Does a HDMI Y-cable exist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 04-24-2008, 12:11 AM - Thread Starter
Daravon's Avatar
I only have one HDMI input on my Sony tube TV. I want to hook up my computer and my DVD player. Why can't i buy a simple Y-cable, it seems all I see are these fancy and expensive switchers. There should be no electrical problem if I'm just trying to watch one at a time, right? Why no y-cables?
I would consider using Component cables on one device, but my Oppo 981 won't output HD over component TTBOMK. Would using component cables out of my computer result in a great loss of PQ?
Daravon is offline
post #2 of 20 Old 04-24-2008, 12:56 AM
cavu's Avatar
monoprice.com has several HDMI "splitters"
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #3 of 20 Old 04-24-2008, 08:08 AM - Thread Starter
Daravon's Avatar
yes, and they all say this
(*) This is splitter cable. You can only connect one input device (i.e. DVD player,cable box or satellite receiver) to two output device(i.e. TV or projector).You can't connect two input device (i.e. DVD player,cable box or satellite receiver) to one output device(i.e. TV or projector)
I could get their 8 inch port saver and just manually plugand unplug the cables every time, but that would be a total PITA
Daravon is offline
post #4 of 20 Old 04-24-2008, 09:47 AM
crutschow's Avatar
You can't do it with an HDMI cable any more that you can with any other cable: component, composite, or RF. The two sources would be fighting each other. They must be isolated. Thus you need a switch with isolation between the two sources.
Carl
Curmudgeon Elektroniker
crutschow is offline
post #5 of 20 Old 04-24-2008, 10:29 AM - Thread Starter
Daravon's Avatar
You can do it with audio cables, that is, use Y-cables. You just have to make sure only one source is playing at one time, or else of course it doesn't work. i assumed it would work with video cables as well, if, for example, I left my DVD player off when I was trying to use the computer.
Daravon is offline
post #6 of 20 Old 04-24-2008, 12:59 PM
creatine64's Avatar
this is all I could find.
http://www.firefold.com/Products/2X1...I-2SWITCH.aspx
____________________________________________________________ ___________________________________________________
The HDMI Switcher allows access to multiple HDMI devices, such as DVD players and Satellite set-top boxes to one HDMI display
I mean no offense or anything but these weren't that hard to find.
just typed 2x1 HDMI splitter in google and in monoprice
creatine64 is offline
post #7 of 20 Old 04-24-2008, 01:24 PM
cavu's Avatar
I agree. I already directed them the the monoprice.com site!
" - MLK
cavu is offline
post #8 of 20 Old 04-24-2008, 01:33 PM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 284 Post(s)
Liked: 3923
Be careful. HDMI switches and HDMI splitters are two different devices. A switch (what the OP wants) switches between multiple input devices and directs output to one display. A HDMI splitter can direct one (of x) inputs and "split" the output to multiple displays at the same time. Usually splitters are switches also.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #9 of 20 Old 04-24-2008, 01:36 PM
creatine64's Avatar
larry
if you look at what was posted you'd see that we gave him what he asked for.
**edit**
I see what you mean though cause I typed 2x1 hdmi splitter in my search.
post #10 of 20 Old 04-24-2008, 04:09 PM - Thread Starter
Daravon's Avatar
to quote myself
My question wasn't so much 'how can I hook my system up' (I already stated that I knew about switchers). My question was more 'why do I have to buy an expensive switcher to hook my system up, and why can't I just use a simple Y-cable.'
What is it about HDMI that won't let me simply branch the cable off? It would be the same thing as unplugging it from one source and plugging it into the other source, provided I turned one source off and turned the other one on. I don't understand the technical reason why I should have to buy a switcher.
Daravon is offline
post #11 of 20 Old 04-24-2008, 05:34 PM
crutschow's Avatar
to quote myself
It's not the same as unplugging one source and plugging in another.
This is not unique to HDMI, it's common to all high frequency connections (where the transmission distance is more than a quarter of the highest frequency wavelength). The problem is that high frequency circuits such as video, RF and HDMI require that the source and load impedances be matched to the cable impedances for proper signal fidelity. If you connect two sources to the same cable, the impedances are now mismatched and serious signal reflections and degradation will likely occur. The usual way to avoid this is thus to have isolation between the two sources by a switch (either mechanical or electronic).
