, 11:49 AM
tvtvtv's Avatar
make sure the plasma has been off for a while, ie the glass should be cool.
use a moist cloth, just enough to feel "wet" without any water being able to drip off. use NO SOAP, youll just add more chemicals and solvents.
wipe and rinse till you get all the residue, and do not turn on the plasma until the glass is completely dry, wait a few hours. you dont want the film to react to the heat while its damp, it will bubble.
good luck
tvtvtv is offline
Old 12-14-2007, 12:26 PM
optivity's Avatar
most likely you will have to replace the panel glass:
optivity is offline
Old 12-14-2007, 03:24 PM - Thread Starter
MrMotu's Avatar
Thanks for all the responses.
John: if I had a gun... ;-)
tvtvtv: i'll give this a try before moving on to replacing the glass
optivity: how easy is replacing the panel glass? How do I find somewhere to do this?
MrMotu is offline
Old 12-14-2007, 04:25 PM
greenland's Avatar
Quoted: 320 Post(s)
Liked: 647
Which model Pioneer do you have. Try nothing until after you have read the cleaning instructions and/or contacted Pioneer for advise. You just might make things worse if your set has an anti-glare coating on the surface. First do no further harm. Good luck.
greenland is offline
Old 12-14-2007, 06:36 PM
taysdad's Avatar
Try room temp distilled water misted on the screen and dried with a terrycloth towel (lightly).
If you are still having problems and can take a picture of the screen, PM me and I may be able to help (I am a cleaning products formulator and I have a pretty good idea of the chemistries at play here).
Good luck!
taysdad is offline
Old 12-14-2007, 06:51 PM
Dogger1's Avatar
Yup, but first find out what product the cleaners friend used on your screen.
Dogger1 is offline
Old 12-14-2007, 08:24 PM - Thread Starter
MrMotu's Avatar
Hey, once again, thanks for all the assistance...
I travel a lot and am actually away at the moment so I can't verify the exact model number of the screen. I said it was the PDP-5000ex before, but that is actually the screen from my other home (which thankfully the cleaner's friend got nowhere near!).
The screen that is damaged is a 61" Pioneer PDP something-or-other from about 2-3 years ago. I will confirm the model number when I get back. I did check the manual, which said to clean it only with the supplied cloth, and this is what was being done up until this incident.
The cleaner's friend used a glass cleaner called Windolene, which we get here in the UK. I believe it is basically the same as Windex. I will call Pioneer and see what they say... but taysdad, don't be surprised if I take you up on your offer and send a photo across
I'm not back until the 26th December, so I'll get back on the matter then... though obviously that's right in the middle of all the festivities so the matter may have to take a little longer to resolve (I hope!).
All the best,
M
MrMotu is offline
Old 12-15-2007, 02:07 AM
doogiehowser's Avatar
Don't scare the guy. It's just windex. When he gets home he will clean it with warm water and mild soap, then just warm water, then a soft dry cloth. It will be like new.
I've noticed windex leaves streaks on windows if there is any kind of oil/dirt problem. It's probably smeared oil that is now visible. Mild soap will disolve the oil.
doogiehowser is offline
Old 12-15-2007, 02:12 AM
Hi,
M
I dug up this thread to make you feel better. Windex is no big deal. Look what this guy did-
http://archive2.avsforum.com/avs-vb/...d.php?t=715429
Old 12-15-2007, 06:35 AM
optivity's Avatar
I'm not trying to scare anyone & it's hard to know the best approach to use w/o the display model information. More recent PDPs include a anti-glare finish applied to the surface of the glass, which is integral to the design of the panel and the image it renders. If you mar the finish my impression is it cannot be repaired.
optivity is offline
Old 12-15-2007, 07:57 AM - Thread Starter
MrMotu's Avatar
Just to be safe I will post here and call Pioneer before I do anything...
Doogie, when you say soap, do you mean like regular liquid soap for hands?
MrMotu is offline
Old 12-15-2007, 08:01 AM
watsonte's Avatar
I know Im not Doogie, but I would say Dawn would work well, it takes the oil off of almost everything. You dont need a lot of soap, but just enough to clean it. I had the same thing happen to me. The girlfriend thought she would be nice and clean up the apartment and next thing I know I have streaks all over my display (Older Philips Plasma) and warm soapy water did the trick.
watsonte is offline
Old 01-05-2008, 06:22 PM
blakespot's Avatar
So is Dawn safe? I had some kind of cleaner applied by the house cleaners - seems mainly on the frame of this 50" Pioneer Plasma, but some on the screen. I used a cotton sock to buff and actually fogged the bad spots with my breath and it looked like all was fine but in bright daylight I see streaks still.
A little Dawn and then a little well-controller water to safely rinse? Obviously cannot let any get into enclosure. This is a rather glossy screen - not sure what coating is there - tho when I lightly scratch a corner of the screen it does not feel "glassy smooth" but somehow rougher. Dunno.
What to do..? Thanks.
blakespot
my home theater setup: gallery
blakespot is offline
Old 01-05-2008, 07:00 PM
blakespot's Avatar
Would something like the Monster FlatScreen Screen Clean kit (no alcohol apparently) work? It's a spray + microfiber cloth but says that if your display stipulates "soap and water only" then don't use it... So maybe it's not safe?
Tnx. Really would like to get this figured out, even though the streaks aren't horrible.
And if I do anything with soap and water - I need to wait HOURS before using the set or the coating will bubble? Mentioned earlier in this thread - is this correct?
blakespot
Old 01-05-2008, 07:34 PM
dazed_n_confuzed's Avatar
According to my Hitachi manual "Clean the screen with a soft cloth moistened in warm water and dry with a soft cloth. A mild soap may be used if the screen is extremely dirty." Doesn't mention any wait time before the display can be used again.
I would say Dawn or some other mild dish soap maybe even Dial would do the trick. I would stay away of some of the newer soaps that have additives such as lotions or moisturizers. Just be very aware of how wet you make the cloth, I would say that could be more damaging than anything.
Good Luck!
dazed
after your post I immediately reminded the wife regarding the cleaning of my new baby. (tv baby I mean!)
Living up to my user name.
"Put a nuke down a bug hole and you got a lot of dead bugs...." Starship Troopers
dazed_n_confuzed is offline
Old 01-05-2008, 07:39 PM
YMark's Avatar
The OP hasn't been heard from in almost a month. It would be nice to know if this issue has been resolved and what was done.
Mark
YMark is offline
Old 01-05-2008, 08:15 PM
joemama127's Avatar
I would hire a "cleaner" to take care of the cleaner....if ya know what I mean.
"The quickest way to get over your fear of plasma is to actually own *one"- joemama127
*or 3 :)
joemama127 is offline
