1 input, 2 output HDMI switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-22-2008, 03:46 PM - Thread Starter
jark87's Avatar
I am looking for an HDMI switch box that will take 1 input (from cable STB) to 2 outputs (LCD TV and AV Receiver). I don't want to split the signal, as I will only use 1 at a time. I just don't want to use my AV receiver every time I watch TV, so I want to be able to have the cable source go direct to my TV, as well as AV receiver for the times when I want home theater sound.
Any advice is much appreciated.
jark87 is offline
post #2 of 10 Old 06-23-2008, 12:55 PM
crutschow's Avatar
Monoprice sells such a device (they call a splitter) http://www.monoprice.com/products/pr...seq=1&format=2 which connects one source device to two display devices.
Carl
Curmudgeon Elektroniker
crutschow is offline
post #3 of 10 Old 06-27-2008, 12:48 AM
tomscave's Avatar
Has anyone used that Monoprice splitter (part #2522)? If so, is it functioning properly? I'm thinking about trying one, but if it doesn't function well, I won't waste my money. I found some info here http://www.avsforum.com/avs-vb/showthread.php?t=1017342 , but it looks like noone has actualy tried it.
Edit - Found my answers here http://www.avsforum.com/avs-vb/showthread.php?t=793241
"I'm suffering from the dreaded upgrade bug"
tomscave is offline
post #4 of 10 Old 08-18-2008, 08:02 AM
Yakko_68's Avatar
That can be tricky. A non powered splitter is usually designed to do what you're talking about. Fry's has one for $ 19.99.
http://shop3.frys.com/product/508296...H:MAIN_RSLT_PG
Just out of curiosity, why aren't you just sending your STB audio over optical or coaxial outputs to your AV Receiver? Nothing more taxing than Dobly Digital 5.1 should ever come out of your STB - no need for HDMI for that. I'm assuming if your receiver has HDMI inputs it has a wealth of other digital audio inputs available. Are they all spoken for? Or is your STB like the annoying Playstation 3 where it won't simultaneously send audo via optical and HDMI?
P
Yakko_68 is offline
post #5 of 10 Old 06-28-2012, 05:34 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Doesn't work for me at all, trying to connect a laptop to two TVs and it's a no go.
joed32 is offline
post #6 of 10 Old 06-28-2012, 11:26 AM
steve771's Avatar
Quoted: 42 Post(s)
Not trying to hijack this thread, but along these lines... I want to use my computer HDMI out to feed my computer monitor AND my HDTV, but not at the same time. Is there such a splitter out there? Right now, I crawl to the back of the computer (after powering down) and unplug/plug the correct HDMI cable. Just looking for convenience of not having to do that.
steve771 is offline
post #7 of 10 Old 06-28-2012, 12:25 PM
alk3997's Avatar
Liked: 92
Why not at the same time? If you can live with both devices having the same outputs, then just get a HDMI distribution amp. Fry's sells a bunch last time I looked. When I got one four years ago, it was about $70. They are probably cheaper now.
Just remember the HDMI least common demominator principle will apply with two sinks.
alk3997 is offline
post #8 of 10 Old 06-28-2012, 03:31 PM
steve771's Avatar
Quoted: 42 Post(s)
Mainly because I only use the HDMI TV output once & awhile. Just didn't see the need to have something that would keep them both active, and thought maybe there was something cheap that would do the job. Thinking along the lines of an A/B type of switch.
steve771 is offline
post #9 of 10 Old 06-28-2012, 04:58 PM
alk3997's Avatar
Liked: 92
You're really not losing anything keeping both ports active. All of the A/B switches I know of are actually active switches (they use power from the HDMI cable), so you really don't gain anything with an A/B switch in your situation. The high speed digital data isn't really compatible with an old-fashioned ca-chunga switch - when you look at A/B switches, if you see an LED light, then that is a powered switch. Also if you do find a true A/B switch that means the EDID handshake will have to start over again when you change the position which will increase the time it takes to display a picture (which is already too slow).
alk3997 is offline
post #10 of 10 Old 06-28-2012, 05:55 PM
steve771's Avatar
Quoted: 42 Post(s)
Ok, thanks!
steve771 is offline
Reply HDMI Q&A - The One Connector World