The problem doesn't occur for audio at the length of typical home connections because of the long wavelength of audio frequencies (9.3 miles at 20,000Hz). But if you were to send the audio several miles, than you could have the same problem.
Carl
post #12 of 20 Old 04-24-2008, 06:19 PM - Thread Starter
Daravon's Avatar
thank you for answering my question.
Daravon is offline
post #13 of 20 Old 04-25-2008, 01:42 PM
Moderator
Moderator
Quoted: 284 Post(s)
Liked: 3923
**edit**
Yes, I just wanted to make sure that the OP and anybody else who read the thread knew the difference to prevent undue confusion down the road. "Splitter" was being used too much even though the pic and what the OP described was a switch.
larry
post #14 of 20 Old 04-26-2008, 01:57 PM
hawkeye3.1's Avatar
High frequency and impedance issues are concerns when splitting digital connections but the main reason with HDMI is that it is a smart connection, yah I know that seems like a misnomer with all the problems inherent to it, but what I mean is the transmitting end communicates with the receiving end to determine how to configure the connection and establish HDCP authorization. This even occurs if the receiving device is turned off because the transmitter supplies 5 vdc over the cable to power just the HDMI chip in the receiving device. It is my understanding, that if you try to connect two receivers at the same time the transmitter will be unable to resolve EDID/HDCP data with two devices talking back to it at once.
hawkeye3.1 is offline
post #15 of 20 Old 04-28-2008, 07:55 AM
Dogorbit's Avatar
There is more to the issue than just bandwidth of the signal. HDMI is an active bidirectional communication protocol. That is, the receiver talks to the transmitter and tells it what signals it can receive (ie. video only, video and audio, audio only, what protocol is to be used for each. etc). The transmitter then sets itself up to send the proper signals to that specific receiver. Any splitter would place two receivers on the same signalling wires. This effectively shorts out the signalling lines and can damage the equipment. Even if no damage occurs, the transmitter will likely receive two conflicting sets of information from the receivers. This will prevent the transmitter from setting up the video transmission.
Dogorbit is offline
post #16 of 20 Old 05-10-2013, 08:59 AM
Psawed's Avatar
My receiver has 2 HDMI in and I'm using a "Y" cable on 2 devices, a BDR and a HTPC into the HDMI - A. HDMI - B is assigned to a ROKU. The two devices on the "Y" cable work flawlessly, I do not have to switch anything manually or otherwise. I should have bought 2 of these cables when I had the chance as I can no longer find them anywhere. I've had this cable for 3 or 4 years and just tried looking for a manufacturer but the only thing on the cable is 4608MKA on one side and SWITCH on the other side. I thought it was from Pelican but I could be wrong.
Psawed is offline
post #17 of 20 Old 05-10-2013, 10:38 AM
alk3997's Avatar
Liked: 92
This makes no sense. You are using a y-cable into the HDMI port on the receiver?? So which device do you see?? Do you see both at the same time? Actually a true Y-cable should result in no image at all.
Maybe what you meant to say is that this cable has some type of switch to choose between A and B?
alk3997 is offline
post #18 of 20 Old 11-21-2014, 01:53 PM
LilBro's Avatar
2 x 1 HDMI cable
I know this is an old thread, but before I buy anything, I want to be clear in this old, feeble mind. I plan to replace my Kenwood VR-509 receiver with either a Pioneer or Yamaha unit. Both only have one HDMI out with no HDMI Standby passthrough. The TV is an LG 50" flat panel with 2 HDMI in. Most of the time we'll probably not have the amp turned on but just pipe the Dish Hopper satellite feed into the TV. Would a simple y-cable work or would I be better off getting an amp with HDMI standby passthrough?
Für Elise  Support the Heart & Breast Cancer Foundations
LilBro is offline
post #19 of 20 Old 11-21-2014, 06:21 PM
LilBro's Avatar
Y cable or pass thru HDMI - Found answer
Looks like using a Y-cable instead of HDMI standby pass-through is not going to work. So I spend an extra 30 buck to get pass thru. I'll also get internet access. Whoopee.
LilBro is offline
post #20 of 20 Old 11-24-2014, 10:26 AM
AV_Integrated's Avatar
Quoted: 971 Post(s)
Liked: 718
Or just use the receiver all the time with the nice speakers you spent money on.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Reply HDMI Q&A - The One Connector World
