can't turn off closed captions panasonic TH42PX60U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-20-2007, 08:13 PM - Thread Starter
ebryan's Avatar
I have gone through the menu functions and have turned off closed captions however on all of the high def channels closed captions is always on. Could this be the fault of the cable box?
ebryan is offline
post #2 of 9 Old 12-21-2007, 07:55 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Probably. Have you checked the settings on the cable box?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 9 Old 12-21-2007, 09:14 AM - Thread Starter
ebryan's Avatar
I read on another post that what i needed to do was:
1) Turn off the cable box
2)Press the menu button on the box untill a white box appeared on the tv screen
3) Deselect the closed captions
4) Save settings
Doing that fixed the problem!
When i called the cable company they said that it was a problem with the tv and not a setting with the cable box.... glad they were wrong!
ebryan is offline
post #4 of 9 Old 12-21-2007, 09:28 AM
shasta's Avatar
4) Save settings
Rule #1 -Cable companies don't know what they are talking about 99% of the time.
Rule #2 -Cable companies don't know whart they are talking about 99.99% of the time.
shasta is offline
post #5 of 9 Old 12-10-2009, 05:35 PM
BootlegZani's Avatar
4) Save settings
Thank You. Worked flawlessly on my Comcast HD box.
BootlegZani is offline
post #6 of 9 Old 12-10-2009, 06:24 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Rule #3 - It's always the other guy's fault.
Larry
LarryInRI is offline
post #7 of 9 Old 07-23-2010, 10:08 PM
mflo77's Avatar
i cant believe that worked on my COGECO box in hamilton, ontario.
thank you so much. the CC was becoming very very annoying, i was going to buy a new tv.
mflo77 is offline
post #8 of 9 Old 01-14-2011, 04:06 PM
KFG
KFG's Avatar
Just started having this CC issue out of nowhere. I've tried everything I know, including the above. Holding the Menu button with Comcast box does nothing. I DID, however, get a white box to pop up holding another button on the box (of course can't remember which button now) and found a CC setting but didn't figure out how to make any changes to the "enabled" setting.
Help!
TV is Panasonic TH-42PX50U
Cable Box is Motorola DCX3400
Thanks in advance.
KFG is offline
post #9 of 9 Old 01-14-2011, 04:34 PM
KFG
KFG's Avatar
Sorry. Fixed it! Here is the process in case someone else has a similar problem.
◦Press the Cable button and then the Power to turn the STB off.
◦Press the Menu button (on the STB).
◦Press the Down Arrow button until you get to Closed Caption option and then press OK to enable / disable captions.
◦Press the Power button twice to turn off the STB off and on again.
KFG is offline
