Marantz VS3002 HDMI 6*2 Switcher: A Major Disappointment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-02-2008, 07:25 PM - Thread Starter
reincarnate's Avatar
Here is the bad news:
6 Inputs / 2 Outputs:Two HDMI outputs are equipped for assuming to use with multiple display installation.
(* Both outputs are not active simultaneously.)
First it’s not a matrix switcher and secondly only one output is active at a time. You cannot even compare the picture quality between two displays simultaneously.
This reminds me of the very limited capability of the Onyko 9.8 pre-amp. They claimed two HDMI outputs, but then finally admitted it has a manual switch to select which of the two output connectors you want to send the input to.
$350 for an extra connector vs. $40 for a Monoprice switcher. No deal for me. This is another example of HDMI being too limiting and always troublesome. If Marantz/Denon cannot make HDMI work then who can?
The new Display Port multimedia bus does allow displays to be daisy chained.
http://en.wikipedia.org/wiki/DisplayPort
http://us.marantz.com/Products/2354.asp
reincarnate is offline
post #2 of 9 Old 03-13-2009, 10:14 AM
brianlvi3's Avatar
Quoted: 58 Post(s)
I do see your point, but you get what you pay for. I have the Marantz as I have 5 HD sources connected to it and it goes out to 2 displays that will never be on at the same time. It has an aluminum face plate and is a very well made. Works like a charm. I wanted something that would look good and match my other equipment in my rack. Got the Marantz on sale for $199.00.
Just my 2 cents.
Brian
brianlvi3 is offline
post #3 of 9 Old 03-13-2009, 10:45 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 284 Post(s)
Liked: 3927
Display Port probably won't be in HTs, at least not supplanting HDMI. It looks like the real successor to DVI - video and such for the PC world.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #4 of 9 Old 03-13-2009, 11:24 AM
brianlvi3's Avatar
Quoted: 58 Post(s)
Not sure I follow you on this.
Brian
post #5 of 9 Old 03-28-2009, 05:30 PM
brianlvi3's Avatar
Quoted: 58 Post(s)
One last thing to add now that I have it fully intergrated in my system is the Harmony 720 remote can control it. It works so perfectly with the Harmony which will switch all the inputs the way I have it set up. I have a 75 ft HDMI run to my Panny projector and I have no problems whatsoever.
Just my 2 cents.
Brian
post #6 of 9 Old 03-29-2009, 04:17 PM
EVizzle's Avatar
According to Monoprice, their 4x2 Matrix unit will output simultaneously. I am anxiously waiting it (April 7th in stock date) and will be ordering it immediately.
EVizzle is offline
post #7 of 9 Old 03-30-2009, 09:29 AM
brianlvi3's Avatar
Quoted: 58 Post(s)
What is the difference on the 4 X 2 switchers they have for sale on Monoprice's web site. I see they have one in stock, but the other one, newer is out of stock.
They seem to be very similar, no?
Brian
post #8 of 9 Old 03-31-2009, 12:38 PM
9volt's Avatar
I believe only one of them will output a different signal to each hdmi out. The other outputs the same signal to each hdmi out.
9volt is offline
post #9 of 9 Old 03-31-2009, 01:09 PM
brianlvi3's Avatar
Quoted: 58 Post(s)
One last comment about this Marantz VS3002 HDMI switcher. I run the following thru ti with no problems at all;
Pioneer 51FD Blu ray player
Toshiba HD2 HD DVD player
Xbox 360 elite
PS3
Cable box
I only need to use the one output at a time as this is in a dedicated home theater room with a 50 inch Toshiba TV and a Panny projector, either one or the other gets used.
Also like I said, my Harmony 720 remote controls all my equipment including the switcher's inputs.
No problems at all, love it.
Brian
Reply HDMI Q&A - The One Connector World
